Home » Archived » BIRT » Able to Preview Data when making Data Set but unable to connect using BIRT Viewr
Able to Preview Data when making Data Set but unable to connect using BIRT Viewr [message #97444] Thu, 08 December 2005 11:17 Go to next message
I am able to Preview Data when making Data Set but unable to connect using
BIRT Viewer. I setup my Data Source and Set perfectly and it previews
fine in the Data Set Preview Tab. But after I start to make my report and
then click on the Preview button at the top of Eclipse to pull up the BIRT
Web Viewer I get the following error in the Web Viewer:
There are errors on the report page:
- There are error(s) in Table:null
Error0 : odaconsumer.CannotOpenConnection(1 time)detail: Cannot open the
connection for the driver (org.eclipse.birt.report.data.oda.jdbc).Cannot
load JDBC Driver class: [com.mysql.jdbc.Driver]. Cannot load JDBC Driver
I am following the tutorial
here....http://dev.mysql.com/tech-resources/articles/using-b irt/....I am
running Windows XP connecting remotely to my MySQL DB....any ideas?
Re: Able to Preview Data when making Data Set but unable to connect using BIRT V [message #97658 is a reply to message #97444] Thu, 08 December 2005 14:48 Go to previous message
Found the answer....just needed to put a copy of the mysql jdbc driver in:
C:\eclipse\plugins\org.eclipse.birt.report.viewer_1.0.1\birt \plugins\org.eclipse.birt.report.data.oda.jdbc\drivers
Previous Topic:M3 Runtime errors
Next Topic:Flat file data source and relative path
Current Time: Wed Sep 03 18:00:37 EDT 2025
Powered by FUDForum. Page generated in 0.05119 seconds
