Home » Archived » Test and Performance Tools Platform (TPTP) » Test case is passed in Quick mode and is failed in Standard mode
Test case is passed in Quick mode and is failed in Standard mode [message #97714] Fri, 04 May 2007 04:16 Go to next message
Originally posted by: sluhay.magenta-technology.ru
Hi All,
I would like to find out the fail reason of test case execution depending
on running mode: quick or standard. TPTP AGR version 4.3.0.
Sample
Pre-conditions: I have build.xml file with predefined ant targets as
‘build’, ‘clean’ and so on. If I open build.xnl then these targets are
presented as tree items in the Outline View.
ApplicationName
|_
build
|_
clean
|_
Note: indexes of items are not changed.
Steps:
1. I record a test case that have to run ‘build’ target as ant task.
2. Playback the test case in Quick mode -> Test case is successfully passed
3. Playback the test case in Standard mode -> Test case is failed with
“item-select” exception
Could you tell me please what is the reason?
Thanks in advance,
Olesya
Re: Test case is passed in Quick mode and is failed in Standard mode [message #97758 is a reply to message #97714] Fri, 04 May 2007 12:10 Go to previous message
Hi Olesya,
I am wondering if in your execution environment one of your preconditions is
not met which is met when you record and playback the test case in your
recording environment. This is usually the cause of such failures. Please
ensure that the execution environment gets correctly set up to execute the
test case and that the state of the execution environment directly prior to
executing the test case is identical to that of the recording environment at
the analogous time.
If you are still finding failures please attach your test suite and the
error message and I will give it a try.
Sincerely,
Liz Dancy
"Olesya" <sluhay@magenta-technology.ru> wrote in message
news:e6d6457d1453e72d85e3accbb176daa8$1@www.eclipse.org...
> Hi All,
> Sample
Previous Topic:TPTP JUnit Plugin Test Hangs
Next Topic:Access controller and integrated access controller woes and some feedback to the owners of this feat
Current Time: Sat Jul 26 09:34:44 EDT 2025
Powered by FUDForum. Page generated in 0.04299 seconds
