Home » Eclipse Projects » Virgo » Exception when trying to use spring namespace handler in virgo
Exception when trying to use spring namespace handler in virgo [message #946856] Tue, 16 October 2012 11:10 Go to next message
I have an OSGi bundle that extends the blueprint tags.I used to deploy it on equinox with spring framework and it works .
but deploying the same bundle on virgo doesn't work.
I got this exception :
<AG0000E> Application context creation failure for bundle 'com.att.tlv.bundles.svc-bundle' version '1.0.0'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'service-lifecycle-module-id': Initialization of bean failed; nested exception is org.springframework.beans.ConversionNotSupportedException: Failed to convert value of type 'org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer' to required type 'org.osgi.service.blueprint.container.BlueprintContainer'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:580)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.springframework.beans.ConversionNotSupportedException: Failed to convert value of type 'org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer' to required type 'org.osgi.service.blueprint.container.BlueprintContainer'; nested exception is java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.SimpleTypeConverter.convertIfNecessary(SimpleTypeConverter.java:58)
at org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintConverterService.convert(SpringBlueprintConverterService.java:136)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:141)
at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:447)
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:499)
at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:493)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1371)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1086)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
... 16 common frames omitted
Caused by: java.lang.IllegalStateException: Cannot convert value of type [org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer] to required type [org.osgi.service.blueprint.container.BlueprintContainer]: no matching editors or conversion strategy found
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:231)
at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:93)
at org.springframework.beans.SimpleTypeConverter.convertIfNecessary(SimpleTypeConverter.java:49)
... 25 common frames omitted
Any Idea?
Yousef,
[Updated on: Sun, 21 October 2012 05:45] by Moderator
Re: Exception when trying to use spring namespace handler in virgo [message #952260 is a reply to message #946856] Sun, 21 October 2012 05:48 Go to previous messageGo to next message
can this be caused because both user and kernel region have
org.eclipse.gemini.blueprint.core_1.0.0.RELEASE
org.eclipse.gemini.blueprint.extender_1.0.0.RELEASE
org.eclipse.gemini.blueprint.io_1.0.0.RELEASE
loaded?
and this error is actually a class cast exception ??
how could I affect the jars loaded in kernel?
Yousef
Re: Exception when trying to use spring namespace handler in virgo [message #968246 is a reply to message #952260] Fri, 02 November 2012 06:07 Go to previous messageGo to next message
It's normal to have two copies of Gemini Blueprint in the kernel and user regions, respectively, so that shouldn't be the root cause.
When you say your bundle "extends the blueprint tags" what do you mean? Are you just using Blueprint "normally" or are you really adding to the Blueprint implementation, in which case you should be adding to the one in the user region.
Re: Exception when trying to use spring namespace handler in virgo [message #974734 is a reply to message #946856] Wed, 07 November 2012 04:30 Go to previous messageGo to next message
doing some debugs I found that the blueprint container I got by injection is the one loaded by kernel, (have different class loader). casting failed in class cast exception.
moving to virgo nano web solve this problem for me but I am missing a lot of the tomcat server features,
Any idea?
Yousef
Re: Exception when trying to use spring namespace handler in virgo [message #974778 is a reply to message #974734] Wed, 07 November 2012 05:09 Go to previous messageGo to next message
Yousef Fadila wrote on Wed, 07 November 2012 09:30
That's really strange. Please could you raise a bug and attach a bundle I could use to reproduce that behaviour locally? On the face of it, it looks like a Virgo bug, so I'd like to dig into the issue to see if that's really the case.
Any idea?
Yousef
Re: Exception when trying to use spring namespace handler in virgo [message #974919 is a reply to message #974778] Wed, 07 November 2012 07:46 Go to previous messageGo to next message
I post a sample app in other post, here is it again
http://host4il.com/virgo/blueprint-test.zip
all what the app done is injecting the blueprint container,
maybe it worth you test it locally before raising a bug If I am the only one complain about this.
hope to hear from you soon.
Re: Exception when trying to use spring namespace handler in virgo [message #975116 is a reply to message #974919] Wed, 07 November 2012 11:08 Go to previous messageGo to next message
After adding the EBR Maven repos to the pom.xml, I built your test bundle, started a fresh Virgo kernel, dropped the bundle in pickup and it started fine. serviceability/logs/log.log contains the bundle's output:
[2012-11-07 16:05:29.572] INFO  region-dm-1                  System.out                                                        bpc = org.eclipse.gemini.blueprint.blueprint.container.SpringBlueprintContainer
[2012-11-07 16:05:29.572] INFO  region-dm-1                  System.out                                                        Beannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
So the question now is: what are you doing differently?
Re: Exception when trying to use spring namespace handler in virgo [message #986421 is a reply to message #975116] Tue, 20 November 2012 06:24 Go to previous message
Thanks for your efforts
This works for me too.. sorry I share with you a wrong test file. I will share another one that actually uses the blueprint container which works for me in equinox and failed in Virgo.
Previous Topic:cipango on virgo jetty server
Next Topic:Write log message in a single file - virgo - common - logging
Current Time: Sat Jul 26 12:56:07 EDT 2025
Powered by FUDForum. Page generated in 0.06536 seconds
