Home » Archived » Buckminster » create a site.p2 from the target platform
create a site.p2 from the target platform [message #969943] Sat, 03 November 2012 13:57 Go to next message
I was trying to use the technique shown here
https://nirmalsasidharan.wordpress.com/2010/10/09/provisioning-your-target-platform-as-local-p2-site/
to create a site.p2 (with Buckminster of course) from a target
definition file.
Basically the target definition is
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="juno" sequenceNumber="1">
<locations>
<location includeAllPlatforms="true" includeConfigurePhase="true"
includeMode="slicer" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.equinox.executable.feature.group"
version="3.6.0.v20120522-1813-7P7OG2BFLWUl7UmbVUO9iCm"/>
<unit id="org.eclipse.rcp.sdk.id" version="4.2.1.M20120914-1800"/>
<unit id="org.eclipse.emf.ecoretools.sdk.feature.group"
version="1.1.0.201205150811"/>
<unit id="org.eclipse.emf.sdk.feature.group"
version="2.8.1.v20120917-0436"/>
<repository location="http://download.eclipse.org/releases/juno"/>
</location>
</locations>
</target>
and then I create a target.feature project initialized with all the
plugins available in the target.
However, when I run site.p2 on this target.feature project it soon
complains about
No component named org.apache.ant:osgi.bundle/[1.7.0,2.0.0) is known to
Buckminster
which actually is not in the target platform (and probably needed by
some of the bundles in the target platform?)
so I was wondering: is there a way to create a p2 site from a target
definition with Buckminster?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: create a site.p2 from the target platform [message #970718 is a reply to message #969943] Sun, 04 November 2012 03:26 Go to previous messageGo to next message
Hi Lorenzo,
> complains about
> Buckminster
The simplest way is probably to let Buckminster create the target
platform using a normal resolve/materialize based on the target feature.
That way, the TP will contain everything that is needed and you won't
even need the target platform definition.
If you for some reason have to use the target definition, then
Buckminster must be able to find the missing pieces somewhere and
complement the TP. You can achieve this by adding an empty directory
container to the TP and then run a resolve/materialize on the target
feature. Buckminster will then use what's already in the TP and add
what's missing to the added container.
- thomas
Re: create a site.p2 from the target platform [message #970758 is a reply to message #970718] Sun, 04 November 2012 04:10 Go to previous messageGo to next message
On 11/04/2012 09:26 AM, Thomas Hallgren wrote:
> Hi Lorenzo,
>> complains about
>> Buckminster
Hi Thomas
Do you mean to have a TP defined through a cspec, cquery and rmap
instead of defining a .target file?
or something else?
thanks in advance
Lorenzo
> - thomas
Re: create a site.p2 from the target platform [message #971273 is a reply to message #970758] Sun, 04 November 2012 14:06 Go to previous messageGo to next message
Probably I understood what you meant... I shared an example here
https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster
cheers
Lorenzo
Re: create a site.p2 from the target platform [message #971893 is a reply to message #971273] Mon, 05 November 2012 02:32 Go to previous messageGo to next message
You did indeed. Great example!
- thomas
> cheers
> Lorenzo
Re: create a site.p2 from the target platform [message #972157 is a reply to message #971893] Mon, 05 November 2012 06:53 Go to previous messageGo to next message
Thanks!
I have a small problem when I try to build the p2 with Jenkins (I don't
have these problems when building in the IDE): although the platform is
resolved correctly with
resolve 'bucky.example.rcpemf.target/target-platform.cquery'
I get these errors when I try to resolve the target.site feature:
ERROR [0002] : No suitable provider for component
org.eclipse.equinox.launcher.gtk.linux.ppc64:osgi.bundle was found in
resourceMap
file:/usr/share/tomcat6/.jenkins/workspace/Buckminster-Target-p2/bucky.example.rcpemf.target/project.rmap
ERROR [0002] : Unable to find a searchPath for
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle was found in
resourceMap
where project.rmap is simply
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
<rm:property key="projects.location" value="${workspace.root}"/>
<rm:locator pattern="^bucky.example.rcpemf(?:\..+)?$"
searchPathRef="project"/>
<rm:searchPath name="project">
<rm:provider
componentTypes="eclipse.feature,osgi.bundle,buckminster"
readerType="local" mutable="false">
<rm:property key="buckminster.mutable" value="false"/>
<rm:uri format="{0}/{1}">
<bc:propertyRef key="projects.location"/>
<bc:propertyRef key="buckminster.component"/>
</rm:uri>
</rm:provider>
</rm:searchPath>
</rm:rmap>
the problems are due to the equinox.launcher fragments (I think they are
fragments)...
these fragments are included in the target.site/feature.xml
they are in the target platform, so why can't they be resolved?
I probably remove these fragments from the feature.xml, but I was
wondering why they cannot be resolved...
thanks in advance
Lorenzo
Re: create a site.p2 from the target platform [message #972213 is a reply to message #972157] Mon, 05 November 2012 07:48 Go to previous messageGo to next message
> fragments)...
Not sure why this happens. Do you create the original TP from Juno or
from the Eclipse platfrom repository? I ask because IIRC some of the
launcher fragments are not present in Juno.
- thomas
Re: create a site.p2 from the target platform [message #972242 is a reply to message #972213] Mon, 05 November 2012 08:15 Go to previous messageGo to next message
>> fragments)...
Hi Thomas
I'm using
(see
https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster/blob/master/bucky.example.rcpemf.target/target-platform.rmap)
however, the strange thing is that in the target platform generated by
the jenkins job the fragments are there, e.g.,
ls
..buckminster/tp/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20120522-1813/META-INF/
eclipse.inf ECLIPSE_.RSA ECLIPSE_.SF MANIFEST.MF
but they cannot be resolved when performing site.p2 on the feature.xml...
most of all, I'm experiencing another critical problem:
I was using the cquery, rmap mechanism for defining the target platform
because, from what I understand, it allows me to have a target for
multiple environments, and to have automatically all the required
software installed (which is something that with a .target file
definition cannot co-exist).
In the IDE this works! But in Jenkins the target platform resolution
with the .cquery does not contain required software!
For instance, emf.sdk seems to require (among the others) org.apache.ant
and org.eclipse.jdt.annotation (there are only few of them). In the IDE
when I run the materialization these additional plugins are
materialized... in Jenkins they are not :(
In the IDE, I created an empty target platform manually that contains
one single and empty directory. Set this target platform active.
A subsequent resolution/materialization will use that platform, in order
to avoid the fact that "An automatically created target platform is
based on the configuration of the currently running Eclipse instance."
So now I'm kind of lost... headless target resolution behaves differently?
In Jenkins I'm performing target platform resolution as follows
is that correct?
thanks in advance
Lorenzo
Re: create a site.p2 from the target platform [message #972325 is a reply to message #972242] Mon, 05 November 2012 09:33 Go to previous messageGo to next message
FWIW -- I run into a similar issue when building off of Juno. I believe
the missing launcher fragments (for some odd architectures like ppc) can
be found in http://download.eclipse.org/eclipse/updates/4.2. These
problems go away when I add that to my rmap file after Juno.
>>> fragments)...
> Hi Thomas
> I'm using
> (see
> ls
> is that correct?
> thanks in advance
> Lorenzo
Re: create a site.p2 from the target platform [message #972330 is a reply to message #972325] Mon, 05 November 2012 09:38 Go to previous messageGo to next message
Thanks Peter, could you please share the rmap?
However, my problem might not be related to this, since in the IDE it
works, and, as I said, that fragments seem to be in the generated target
platform...
cheers
Lorenzo
>>>> are
>>>> fragments)...
>> Hi Thomas
>> I'm using
>> (see
>> ls
>> differently?
>> is that correct?
>> thanks in advance
>> Lorenzo
Re: create a site.p2 from the target platform [message #972579 is a reply to message #972330] Mon, 05 November 2012 13:41 Go to previous messageGo to next message
I am a newbie, so I might say something very wrong here, but do you have the famous delta pack in your materialized target?
Because it seems it cannot find org.eclipse.equinox.launcher.gtk.linux.ppc64:osgi.bundle (among others I guess),
that is part of the linux equinox launcher. Is your IDE a linux ide as well?
[Updated on: Mon, 05 November 2012 15:51] by Moderator
Re: create a site.p2 from the target platform [message #972737 is a reply to message #972579] Mon, 05 November 2012 16:33 Go to previous messageGo to next message
Hi Andrea
don't worry: I consider myself a bucky newbie as well :)
On 11/05/2012 07:41 PM, Andrea Richiardi wrote:
> I am a newbie, so I might say something vrey wrong, but, do you have the
the delta pack is not needed anymore from what I understand, as long as
you have a target platform with launchers for all environments...
> guess),
> that is part of the linux launcher. Is your IDE a linux ide as well?
if you see my previous post: in the IDE it all works fine since the
target platform materialization materializes all the launchers...
in Jenkins: it is exactly as in the IDE: the target platform
materialization materializes all the launchers, but then, when resolving
the feature.xml, which includes all the fragments for launchers, it is
not able to find the fragment bundles, even though they are in the
target platform... that's why it is strange...
in Jenkins it cannot find ANY launcher fragment... even though they're
all in the materialized target platform...
cheers
Lorenzo
Re: create a site.p2 from the target platform [message #973621 is a reply to message #972737] Tue, 06 November 2012 08:37 Go to previous messageGo to next message
Do you by any chance have some setting for target.os, target.ws, and
target.arch in your IDE preferences? Buckminster will look at
"Preferences" -> "Run/Debug" -> "String Substitution".
Are you running Buckminster twice? Once to materialize the target
platform and then again to build using that platform? Or is it all in
one go? I.e. are you running using a Buckminster script file or are you
invoking Buckminster several times from Jenkins?
- thomas
Re: create a site.p2 from the target platform [message #973711 is a reply to message #972330] Tue, 06 November 2012 10:06 Go to previous messageGo to next message
The relevant parts are:
<rm:locator searchPathRef="juno" failOnError="false"/>
<rm:locator searchPathRef="eclipse"/>
<rm:searchPath name="juno">
<rm:provider componentTypes="osgi.bundle,eclipse.feature"
readerType="p2">
<rm:uri format="http://download.eclipse.org/releases/juno"/>
</rm:provider>
</rm:searchPath>
<rm:searchPath name="eclipse">
readerType="p2">
<rm:uri format="http://download.eclipse.org/eclipse/updates/4.2"/>
</rm:provider>
</rm:searchPath>
> platform...
> cheers
> Lorenzo
>>>>> are
>>>>> fragments)...
>>> Hi Thomas
>>> I'm using
>>> (see
>>> ls
>>> differently?
>>> is that correct?
>>> thanks in advance
>>> Lorenzo
Re: create a site.p2 from the target platform [message #973940 is a reply to message #973621] Tue, 06 November 2012 13:45 Go to previous messageGo to next message
I think I found my main (stupid) mistake in headless (Jenkins)
build scenario:
I was materializing (through a cquery) the target platform (which is in
a separate project), and then I was performing site.p2 on the
target.site feature (which is another project). The target.site feature
was correctly bound to the workspace (through the rmap) but it had not
been actually resolved/materialized (in the IDE I didn't need this step
of course) :)
if I materialize also the target.site feature (with another cquery)
everything works :) (modulo materializing and performing into two
Jenkins build step, otherwise you get the problem described here
http://www.eclipse.org/forums/index.php/m/767528/ for a particular
conflicting bundle).
I've updated
https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster where I
also have another feature (target.mirror.site) where besides all the
bundles I include also the features of the target platform, so that I
end up with a site.p2 with all the IU of the target platform.
Stay tuned for a blog post where I'll try to describe all of this.
Bucky rocks! :)
cheers
Lorenzo
> - thomas
Re: create a site.p2 from the target platform [message #973963 is a reply to message #973940] Tue, 06 November 2012 14:11 Go to previous messageGo to next message
Nicely done!
But, a newbie question:
If my feature (plugin) has dependencies, these dependencies are found but they have dependencies themselves.
Where are those taken from? The rmap? The TP? Do I have to materialize them in order to build the first plugin?
My guess would be I don't, but I keep having errors about CSpec missing even if the plugin is actually in the right place and I am getting confused Smile
Re: create a site.p2 from the target platform [message #975269 is a reply to message #973940] Wed, 07 November 2012 13:47 Go to previous messageGo to next message
As promised, here's the blog post
http://www.lorenzobettini.it/2012/11/materializing-and-provisioning-your-target-platform-as-local-p2-site-with-buckminster/
I'd really like to have feedback, hoping I got things right :)
thanks in advance
Lorenzo
Re: create a site.p2 from the target platform [message #975324 is a reply to message #973963] Wed, 07 November 2012 14:49 Go to previous messageGo to next message
On 11/06/2012 08:11 PM, Andrea Richiardi wrote:
> Nicely done!
> confused :)
Are you using the IDE or headlessly?
From what I know, you must materialize the TP and then you have to
materialize the main plugin (usually this is the main feature for your
project) so that all its dependencies are also materialized, using the
materialize TP and possibly by using the rmap (if it needs further
dependencies).
see also this brand new post :)
cheers
Lorenzo
Re: create a site.p2 from the target platform [message #976529 is a reply to message #975324] Thu, 08 November 2012 11:53 Go to previous messageGo to next message
Headless, and yes, after the "matching" phase, it tries to download the dependencies before materializing the plugin (just one in my case).
I am having a problem though with a p2 repository, see other post.
Good job with your article!
Re: create a site.p2 from the target platform [message #984679 is a reply to message #976529] Wed, 14 November 2012 17:24 Go to previous messageGo to next message
Another quick question, where is the headless buckminster materializing the tp?
Because in the log I see:
Processing changes in target platform locations...
INFO:  Resetting target platform Buckminster Default TP
Done processing changes in target platform locations
Project com.test.ui now has dynamic dependencies to com.test.ui
INFO:  Import complete.
Doing full workspace refresh
Waiting for jobs to end
But I can't, for example run:
buckminster perform com.test.ui#whatever
Receiving:
No component named com.test.ui is known to Buckminster
Why???
Re: create a site.p2 from the target platform [message #985285 is a reply to message #984679] Thu, 15 November 2012 04:23 Go to previous messageGo to next message
> the tp?
Buckminster will materialize into the currently active TP. Unless you
specify what TP that will be, it will be a copy of the Runtime TP with
an additional folder that resides under the .buckminster project.
I'd recommend that you do the following to control the TP in you IDE.
1. Create a general project named TP.
2. Create a new PDE target platform (under pde preferences) named TP
where you add one location of type Directory. This directory should be
${workspace_loc:TP} (i.e. the project you just created).
3. Ensure that this new target platform is active.
Now run your resolve/materialize. Buckminster will populate the new TP.
From the command line you can use:
addtargetplatform -N TP -A <path to a directory>
to add an active target platform.
HTH,
- thomas
> Receiving:
> Why???
Re: create a site.p2 from the target platform [message #986227 is a reply to message #985285] Mon, 19 November 2012 09:20 Go to previous messageGo to next message
Thanks for answering,
the fact is that everything is working under the IDE. I have problems with the headless materialization. Basically I can't see any .buckminster folder, anywhere...
Probably, doing
will generate the folder that the headless buckminster can fill...I am about to try.
Re: create a site.p2 from the target platform [message #986237 is a reply to message #986227] Mon, 19 November 2012 10:00 Go to previous messageGo to next message
Ok, it worked, it created a sub-folder that, on materializing, has been filled by all the dependencies...not the actual plugin though.
I'd better check the mspec again (I am materializing the cquery....is the mspec considered here?).
Re: create a site.p2 from the target platform [message #986241 is a reply to message #986237] Mon, 19 November 2012 10:15 Go to previous messageGo to next message
Ok, sorry for bombarding, but I found out that my source code is somehow materialized into C:\Users\*myuser*\workspace but the jar plugin is not actually generated. Can I change the workspace location or, better, disable the source materialization (I will just need to build it using a site.p2 action) ?
Re: create a site.p2 from the target platform [message #986246 is a reply to message #986241] Mon, 19 November 2012 10:53 Go to previous messageGo to next message
Ok, I am slowly moving forward. Now, even if the workspace is actually filled up with unwanted source code, I can still perform the action site.p2.
I now receive the error:
c:\buckminster>buckminster -L DEBUG perform com.test.custom#site.p2
The project was not built since its build path is incomplete. Cannot find the cl
ass file for org.eclipse.swt.events.HelpListener. Fix the build path then try bu
ilding this project
I can distinctly see that there is no org.eclipse.swt.win32.* in my TP.
Aren't all the needed plugin supposed to be there?
I think I am missing something then...
Re: create a site.p2 from the target platform [message #986264 is a reply to message #986246] Mon, 19 November 2012 11:40 Go to previous messageGo to next message
To complete the process...forget about what I wrote before...I was just missing the correct path for my external and custom target platform.
A little, new, problem I get now is:
Access restriction: The type Display is not accessible due to restriction on req
uired library C:\p2_biomet\tc_platform\plugins\org.eclipse.swt.win32.win32.x86_6
4_3.5.0.v3550b.jar
Just using the headless buckminster, it works fine if I invoke the action withing the IDE.
Re: create a site.p2 from the target platform [message #986267 is a reply to message #986246] Mon, 19 November 2012 11:43 Go to previous messageGo to next message
Ok, now, even in the IDE I receive:
ERROR: org.eclipse.core.runtime.CoreException: C:\eclipse\configuration\org.eclipse.osgi\bundles\302\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:214: C:\Users\arichiardi\Desktop\{fs:action.requirements} does not exist.
	at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
	at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
	at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
	at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
	at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
	at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
	at org.eclipse.buckminster.ui.InvokeActionJob.runInWorkspace(InvokeActionJob.java:67)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: C:\eclipse\configuration\org.eclipse.osgi\bundles\302\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:214: C:\Users\arichiardi\Desktop\{fs:action.requirements} does not exist.
	at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
	at org.apache.tools.ant.taskdefs.Copy.execute(Copy.java:489)
	at org.eclipse.buckminster.ant.taskdefs.Copy.execute(Copy.java:42)
	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
	at org.apache.tools.ant.Task.perform(Task.java:348)
	at org.apache.tools.ant.Target.execute(Target.java:392)
	at org.apache.tools.ant.Target.performTasks(Target.java:413)
	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
	at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
	at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
	at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
	at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
	... 9 more
[Updated on: Mon, 19 November 2012 12:19] by Moderator
Re: create a site.p2 from the target platform [message #987456 is a reply to message #969943] Mon, 26 November 2012 11:58 Go to previous messageGo to next message
Anyone has ever seen this error?
From what I found online, it is an Eclipse PDE building error...
Re: create a site.p2 from the target platform [message #987606 is a reply to message #987456] Tue, 27 November 2012 05:14 Go to previous messageGo to next message
which error?
Re: create a site.p2 from the target platform [message #987737 is a reply to message #969943] Tue, 27 November 2012 15:24 Go to previous message
The one two posts above, the first (shorter trace) is with the headless Buckminster, the second (longer trace) is if I try to build calling the create.product withing the Eclipse IDE.
Previous Topic:Dependency version mismatch when materializing a plugin
Next Topic:sourceLevel=DESIRE doesn't fetch component when already present in target platform
Current Time: Sun Jul 20 02:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.10391 seconds
