Home » Language IDEs » PHP Development Tools (PDT) » EPP PHP Error creating DocBlock
EPP PHP Error creating DocBlock [message #97873] Tue, 02 June 2009 18:36 Go to next message
I have just downloaded the PDT 2.1 All In One release for Windows 32 to
trial it for PHP development and I'm encountering an error when I try to
create a Doc block for a function or other element.
As the help says I right click on an element in the outline and select
source > generate element comment and immediately I get an error
"Could not open the editor : The file does not exist."
The error log is below
I've checked the md5 of the downloaded zip file
(eclipse-php-galileo-RC1-win32.zip) and I've unzipped it with two
different unarchivers and I've tried it on Vista Home Premium (32 bit) and
XP Pro 32 bit with the same result in each case.
Is this a bug or am I just missing something from the set up?
(I tried Googling but without any success)
The installation details are:
EPP PHP Package 1.0.0
Eclipse Platform 3.5.0.I20090515-1143
EPP PHP Feature 2.0.0.20090521-0720
Error Log
!SESSION 2009-06-02 23:13:56.562
eclipse.buildId=I20090515-1143
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product
!ENTRY org.eclipse.osgi 2 1 2009-06-02 23:15:37.453
!MESSAGE NLS missing message: DebugConnectionThread_oldDebuggerVersion in:
org.eclipse.php.internal.debug.core.PHPDebugCoreMessages
!MESSAGE NLS missing message: DebugServerTestEvent_success in:
!MESSAGE NLS missing message: DebugServerTestEvent_timeOutMessage in:
!ENTRY org.eclipse.ui.workbench 4 0 2009-06-02 23:18:41.250
!MESSAGE org.eclipse.jface.text.TextSelection cannot be cast to
org.eclipse.jface.viewers.IStructuredSelection
!STACK 0
java.lang.ClassCastException: org.eclipse.jface.text.TextSelection cannot
be cast to org.eclipse.jface.viewers.IStructuredSelection
at
org.eclipse.php.internal.ui.actions.ReorgMoveAction.selectio nChanged(ReorgMoveAction.java:89)
at
org.eclipse.php.internal.ui.actions.ReorgMoveAction.selectio nChanged(ReorgMoveAction.java:87)
at
org.eclipse.ui.internal.PluginAction.refreshEnablement(Plugi nAction.java:206)
at
org.eclipse.ui.internal.PluginAction.selectionChanged(Plugin Action.java:277)
at
org.eclipse.ui.internal.PluginAction.selectionChanged(Plugin Action.java:299)
at
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:156)
at
org.eclipse.ui.internal.AbstractSelectionService.setActivePa rt(AbstractSelectionService.java:282)
at
org.eclipse.ui.internal.WWinPartService.updateActivePart(WWi nPartService.java:132)
at
org.eclipse.ui.internal.WWinPartService.access$0(WWinPartSer vice.java:122)
at
org.eclipse.ui.internal.WWinPartService$WWinListener.partDea ctivated(WWinPartService.java:50)
at
org.eclipse.ui.internal.PartListenerList2$4.run(PartListener List2.java:115)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at
org.eclipse.ui.internal.PartListenerList2.fireEvent(PartList enerList2.java:55)
at
org.eclipse.ui.internal.PartListenerList2.firePartDeactivate d(PartListenerList2.java:113)
at
org.eclipse.ui.internal.PartService.firePartDeactivated(Part Service.java:242)
at org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:300)
at
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:57)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java :136)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3531)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:614)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2869)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at
org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1151)
at
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:107)
at
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:76)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
!ENTRY org.eclipse.ui 4 0 2009-06-02 23:20:23.234
!MESSAGE Unable to create editor ID org.eclipse.php.editor: The file does
not exist.
!STACK 1
org.eclipse.core.runtime.CoreException: The file does not exist.
at
org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:237)
at
org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:113)
at
org.eclipse.ui.editors.text.TextFileDocumentProvider.createF ileInfo(TextFileDocumentProvider.java:559)
at
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.createFileInfo(SourceModuleDocumentProvider.java:1237)
at
org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at
org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.connect(SourceModuleDocumentProvider.java:1517)
at
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4134)
at
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:166)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:1712)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(PHPStructuredEditor.java:2013)
at
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2578)
at
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2321)
at
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( PHPStructuredEditor.java:1033)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
at
at
at
at
at
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:439)
at
org.eclipse.php.internal.ui.actions.AddDescriptionAction.run (AddDescriptionAction.java:82)
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.core.filebuffers 4 0 2009-06-02 23:20:23.250
!MESSAGE The file does not exist.
!ENTRY org.eclipse.ui 2 2 2009-06-02 23:20:23.328
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable:
org.eclipse.ui.internal.DefaultSaveable@1fa8f74 from part:
org.eclipse.ui.internal.ErrorEditorPart@1fa8f74
at
org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at
org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 0 2009-06-02 23:20:23.359
!MESSAGE Unhandled event loop exception
!STACK 0
at
org.eclipse.php.internal.ui.actions.AddDescriptionAction.run (AddDescriptionAction.java:89)
at
at
at
at
at
at
at
at
at
at
at
at
Re: EPP PHP Error creating DocBlock [message #98050 is a reply to message #97873] Thu, 04 June 2009 13:56 Go to previous messageGo to next message
Not a problem anyone else gets then I assume.
Re: EPP PHP Error creating DocBlock [message #98167 is a reply to message #97873] Fri, 05 June 2009 15:53 Go to previous messageGo to next message
Originally posted by: mnm.criion.net
Wha is EEP?
-michael
Re: EPP PHP Error creating DocBlock [message #98182 is a reply to message #98167] Sun, 07 June 2009 16:24 Go to previous message
Michael Madsen wrote:
> Wha is EEP?
I don't know what EPP stands for - but that's what it say in the window
title and in the help about "This is the EPP PHP About Dialog."
The Installation details are:
EPP PHP Package 1.0.0 epp.package.php
Eclipse Platform 3.5.0.I20090515-1143 org.eclipse.platform.ide
EPP.PHP Feature 1.0.0.20090521-0720
org.eclipse.epp.package.feature.feature.group
or in full when fully expanded
Eclipse
Platform 3.5.0.v20090513-9fEdG1HFtGcZlCVLSVqmsTcdv4RgTlPeD org.eclipse.platform.feature.group
Eclipse Help
System 1.1.0.v20090407-7e7eFAlFEx2XZoYitqd9cLH org.eclipse.help.feature.group
Eclipse
RCP 3.5.0.v20090506-9SA-FwxFtqHA7O_ZPyAv-cGC org.eclipse.rcp.feature.group
Equinox p2
Provisioning 1.1.0.v20090507-2000b-7Z2Fb3FT0z0-3R1JdSTXilM org.eclipse.equinox.p2.user.ui.feature.group
EPP PHP
Feature 1.0.0.20090521-0720 org.eclipse.epp.package.php.feature.feature.group
Dynamic Languages Toolkit - Remote Development Support
(Incubation) 1.0.0.v20080815-1326-2--8s733K3C7315I35 org.eclipse.dltk.rse.feature.group
Dynamic Languages Toolkit - Core Frameworks
(Incubation) 1.0.0.v20081009-1644-7B8T0EAAoOQAPKjp9TOMm org.eclipse.dltk.core.feature.group
RSE
Core 3.1.0.v200905141013-7a7CDGFC7sRTNSWfNeYh1 org.eclipse.rse.core.feature.group
Eclipse CVS
Client 1.1.100.v20090514-7E79FBV9BJ99r9SHS3BF7N org.eclipse.cvs.feature.group
Eclipse XML Editors and
Tools 3.1.0.v200901260254-7H6FMUDxtkM-5NhLERH4xQocS5AL org.eclipse.wst.xml_ui.feature.feature.group
WST Common
UI 3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxPmMse org.eclipse.wst.common_ui.feature.feature.group
WST Common
Core 3.1.0.v200903021835-7B77FXTF7RZHITIwOlLrdV org.eclipse.wst.common_core.feature.feature.group
WST XML
Core 3.1.0.v200901260254-7C7OFPeF7RZHIXHnTz0Jqc0 org.eclipse.wst.xml_core.feature.feature.group
WST XML User
Documentation 3.1.0.v200808191955-50FR7AkF77f7MESDKEF org.eclipse.wst.xml_userdoc.feature.feature.group
Mylyn Bridge: Eclipse
IDE 3.2.0.I20090520-2300-e3x org.eclipse.mylyn.ide_feature.feature.group
Mylyn Bridge: Team
Support 3.2.0.I20090520-2300-e3x org.eclipse.mylyn.team_feature.feature.group
Mylyn Connector:
Bugzilla 3.2.0.I20090520-2300-e3x org.eclipse.mylyn.bugzilla_feature.feature.group
Mylyn Focused UI
(Recommended) 3.2.0.I20090520-2300-e3x org.eclipse.mylyn.context_feature.feature.group
Mylyn Task List
(Required) 3.2.0.I20090520-2300-e3x org.eclipse.mylyn_feature.feature.group
Mylyn
WikiText 1.1.0.I20090520-2300-e3x org.eclipse.mylyn.wikitext_feature.feature.group
PDT SDK
Feature 2.1.0.v20090409-0930-51-84OABBIFViJMcO41dGIbAAz-S org.eclipse.php.sdk.feature.group
PDT Runtime
Feature 2.1.0.v20090517-1334-7J78-F7RZHIXHz-Tw8R7up org.eclipse.php.feature.group
Web Developer
Tools 3.1.0.v200810090150-7I5-8h_qTa9-RvEbGYYT_g5WiDkX org.eclipse.wst.feature.group
PDT SDK
Feature 2.1.0.v20090517-1334-7J78-F7RZHIXHz-Tw8R7up org.eclipse.php.source.feature.group
Usage Data
Collector 1.1.0.R200905190432 org.eclipse.epp.usagedata.feature.feature.group
Eclipse Faceted Project
Framework 3.1.0.v200901260254-377-8s733L3B59397B org.eclipse.wst.common.fproj.feature.group
JavaScript Developer
Tools 1.1.0.v200901260254-77-FGBCcNBC-BdLkD_Pr org.eclipse.wst.jsdt.feature.feature.group
WST Server
Adapters 3.1.0.v200901260254-51DFAkF77g7GCNc org.eclipse.wst.server_adapters.feature.feature.group
WST Web
UI 3.1.0.v200901280206-7R77FSgEVw2xUFnDz0nhptdbEBKV org.eclipse.wst.web_ui.feature.feature.group
WST Server
UI 3.1.0.v200901260254-7B3DLAtJXpyxdKabDSON769F org.eclipse.wst.server_ui.feature.feature.group
WST Server
Core 3.1.0.v200901260254-30DK8s733L3B4G1227 org.eclipse.wst.server_core.feature.feature.group
WST Server User
Documentation 3.1.0.v200903071919-209L7w311A12343145 org.eclipse.wst.server_userdoc.feature.feature.group
WST Web
Core 3.1.0.v200901280206-7H77FD3AT7mhldDfJV4d-4kMBWb1 org.eclipse.wst.web_core.feature.feature.group
WST Web Services
Core 3.1.0.v200905132336-7L7RFTUFGtGcn6glz-kxdBF462A org.eclipse.wst.ws_core.feature.feature.group
WSDL 1.5
Feature 1.5.3.v200903071919-2407w311917141519 org.eclipse.wst.ws_wsdl15.feature.feature.group
WST Web Services
UI 3.1.0.v200903020650-7I6FPlEtEnGxRBtv6tT6gpKVjP3b org.eclipse.wst.ws_ui.feature.feature.group
WST Web Services User
Documentation 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK org.eclipse.wst.ws_userdoc.feature.feature.group
WST Web User
Documentation 3.1.0.v200903071919-31DF8s733J3E4D56BB org.eclipse.wst.web_userdoc.feature.feature.group
XSL
Tools 1.0.0.v200904300211-7R7T7IFHlEcfLds11nz-PO1 org.eclipse.wst.xsl.feature.feature.group
Previous Topic:Error in editor not propagating in PHP explorer tree
Next Topic:outline typing error
Current Time: Fri Jul 18 07:33:59 EDT 2025
Powered by FUDForum. Page generated in 0.06657 seconds
