Home » Modeling » EMF » ecorediag class instance
ecorediag class instance [message #973576] Tue, 06 November 2012 07:59 Go to next message
Hi all,
I'm only in my first footsteps so please bear with me.
I have project with some special features.
1. Lets say in the created model I have two classes: Container and TypeA.
Now TypeA object have relation between one another (specifically they can point one to another-unidirectional pointing).
Container has all TypeA objects in a list and also I need him to have two "special" TypeA instances; they are special because they dont point to other TypeA (empty list or even no list property) and some of the other TypeA properties are Constant.
How would you suggest me to model this? is it possible?
Another problem, lets say I have a model and an infrastructure that works with that model, can I bring object from that model into mine without have to bring the entire model scheme?
Thank you
Eyal
Re: ecorediag class instance [message #973616 is a reply to message #973576] Tue, 06 November 2012 08:33 Go to previous message
Eyal,
Comments below.
On 06/11/2012 1:59 PM, Eyal Heinemann wrote:
> Hi all,
> TypeA. Now TypeA object have relation between one another
Certainly there is no way in Ecore to model constants. With respect to
TypeA, you might define a base interface with only operations and define
several subclasses with features whose accessors override those
operations and ones with no overrides for which you manually modify the
Impl class them to return constants. It's not clear if you want the
special instances to be in a list. Perhaps you put them in some
transient derived read-only features that you populate automatically
ContainerImpl's constructor
You can defined wrapper EDataTypes for existing classes (much like
Ecore.ecore does for EDate).
> Thank you
> Eyal
Previous Topic:Is it not possibile to use instance of eclass as map key?
Next Topic:Creating an own form based editor
Current Time: Fri Jul 25 23:11:34 EDT 2025
Powered by FUDForum. Page generated in 1.11505 seconds
