Home » Eclipse Projects » NatTable » Can't compile the nattable examples (Compilation problems)
| Can't compile the nattable examples [message #981345] |
Mon, 12 November 2012 05:45  |
I followed the instructions in 'getting started' (http://eclipse.org/nattable/documentation.php?page=getting_started), but some projects turn red in eclipse. The maven compiles work OK, import in eclipse goes well too, except for a few projects turning red. The root cause might well be that when I run the copy dependencies step, either from the command line, or from eclipse, the system doesn't generate a dependencies subdirectory. The maven command 'mvn dependency:copy-dependencies -DoutputDirectory=dependencies' doesn't complain about anything, but it doesn't produce any output. Any idea what might be wrong here?
| Re: Can't compile the nattable examples [message #982837 is a reply to message #982530] |
Tue, 13 November 2012 08:06   |
- Did you call the command from the command line out of the correct directory (as explained in the documentation)?
=> Yes, i'm sure of that
- Did you try the second attempt to install m2e and run the copy dependencies.launch file out of Eclipse?
=> m2e was already installed in my eclipse, I updated the run configuration 'copy dependencies' to use my own maven instead of the eclipse embedded maven, and then it worked just like the one on the command line: happily returning, producing no output
- Did you ensure that the workspace is in sync?
=> I guess so, was looking for the dependencies subdirectory from windows explorer, it's not there
=> when hitting the 'Set as Target Platform' link eclipse also complains that the subdir doesn't exist
- Did you check the target definition in the PDE editor?
=> yep
- Sorry for some of the questions ..
=> No problem, I'm grateful for your feedback!
- you might have an issue with your firewall?
=> We do have a firewall in the office, but mvn is configured to work OK. The maven output of the first two commands (mvn -f deps/pom.xml clean install
mvn -f org.eclipse.nebula.widgets.nattable.parent/pom.xml clean install) shows that my maven is working normally. What i don't understand is that everything compiles, but still I don't see a ca.odell.xxx.yyy in my local repository.
- A shame I cannot attach files to this forum because I assembled a few files to illustrate what i did: screenshots and console output ...
| Re: Can't compile the nattable examples [message #982871 is a reply to message #982847] |
Tue, 13 November 2012 08:39   |
1) tried with my own maven and the embedded one
2) output is similar, see below
3) still don't understand how 'mvn clean install' from command line can work, when there's no ca.odell.x.y in my local repository. But I don't know a thing about tycho, I think in maven proper this is impossible
4) maven debug information:
Apache Maven 3.0.4 (r1232337; 2012-01-17 09:44:56+0100)
Maven home: C:\programs\apache-maven-3.0.4
Java version: 1.6.0_31, vendor: Sun Microsystems Inc.
Java home: C:\programs\jdk1.6.0_31_32bit\jre
Default locale: nl_BE, platform encoding: Cp1252
OS name: "windows 7", version: "6.1", arch: "x86", family: "windows"
[INFO] Error stacktraces are turned on.
[DEBUG] Reading global settings from C:\programs\apache-maven-3.0.4\conf\settings.xml
[DEBUG] Reading user settings from C:\programs\apache-maven-3.0.4\conf\settings.xml
[DEBUG] Using local repository at c:\data\mvn_repo
[DEBUG] Using manager EnhancedLocalRepositoryManager with priority 10 for c:\data\mvn_repo
[INFO] Scanning for projects...
[DEBUG] org.eclipse.tycho:tycho-maven-plugin:jar:0.15.0:
[DEBUG] org.eclipse.tycho:tycho-core:jar:0.15.0:compile
[DEBUG] org.apache.maven:maven-core:jar:3.0:compile
[DEBUG] org.apache.maven:maven-model:jar:3.0:compile
[DEBUG] org.apache.maven:maven-settings:jar:3.0:compile
[DEBUG] org.apache.maven:maven-settings-builder:jar:3.0:compile
[DEBUG] org.apache.maven:maven-repository-metadata:jar:3.0:compile
[DEBUG] org.apache.maven:maven-artifact:jar:3.0:compile
[DEBUG] org.apache.maven:maven-model-builder:jar:3.0:compile
[DEBUG] org.apache.maven:maven-aether-provider:jar:3.0:runtime
[DEBUG] org.sonatype.aether:aether-impl:jar:1.7:compile
[DEBUG] org.sonatype.aether:aether-spi:jar:1.7:compile
[DEBUG] org.sonatype.aether:aether-api:jar:1.7:compile
[DEBUG] org.sonatype.aether:aether-util:jar:1.7:compile
[DEBUG] org.codehaus.plexus:plexus-interpolation:jar:1.14:compile
[DEBUG] org.codehaus.plexus:plexus-classworlds:jar:2.2.3:compile
[DEBUG] org.sonatype.plexus:plexus-sec-dispatcher:jar:1.3:compile
[DEBUG] org.sonatype.plexus:plexus-cipher:jar:1.4:compile
[DEBUG] org.apache.maven:maven-plugin-api:jar:3.0:compile
[DEBUG] org.codehaus.plexus:plexus-utils:jar:2.0.4:compile
[DEBUG] org.codehaus.plexus:plexus-archiver:jar:1.2:compile
[DEBUG] org.codehaus.plexus:plexus-io:jar:1.0.1:compile
[DEBUG] org.eclipse.tycho:org.eclipse.osgi:jar:3.8.0.v20120430-1750:compile
[DEBUG] org.eclipse.tycho:sisu-equinox-embedder:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:sisu-equinox-api:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:tycho-metadata-model:jar:0.15.0:compile
[DEBUG] de.pdark:decentxml:jar:1.3:compile
[DEBUG] org.eclipse.tycho:tycho-embedder-api:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:org.eclipse.tycho.embedder.shared:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:org.eclipse.tycho.core.shared:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:tycho-p2-facade:jar:0.15.0:compile
[DEBUG] org.codehaus.plexus:plexus-component-annotations:jar:1.5.5:compile
[DEBUG] org.sonatype.sisu:sisu-inject-plexus:jar:1.4.2:compile
[DEBUG] org.sonatype.sisu:sisu-inject-bean:jar:1.4.2:compile
[DEBUG] org.sonatype.sisu:sisu-guice:jar:noaop:2.1.7:compile
[DEBUG] org.eclipse.tycho:org.eclipse.tycho.p2.resolver.shared:jar:0.15.0:compile
[DEBUG] org.eclipse.tycho:org.eclipse.tycho.p2.tools.shared:jar:0.15.0:compile
[DEBUG] Created new class realm maven.api
[DEBUG] Importing foreign packages into class realm maven.api
[DEBUG] Imported: org.apache.maven.wagon.events < plexus.core
[DEBUG] Imported: org.sonatype.aether.transfer < plexus.core
[DEBUG] Imported: org.apache.maven.exception < plexus.core
[DEBUG] Imported: org.sonatype.aether.metadata < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.Xpp3Dom < plexus.core
[DEBUG] Imported: org.sonatype.aether.collection < plexus.core
[DEBUG] Imported: org.sonatype.aether.version < plexus.core
[DEBUG] Imported: org.apache.maven.monitor < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.repository < plexus.core
[DEBUG] Imported: org.apache.maven.repository < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.resource < plexus.core
[DEBUG] Imported: org.codehaus.plexus.logging < plexus.core
[DEBUG] Imported: org.apache.maven.profiles < plexus.core
[DEBUG] Imported: org.sonatype.aether.repository < plexus.core
[DEBUG] Imported: org.apache.maven.classrealm < plexus.core
[DEBUG] Imported: org.apache.maven.execution < plexus.core
[DEBUG] Imported: org.sonatype.aether.artifact < plexus.core
[DEBUG] Imported: org.sonatype.aether.spi < plexus.core
[DEBUG] Imported: org.apache.maven.reporting < plexus.core
[DEBUG] Imported: org.apache.maven.usability < plexus.core
[DEBUG] Imported: org.codehaus.plexus.container < plexus.core
[DEBUG] Imported: org.codehaus.plexus.component < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlSerializer < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.authentication < plexus.core
[DEBUG] Imported: org.apache.maven.lifecycle < plexus.core
[DEBUG] Imported: org.codehaus.plexus.classworlds < plexus.core
[DEBUG] Imported: org.sonatype.aether.graph < plexus.core
[DEBUG] Imported: org.sonatype.aether.* < plexus.core
[DEBUG] Imported: org.apache.maven.settings < plexus.core
[DEBUG] Imported: org.codehaus.classworlds < plexus.core
[DEBUG] Imported: org.sonatype.aether.impl < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.* < plexus.core
[DEBUG] Imported: org.apache.maven.toolchain < plexus.core
[DEBUG] Imported: org.sonatype.aether.deployment < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.observers < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlPullParserException < plexus.core
[DEBUG] Imported: org.codehaus.plexus.util.xml.pull.XmlPullParser < plexus.core
[DEBUG] Imported: org.apache.maven.configuration < plexus.core
[DEBUG] Imported: org.apache.maven.cli < plexus.core
[DEBUG] Imported: org.sonatype.aether.installation < plexus.core
[DEBUG] Imported: org.codehaus.plexus.context < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.authorization < plexus.core
[DEBUG] Imported: org.apache.maven.project < plexus.core
[DEBUG] Imported: org.apache.maven.rtinfo < plexus.core
[DEBUG] Imported: org.codehaus.plexus.lifecycle < plexus.core
[DEBUG] Imported: org.codehaus.plexus.configuration < plexus.core
[DEBUG] Imported: org.apache.maven.artifact < plexus.core
[DEBUG] Imported: org.apache.maven.model < plexus.core
[DEBUG] Imported: org.apache.maven.* < plexus.core
[DEBUG] Imported: org.apache.maven.wagon.proxy < plexus.core
[DEBUG] Imported: org.sonatype.aether.resolution < plexus.core
[DEBUG] Imported: org.apache.maven.plugin < plexus.core
[DEBUG] Imported: org.codehaus.plexus.* < plexus.core
[DEBUG] Imported: org.codehaus.plexus.personality < plexus.core
[DEBUG] Populating class realm maven.api
[DEBUG] Created new class realm extension>org.eclipse.tycho:tycho-maven-plugin:0.15.0
[DEBUG] Importing foreign packages into class realm extension>org.eclipse.tycho:tycho-maven-plugin:0.15.0
[DEBUG] Imported: < maven.api
[DEBUG] Populating class realm extension>org.eclipse.tycho:tycho-maven-plugin:0.15.0
[DEBUG] Included: org.eclipse.tycho:tycho-maven-plugin:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:tycho-core:jar:0.15.0
[DEBUG] Included: org.sonatype.aether:aether-util:jar:1.7
[DEBUG] Included: org.codehaus.plexus:plexus-interpolation:jar:1.14
[DEBUG] Included: org.sonatype.plexus:plexus-sec-dispatcher:jar:1.3
[DEBUG] Included: org.sonatype.plexus:plexus-cipher:jar:1.4
[DEBUG] Included: org.codehaus.plexus:plexus-utils:jar:2.0.4
[DEBUG] Included: org.codehaus.plexus:plexus-archiver:jar:1.2
[DEBUG] Included: org.codehaus.plexus:plexus-io:jar:1.0.1
[DEBUG] Included: org.eclipse.tycho:org.eclipse.osgi:jar:3.8.0.v20120430-1750
[DEBUG] Included: org.eclipse.tycho:sisu-equinox-embedder:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:sisu-equinox-api:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:tycho-metadata-model:jar:0.15.0
[DEBUG] Included: de.pdark:decentxml:jar:1.3
[DEBUG] Included: org.eclipse.tycho:tycho-embedder-api:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:org.eclipse.tycho.embedder.shared:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:org.eclipse.tycho.core.shared:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:tycho-p2-facade:jar:0.15.0
[DEBUG] Included: org.codehaus.plexus:plexus-component-annotations:jar:1.5.5
[DEBUG] Included: org.sonatype.sisu:sisu-inject-bean:jar:1.4.2
[DEBUG] Included: org.sonatype.sisu:sisu-guice:jar:noaop:2.1.7
[DEBUG] Included: org.eclipse.tycho:org.eclipse.tycho.p2.resolver.shared:jar:0.15.0
[DEBUG] Included: org.eclipse.tycho:org.eclipse.tycho.p2.tools.shared:jar:0.15.0
[DEBUG] Extension realms for project org.eclipse.nebula.widgets.nattable:target-platform:pom:0.9.0-SNAPSHOT: [ClassRealm[extension>org.eclipse.tycho:tycho-maven-plugin:0.15.0, parent: sun.misc.Launcher$AppClassLoader@1ea2dfe]]
[DEBUG] Created new class realm project>org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT
[DEBUG] Populating class realm project>org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT
[DEBUG] Looking up lifecyle mappings for packaging pom from ClassRealm[project>org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT, parent: ClassRealm[maven.api, parent: null]]
[DEBUG] === REACTOR BUILD PLAN ================================================
[DEBUG] Project: org.eclipse.nebula.widgets.nattable:target-platform:pom:0.9.0-SNAPSHOT
[DEBUG] Tasks: [org.apache.maven.plugins:maven-dependency-plugin:2.0:copy-dependencies]
[DEBUG] Style: Regular
[DEBUG] =======================================================================
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building target-platform 0.9.0-SNAPSHOT
[DEBUG] Lifecycle default -> [validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy]
[DEBUG] Lifecycle clean -> [pre-clean, clean, post-clean]
[DEBUG] Lifecycle site -> [pre-site, site, post-site, site-deploy]
[DEBUG] === PROJECT BUILD PLAN ================================================
[DEBUG] Project: org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT
[DEBUG] Dependencies (collect): []
[DEBUG] Dependencies (resolve): [test]
[DEBUG] Repositories (dependencies): [download_maven_2 (http://download.java.net/maven/2/, releases+snapshots), central-repo (http://repo.maven.apache.org/maven2/, releases+snapshots), jboss-public-repository-group (https://repository.jboss.org/nexus/content/groups/public-jboss/, releases+snapshots), central (http://repo.maven.apache.org/maven2, releases)]
[DEBUG] Repositories (plugins) : [jboss-public-repository-group (https://repository.jboss.org/nexus/content/groups/public-jboss/, releases+snapshots), central-plugin-repo (http://repo.maven.apache.org/maven2/, releases+snapshots), central (http://repo.maven.apache.org/maven2, releases)]
[DEBUG] -----------------------------------------------------------------------
[DEBUG] Goal: org.apache.maven.plugins:maven-dependency-plugin:2.0:copy-dependencies (default-cli)
[DEBUG] Configuration: <?xml version="1.0" encoding="UTF-8"?>
<configuration>
<classifier default-value="">${classifier}</classifier>
<copyPom default-value="false">${mdep.copyPom}</copyPom>
<excludeArtifactIds default-value="">${excludeArtifactIds}</excludeArtifactIds>
<excludeClassifiers default-value="">${excludeClassifiers}</excludeClassifiers>
<excludeGroupIds default-value="">${excludeGroupIds}</excludeGroupIds>
<excludeScope default-value="">${excludeScope}</excludeScope>
<excludeTransitive default-value="false">${excludeTransitive}</excludeTransitive>
<excludeTypes default-value="">${excludeTypes}</excludeTypes>
<failOnMissingClassifierArtifact default-value="true">${mdep.failOnMissingClassifierArtifact}</failOnMissingClassifierArtifact>
<includeArtifactIds default-value="">${includeArtifactIds}</includeArtifactIds>
<includeClassifiers default-value="">${includeClassifiers}</includeClassifiers>
<includeGroupIds default-value="">${includeGroupIds}</includeGroupIds>
<includeScope default-value="">${includeScope}</includeScope>
<includeTypes default-value="">${includeTypes}</includeTypes>
<local>${localRepository}</local>
<markersDirectory default-value="${project.build.directory}/dependency-maven-plugin-markers">${markersDirectory}</markersDirectory>
<outputAbsoluteArtifactFilename default-value="false">${outputAbsoluteArtifactFilename}</outputAbsoluteArtifactFilename>
<outputDirectory default-value="${project.build.directory}/dependency">${outputDirectory}</outputDirectory>
<overWriteIfNewer default-value="true">${overWriteIfNewer}</overWriteIfNewer>
<overWriteReleases default-value="false">${overWriteReleases}</overWriteReleases>
<overWriteSnapshots default-value="false">${overWriteSnapshots}</overWriteSnapshots>
<project>${project}</project>
<reactorProjects>${reactorProjects}</reactorProjects>
<remoteRepos>${project.remoteArtifactRepositories}</remoteRepos>
<silent default-value="false">${silent}</silent>
<stripVersion default-value="false">${mdep.stripVersion}</stripVersion>
<type default-value="java-source">${type}</type>
<useRepositoryLayout default-value="false">${mdep.useRepositoryLayout}</useRepositoryLayout>
<useSubDirectoryPerArtifact default-value="false">${mdep.useSubDirectoryPerArtifact}</useSubDirectoryPerArtifact>
<useSubDirectoryPerType default-value="false">${mdep.useSubDirectoryPerType}</useSubDirectoryPerType>
</configuration>
[DEBUG] org.eclipse.nebula.widgets.nattable:target-platform:pom:0.9.0-SNAPSHOT
[INFO]
[INFO] --- maven-dependency-plugin:2.0:copy-dependencies (default-cli) @ target-platform ---
[DEBUG] org.apache.maven.plugins:maven-dependency-plugin:jar:2.0:
[DEBUG] org.apache.maven:maven-artifact:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-plugin-api:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-project:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-settings:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-profile:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-artifact-manager:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-plugin-registry:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-model:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-core:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-plugin-parameter-documenter:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-repository-metadata:jar:2.0.8:compile
[DEBUG] org.apache.maven:maven-error-diagnostics:jar:2.0.8:compile
[DEBUG] commons-cli:commons-cli:jar:1.0:compile
[DEBUG] org.apache.maven:maven-plugin-descriptor:jar:2.0.8:compile
[DEBUG] org.codehaus.plexus:plexus-interactivity-api:jar:1.0-alpha-4:compile
[DEBUG] org.apache.maven:maven-monitor:jar:2.0.8:compile
[DEBUG] classworlds:classworlds:jar:1.1:compile
[DEBUG] org.codehaus.plexus:plexus-archiver:jar:1.0-alpha-9:compile
[DEBUG] org.codehaus.plexus:plexus-utils:jar:1.4.6:compile
[DEBUG] org.apache.maven.shared:file-management:jar:1.1:compile
[DEBUG] org.apache.maven.shared:maven-shared-io:jar:1.0:compile
[DEBUG] org.apache.maven.wagon:wagon-provider-api:jar:1.0-alpha-6:compile
[DEBUG] org.codehaus.plexus:plexus-container-default:jar:1.0-alpha-9-stable-1:compile
[DEBUG] junit:junit:jar:3.8.1:compile
[DEBUG] org.apache.maven.shared:maven-dependency-analyzer:jar:1.0:compile
[DEBUG] asm:asm:jar:3.0:compile
[DEBUG] org.apache.maven.shared:maven-dependency-tree:jar:1.1:compile
[DEBUG] org.apache.maven.shared:maven-common-artifact-filters:jar:1.0:compile
[DEBUG] org.apache.maven.shared:maven-plugin-testing-harness:jar:1.1:compile
[DEBUG] org.codehaus.plexus:plexus-io:jar:1.0-alpha-1:compile
[DEBUG] org.apache.maven.reporting:maven-reporting-api:jar:2.0.6:compile
[DEBUG] org.apache.maven.reporting:maven-reporting-impl:jar:2.0.4:compile
[DEBUG] commons-validator:commons-validator:jar:1.2.0:compile
[DEBUG] commons-beanutils:commons-beanutils:jar:1.7.0:compile
[DEBUG] commons-digester:commons-digester:jar:1.6:compile
[DEBUG] commons-logging:commons-logging:jar:1.0.4:compile
[DEBUG] xml-apis:xml-apis:jar:1.0.b2:compile
[DEBUG] org.apache.maven.doxia:doxia-core:jar:1.0-alpha-7:compile
[DEBUG] oro:oro:jar:2.0.7:compile
[DEBUG] org.apache.maven.doxia:doxia-sink-api:jar:1.0-alpha-8:compile
[DEBUG] org.apache.maven.doxia:doxia-site-renderer:jar:1.0-alpha-8:compile
[DEBUG] org.codehaus.plexus:plexus-i18n:jar:1.0-beta-6:compile
[DEBUG] org.codehaus.plexus:plexus-velocity:jar:1.1.3:compile
[DEBUG] commons-collections:commons-collections:jar:2.0:compile
[DEBUG] velocity:velocity:jar:1.4:compile
[DEBUG] velocity:velocity-dep:jar:1.4:runtime
[DEBUG] org.apache.maven.doxia:doxia-decoration-model:jar:1.0-alpha-8:compile
[DEBUG] Created new class realm plugin>org.apache.maven.plugins:maven-dependency-plugin:2.0
[DEBUG] Importing foreign packages into class realm plugin>org.apache.maven.plugins:maven-dependency-plugin:2.0
[DEBUG] Imported: < project>org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT
[DEBUG] Populating class realm plugin>org.apache.maven.plugins:maven-dependency-plugin:2.0
[DEBUG] Included: org.apache.maven.plugins:maven-dependency-plugin:jar:2.0
[DEBUG] Included: commons-cli:commons-cli:jar:1.0
[DEBUG] Included: org.codehaus.plexus:plexus-interactivity-api:jar:1.0-alpha-4
[DEBUG] Included: org.codehaus.plexus:plexus-archiver:jar:1.0-alpha-9
[DEBUG] Included: org.codehaus.plexus:plexus-utils:jar:1.4.6
[DEBUG] Included: org.apache.maven.shared:file-management:jar:1.1
[DEBUG] Included: org.apache.maven.shared:maven-shared-io:jar:1.0
[DEBUG] Included: junit:junit:jar:3.8.1
[DEBUG] Included: org.apache.maven.shared:maven-dependency-analyzer:jar:1.0
[DEBUG] Included: asm:asm:jar:3.0
[DEBUG] Included: org.apache.maven.shared:maven-dependency-tree:jar:1.1
[DEBUG] Included: org.apache.maven.shared:maven-common-artifact-filters:jar:1.0
[DEBUG] Included: org.apache.maven.shared:maven-plugin-testing-harness:jar:1.1
[DEBUG] Included: org.codehaus.plexus:plexus-io:jar:1.0-alpha-1
[DEBUG] Included: org.apache.maven.reporting:maven-reporting-api:jar:2.0.6
[DEBUG] Included: org.apache.maven.reporting:maven-reporting-impl:jar:2.0.4
[DEBUG] Included: commons-validator:commons-validator:jar:1.2.0
[DEBUG] Included: commons-beanutils:commons-beanutils:jar:1.7.0
[DEBUG] Included: commons-digester:commons-digester:jar:1.6
[DEBUG] Included: commons-logging:commons-logging:jar:1.0.4
[DEBUG] Included: xml-apis:xml-apis:jar:1.0.b2
[DEBUG] Included: org.apache.maven.doxia:doxia-core:jar:1.0-alpha-7
[DEBUG] Included: oro:oro:jar:2.0.7
[DEBUG] Included: org.apache.maven.doxia:doxia-sink-api:jar:1.0-alpha-8
[DEBUG] Included: org.apache.maven.doxia:doxia-site-renderer:jar:1.0-alpha-8
[DEBUG] Included: org.codehaus.plexus:plexus-i18n:jar:1.0-beta-6
[DEBUG] Included: org.codehaus.plexus:plexus-velocity:jar:1.1.3
[DEBUG] Included: commons-collections:commons-collections:jar:2.0
[DEBUG] Included: velocity:velocity:jar:1.4
[DEBUG] Included: velocity:velocity-dep:jar:1.4
[DEBUG] Included: org.apache.maven.doxia:doxia-decoration-model:jar:1.0-alpha-8
[DEBUG] Excluded: org.apache.maven:maven-artifact:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-plugin-api:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-project:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-settings:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-profile:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-artifact-manager:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-plugin-registry:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-model:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-core:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-plugin-parameter-documenter:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-repository-metadata:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-error-diagnostics:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-plugin-descriptor:jar:2.0.8
[DEBUG] Excluded: org.apache.maven:maven-monitor:jar:2.0.8
[DEBUG] Excluded: classworlds:classworlds:jar:1.1
[DEBUG] Excluded: org.apache.maven.wagon:wagon-provider-api:jar:1.0-alpha-6
[DEBUG] Excluded: org.codehaus.plexus:plexus-container-default:jar:1.0-alpha-9-stable-1
[DEBUG] Configuring mojo org.apache.maven.plugins:maven-dependency-plugin:2.0:copy-dependencies from plugin realm ClassRealm[plugin>org.apache.maven.plugins:maven-dependency-plugin:2.0, parent: sun.misc.Launcher$AppClassLoader@1ea2dfe]
[DEBUG] Configuring mojo 'org.apache.maven.plugins:maven-dependency-plugin:2.0:copy-dependencies' with basic configurator -->
[DEBUG] (s) copyPom = false
[DEBUG] (f) excludeTransitive = false
[DEBUG] (s) failOnMissingClassifierArtifact = true
[DEBUG] (s) local = id: local
url: file:///c:/data/mvn_repo/
layout: none
[DEBUG] (s) markersDirectory = C:\projects\lab\org.eclipse.nebula.widgets.nattable\target-platform\target\dependency-maven-plugin-markers
[DEBUG] (f) outputAbsoluteArtifactFilename = false
[DEBUG] (s) outputDirectory = C:\projects\lab\org.eclipse.nebula.widgets.nattable\target-platform\dependencies
[DEBUG] (f) overWriteIfNewer = true
[DEBUG] (f) overWriteReleases = false
[DEBUG] (f) overWriteSnapshots = false
[DEBUG] (f) project = MavenProject: org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT @ C:\projects\lab\org.eclipse.nebula.widgets.nattable\target-platform\pom.xml
[DEBUG] (f) reactorProjects = [MavenProject: org.eclipse.nebula.widgets.nattable:target-platform:0.9.0-SNAPSHOT @ C:\projects\lab\org.eclipse.nebula.widgets.nattable\target-platform\pom.xml]
[DEBUG] (s) remoteRepos = [ id: download_maven_2
url: http://download.java.net/maven/2/
layout: default
snapshots: [enabled => true, update => never]
releases: [enabled => true, update => never]
, id: central-repo
url: http://repo.maven.apache.org/maven2/
layout: default
, id: jboss-public-repository-group
url: https://repository.jboss.org/nexus/content/groups/public-jboss/
layout: default
, id: central
layout: default
snapshots: [enabled => false, update => daily]
releases: [enabled => true, update => daily]
[DEBUG] (f) silent = false
[DEBUG] (s) stripVersion = false
[DEBUG] (f) type = java-source
[DEBUG] (s) useRepositoryLayout = false
[DEBUG] (s) useSubDirectoryPerArtifact = false
[DEBUG] (s) useSubDirectoryPerType = false
[DEBUG] -- end configuration --
[INFO] BUILD SUCCESS
[INFO] Total time: 1.030s
[INFO] Finished at: Tue Nov 13 14:35:42 CET 2012
[INFO] Final Memory: 5M/15M
Current Time: Sun Nov 09 09:55:05 EST 2025
Powered by FUDForum. Page generated in 0.05732 seconds
