Home » Eclipse Projects » Virgo » Books you should read about OSGi
Books you should read about OSGi [message #960961] Sat, 27 October 2012 19:45 Go to next message
Not sure this had a place here but still.
Since more and more people are attracted by OSGi I recommend some great books :
- Modular Java Creating Flexible Applications with OSGi and Spring (this one is great to learn about OSGi, especially since you start from scratch, then move on to something with spring)
- Pro Spring Dynamic Modules for OSGi Service Platforms (Spring DM, old blueprint)
- Java Application Architecture Modularity Patterns with Examples Using OSGi (Probably the best one for good understanding on "how to do stuff" properly and with efficiency, there is even a bit of glyn into this book Very Happy)
[Updated on: Mon, 29 October 2012 05:25] by Moderator
Re: Books you should read about OSGi [message #968323 is a reply to message #960961] Fri, 02 November 2012 07:21 Go to previous messageGo to next message
Thanks Mastah. Feel free to put that list on the Virgo wiki so others can add to it.
Re: Books you should read about OSGi [message #969066 is a reply to message #968323] Fri, 02 November 2012 20:20 Go to previous messageGo to next message
Under which sub category of the wiki should I put those informations ?
Re: Books you should read about OSGi [message #972082 is a reply to message #969066] Mon, 05 November 2012 05:41 Go to previous messageGo to next message
I created a suitable spot here http://wiki.eclipse.org/Virgo/Concepts#OSGi which we can then link to from whereever is appropriate.
Re: Books you should read about OSGi [message #974909 is a reply to message #960961] Wed, 07 November 2012 07:37 Go to previous messageGo to next message
IMHO, OSGI in depth is one of the must read if you want to know OSGI mecanisms
Re: Books you should read about OSGi [message #976146 is a reply to message #960961] Thu, 08 November 2012 05:53 Go to previous message
Glyn, I've updated the section. Feel free to edit if you feel the need.
Previous Topic:Deploy WAR to VTS
Next Topic:Monitoring Directories Using Spring Integration
Current Time: Sun Jul 20 23:14:38 EDT 2025
Powered by FUDForum. Page generated in 0.65638 seconds
