Home » Newcomers » Newcomers » JSP debugging
JSP debugging [message #97469] Thu, 25 August 2005 14:21 Go to next message
Originally posted by: freestuff2k4.yahoo.com
Hi, greetings.
I'd like to know what is the best way to debug JSP pages. I have Eclipse 3.1
and Tomcat 5.5.9 setup.
After searching around the Internet, my impression is that we can only set
breakpoints in the **_jsp.java file to debug it. Is it true? Is there a way
to set breakpoints on JSP page directly?
I found that all my **_jsp.java files are in work\org\apache\jsp directory.
I was able to set breakpoints in the files and debug them ONLY IF I turn on
"Build Automatically" setting. Is this setting a requirement? Or I did
something wrong?
Thanks for the help.
IG.
Re: JSP debugging [message #97538 is a reply to message #97469] Thu, 25 August 2005 22:10 Go to previous messageGo to next message
The JSP editor in the Web Tools Platform (WTP) will allow you to set
breakpoints that you can debug using both WTP's server tools and the
Sysdeo Tomcat plugin. There are many other commercial offerings
that allow for JSP debugging as well.
Sysdeo Tomcat Launcher plugin:
http://www.sysdeo.com/eclipse/tomcatplugin
Eclipse WTP: http://eclipse.org/webtools (and
http://www.eclipse.org/webtools/development/updatesite/updat esite.html)
- Nitin
Re: JSP debugging [message #97708 is a reply to message #97538] Fri, 26 August 2005 08:01 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <deltng$kjs$1@news.eclipse.org>, nitind@us.ibm.com says...
How do I get to (start) the JSP editor? I've been looking through the
menus and options, and can't find it.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: JSP debugging [message #97723 is a reply to message #97708] Fri, 26 August 2005 08:04 Go to previous messageGo to next message
In article <MPG.1d78ceb4a1ce8973989690@news.eclipse.org>,
ns_dkerber@ns_WarrenRogersAssociates.com says...
Let me clarify: I guess I've been using the jsp editor, but how do I
get it to stop at breakpoints set in jsp pages? I've never managed to
do that.
Re: JSP debugging [message #106996 is a reply to message #97723] Mon, 03 October 2005 22:21 Go to previous message
> do that.
Basically you have to run Tomcat within Eclipse. WTP has Server
Tools to help you do this by first defining a Runtime within the
Server Preferences and then by debugging an instance of that server
using the Servers view.
- Nitin
Previous Topic:Eclipse does not like taglib tag in web.xml
Next Topic:WST Plugin: HTML Syntax Highlighting
Current Time: Tue Jul 22 03:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.12722 seconds
