Home » Eclipse Projects » Remote Application Platform (RAP) » Eclipse Juno RAP problem
icon5.gif  Eclipse Juno RAP problem [message #979197] Sat, 10 November 2012 13:18 Go to next message
Hi people, I just downloaded the last Eclipse for RCP and RAP developers.
I tryed to do the Hello example but it show me a error message when I try to run:
osgi> 2012-11-10 16:08:07.029:WARN:oejs.ServletHandler:ERROR:  /rap
java.lang.IllegalArgumentException: Entry point not found: default
Do I have to set the entrypoint in somewhere ?
My target is RAP 2.0, I didn't choose it.. it just download the "recommended one".
Thanks in advance
Re: Eclipse Juno RAP problem [message #980013 is a reply to message #979197] Sun, 11 November 2012 04:05 Go to previous messageGo to next message
Hi Felipe,
RAP 2.0 has a lot of breaking changes (see [1]). If your target is
2.0... you need Tools 2.0 as well. Unfortunately, there is a bug [2]
that prevents upgrading of Tools included in Juno "Eclipse for RCP and
RAP developers" package to the latest 2.0 milestone/nightly. You need
Juno Classic SDK package in order to install the latest version of Tools.
[1] http://www.eclipse.org/rap/noteworthy/2.0/migration-guide/
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=391336
Best,
Ivan
> try to run:
> "recommended one".
> Thanks in advance
> Regards
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Eclipse Juno RAP problem [message #980022 is a reply to message #979197] Sun, 11 November 2012 04:16 Go to previous messageGo to next message
One more hint... In your existing setup you could try to change your
launch configuration. Change the "Servlet Path" field from "/rap" to the
value specified in "Startup parameter" field. Afterwards leave the
"Startup parameter" field empty.
HTH,
Ivan
> try to run:
> "recommended one".
> Thanks in advance
> Regards
Ivan Furnadjiev
Re: Eclipse Juno RAP problem [message #980259 is a reply to message #980022] Sun, 11 November 2012 08:58 Go to previous messageGo to next message
Hi, thank you for your answer.
I changed the target to RAP 1.5 but got other error message:
org.osgi.framework.BundleException: The bundle "org.eclipse.rap.rwt.testfixture_1.5.1.20120917-1116 [21]" could not be resolved. Reason: Missing Constraint: Import-Package: org.json; version="0.0.0"
I'm use 64 bit eclipse version on Windows 7.
Anyway, I tryed also what you advice me about change the Servlet Path, but my Startup parameter is empty.. so it's does not work. Crying or Very Sad
Any clue Ivan ?
I would like very much to use RAP for my university project.
Re: Eclipse Juno RAP problem [message #980330 is a reply to message #980259] Sun, 11 November 2012 10:17 Go to previous messageGo to next message
Hi Felipe,
I would suggest to:
1. Download and install (unzip) "Eclipse for RCP and RAP developers"
Juno SR1.
2. Install and activate the latest released RAP runtime (Target
Components) [1] v1.5.1
3. Use "New Project" wizard to create RAP "Hello World" application.
[1] http://www.eclipse.org/rap/downloads/
PS. The org.eclipse.rap.rwt.testfixture bundle is not needed for normal
application execution, but only for JUnit tests.
HTH,
Ivan
On 11/11/2012 3:58 PM, Felipe Oliveira wrote:
> Hi, thank you for your answer. I changed the target to RAP 1.5 but got
> version="0.0.0"
> but my Startup parameter is empty.. so it's does not work. :cry:
> Any clue Ivan ?
> Thanks
Ivan Furnadjiev
Re: Eclipse Juno RAP problem [message #980389 is a reply to message #980330] Sun, 11 November 2012 11:32 Go to previous messageGo to next message
Hi Ivan.. I already tryed to do exactly what you said before.
And now I tryed again from the start but when I try to install target 1.5 it can't even install, I get a message:
Problems occurred while resolving the target contents
Error reading manifest for C:\ProjetosOSGI\workspace\.metadata\.plugins\org.eclipse.pde.core\.bundle_pool\plugins\org.eclipse.rap.ui.source_1.5.1.20120917-1116.jar
error in opening zip file
I'm out of luck I think.. since nobody seams to get this errors. It's a little deceiving.. I can't even get the hello world. Sad
Re: Eclipse Juno RAP problem [message #980471 is a reply to message #980389] Sun, 11 November 2012 13:02 Go to previous messageGo to next message
Hi Felipe,
RAP runtime (Target Component) must not be installed into the IDE. Open
Eclipse IDE menu: Window -> Preferences -> Plug-in Development -> Target
Platform and set it there (add new from update site).
HTH,
Ivan
> a little deceiving.. I can't even get the hello world. :(
> Regards
Ivan Furnadjiev
Re: Eclipse Juno RAP problem [message #980516 is a reply to message #980471] Sun, 11 November 2012 14:00 Go to previous messageGo to next message
Hi Ivan.. I tryed this way also and got same error:
Do you think RAP is ready for use in Eclipse ? If yes I would like if you give me a closer support as I see you offer professional services.
Maybe we can chat on gtalk or skype if you don't mind. My skype is felipe.oliveira.alert and gtalk felipe.bit@gmail.com
Thank you
Re: Eclipse Juno RAP problem [message #981185 is a reply to message #980516] Mon, 12 November 2012 03:12 Go to previous message
Hi Felipe,
RAP project is 6 years old project and it is included in all latest
simultaneous releases on Eclipse. Yes, it's ready to be used in Eclipse.
Just installed the latest RAP release (target platform) from the
following update site [1] without problem. For professional support look
here:
[1] http://download.eclipse.org/rt/rap/1.5/runtime
Best,
Ivan
> felipe.oliveira.alert and gtalk mailto:felipe.bit@xxxxxxxx
> Thank you
> Regards
Ivan Furnadjiev
Previous Topic:How to disable scrollbars in RAP 2.0M2
Next Topic:Excel file generated by poi can not been downloaded in IE6?
Current Time: Sat Jul 26 23:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.10408 seconds
