Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP JUnit Plugin Test Hangs
TPTP JUnit Plugin Test Hangs [message #97557] Wed, 02 May 2007 08:44 Go to next message
Originally posted by: bbrady.broad.mit.edu
I am running Eclipse 3.2.2 with jdk 1.5.0.11 and the latest TPTP install
from Callisto update (includes TPTP Test Core Plugin 4.2.3).
I have built a simple TPTP JUnit Plugin test that runs on as a
deployment on the local workbench, i.e., I just right click on the
Wizard created TPTP testuite and do Run As->Test.
The problem I have is that the first time I run the test, everything
works fine. The TPTP test launches, then executes successfully.
Subsequent runs with during the same eclipse session hang at the
lauching phase. I then have to manually kill the java and eclipse
processes and start over.
If I delete the generated test-workspace dir that was generated and
restart eclipse with the -clean switch, then the first run succeeds.
Subsequent runs will hang at launch phase.
Does anyone know what I'm doing wrong? Maybe If I can automatically
delete the test-workspace after each test it would solve the problem,
but I don't know how to do it. I tried using a TPTP deployment with an
associated TPTP workspace pointing locally and using a temp workspace or
clearing the workspace, but this gave same result: hang at launch.
Any solution ideas would be appreciated.
Bob
Re: TPTP JUnit Plugin Test Hangs [message #97567 is a reply to message #97557] Wed, 02 May 2007 08:48 Go to previous messageGo to next message
I should have added that the TPTP JUnit Plugin test runs successfully
every time when run through the jdt JUnit Plugin test launcher:
1) Right click on the Java Test File ->Run As->JUnit Plugin Test.
There are no launch hangs.
-Bob
Re: TPTP JUnit Plugin Test Hangs [message #97622 is a reply to message #97557] Thu, 03 May 2007 06:41 Go to previous messageGo to next message
Ho Bob,
Did you install and run the Agent Controller (see
http://www.eclipse.org/tptp/home/downloads/installguide/Inst allGuide43.html#install_agent_controller)?
It is not a requirement since there is a in-process Agent Controller shipped
with the TPTP workbench. However, the Agent Controller is better performing
than its integrated counterpart.
When you test execution hangs, what percentage is displayed in the
progress indictor? What OS are you running? Are there any error messages
in the Eclipse .log file?
There should be no need to manually delete any files or restart the TPTP
workbench between test executions. At first glance, this appears to be a
defect. After you have tried the Agent Controller and the problem still
exists, please open a defect (component: Test.Execution.JUnitRunner) with
the <Agent Controller installation directory>/config/servicelog.log file
attached.
Paul
"Bob Brady" <bbrady@broad.mit.edu> wrote in message
news:f1a13c$6ho$1@build.eclipse.org...
> I have built a simple TPTP JUnit Plugin test that runs on as a deployment
> on the local workbench, i.e., I just right click on the Wizard created
> The problem I have is that the first time I run the test, everything works
> fine. The TPTP test launches, then executes successfully. Subsequent runs
> with during the same eclipse session hang at the lauching phase. I then
> have to manually kill the java and eclipse processes and start over.
> delete the test-workspace after each test it would solve the problem, but
> Bob
Re: TPTP JUnit Plugin Test Hangs [message #97668 is a reply to message #97622] Thu, 03 May 2007 18:35 Go to previous messageGo to next message
Hi Paul,
Thanks for your prompt & informative response. Your post to the
previous thread was helpful too. I appreciate it.
-Bob
Yes, I installed agntctrl.win_ia32-TPTP-4.3.1: set the config & put in
PATH. I didn't run it, though, thinking the in-process one would be
good enough. The in-process one was always good enough for plain JUnit,
so it didn't occur to me.
Once I did start RAServer prior to executing the JUnit plugin tests, it
worked! Thanks!
> progress indictor?
60%, everytime.
OS: Windows XP, SP2
Intel Dual CPU @ 2.4GHz
3 GB RAM
No error messages in .log.
Re: TPTP JUnit Plugin Test Hangs [message #97729 is a reply to message #97668] Fri, 04 May 2007 08:14 Go to previous message
Great Bob.
The hang at 60% represents a problem deploying the test assets using the
Integrated Agent Controller (IAC). This is a known problem. Using the
Agent Controller will (and has:) resolve the problem. Furthermore, the IAC
has been completely refactored in 4.4 to resolve several of these hanging
issues.
Paul
news:f1do3c$k2c$1@build.eclipse.org...
> Hi Paul,
> Thanks for your prompt & informative response. Your post to the previous
> -Bob
> PATH. I didn't run it, though, thinking the in-process one would be good
> enough. The in-process one was always good enough for plain JUnit, so it
> didn't occur to me.
> worked! Thanks!
>> progress indictor?
> 60%, everytime.
>> What OS are you running? Are there any error messages in the Eclipse
>> .log file?
> OS: Windows XP, SP2
> 3 GB RAM
Previous Topic:Problem creating workbench location - Argument cannot be null
Next Topic:Test case is passed in Quick mode and is failed in Standard mode
Current Time: Sat Jul 26 11:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.27736 seconds
