Home » Eclipse Projects » Equinox » Jetty Configuration
Jetty Configuration [message #97106] Tue, 11 September 2007 15:19 Go to next message
Originally posted by: irbull.cs.uvic.ca
Does anyone have any pointers for howto configure Jetty running as an
Equinox bundle? In particular, I would like to setup something like
apache's document index (that is, when I navigate to a directory I can
get it to automatically use index.html).
Can these be configured using an external file (configuration.xml or
something) or do they have to be coded against the Jetty API (or using
extension points?).
Any help is appreciated.
Ian
Re: Jetty Configuration [message #97122 is a reply to message #97106] Tue, 11 September 2007 19:14 Go to previous messageGo to next message
Originally posted by: kitplummer.gmail.com
Have you seen this:
http://www.eclipse.org/equinox/server/http_in_equinox.php
I've not been able to get 6.1.5 to work...complains about javax.servlet
which is a bit strange. But, I have this stuff working:
http://www.eclipse.org/equinox/server/http_writing_applicati on.php
Both the static page, and the servlet.
Kit
On 9/11/07 12:19 PM, in article fc6po0$t26$1@build.eclipse.org, "Ian Bull"
> extension points?).
> Cheers,
> Ian
Re: Jetty Configuration [message #97135 is a reply to message #97106] Tue, 11 September 2007 19:16 Go to previous messageGo to next message
Oh yeh, I also was going to tell that most of the Jetty config can be passed
as VM args: -Dorg.eclipse.equinox.http.jetty.http.port=8080
> extension points?).
> Cheers,
> Ian
Re: Jetty Configuration [message #97424 is a reply to message #97106] Thu, 13 September 2007 21:29 Go to previous messageGo to next message
Hi Ian,
In addition to Kit's suggestions you might want to take a look at
"org.eclipse.equinox.http.jetty.JettyConfigurator"
This lets you create you programmatically configure your own instance of the
Http Service based on Jetty. This is the approach used by UA/Help and WTP.
The Http Service unfortunately does not provide direct support for mapping
requests for a directory to "index.html".
What you can do is register a servlet at the directory path and then either
requestDispatcher.forward the request or something similar.
There's a bug open on that particular topic also --
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193202
HTH
-Simon
"Ian Bull" <irbull@cs.uvic.ca> wrote in message
news:fc6po0$t26$1@build.eclipse.org...
> apache's document index (that is, when I navigate to a directory I can get
> extension points?).
> Cheers,
> Ian
Re: Jetty Configuration [message #97529 is a reply to message #97424] Mon, 17 September 2007 14:48 Go to previous message
Thanks Kit and Simon,
I was able to map a servlet a "/", and then forward to index.html. The
problem is, the forward is picked up by the servlet again (since
/index.html get picked up by "/"), so I get an infinite number of
redirects. Is there a way to forward to a resource alias from a serlvet
programmatically (without forwarding to any servlet aliases?
Thanks again,
Ian
Simon Kaegi wrote:
> Hi Ian,
> HTH
> -Simon
>> extension points?).
>> Cheers,
>> Ian
Previous Topic:Extension-Registry as OSGi Services
Next Topic:OSGi Plugin Deployment
Current Time: Sat Jul 26 04:37:09 EDT 2025
Powered by FUDForum. Page generated in 0.06210 seconds
