HelloWorldSWT [message #975390] |
Wed, 07 November 2012 15:59  |
Following the tutorial at the point where you have to configure the project by right clicking the project, selecting Properties in the context menu and then Java Build Path and then the Project tab, the tutorial says...
"In the Java Build Path page open the Projects tab, add the org.eclipse.swt.{platform}.{os}.{arch} project, then click OK. "
Well, the add button is dimmed out, the dialog under the Projects tab will not let me type anything so what is the trick? I assume I have to know the platform, os, and arch.
os would be the operating system like "Microsoft Windows 7 64 bit", platform would perhaps be "laptop", and arch would be what? Or are they saying that the thing to be entered is "org.eclipse.swt". In any event, how do you enter that? You can not type.
Re: HelloWorldSWT [message #976347 is a reply to message #975390] |
Thu, 08 November 2012 09:06  |
> tutorial says...
This looks like you skipped the 'Import the SWT project' step from the
tutorial.
Dani
FUDForum. Page generated in 0.22839 seconds
