Home » Archived » BIRT » Embedded fonts not found in BIRT 3.7.1
Embedded fonts not found in BIRT 3.7.1 [message #973236] Tue, 06 November 2012 01:59 Go to next message
we use BIRT 3.7.1 integrated in our web applicaion using the POJO method
and somehow the font loading from the "fonts" subdirectory of the
org.eclipse.birt.report.engine bundle doesn't work anymore. It worked in
all BIRT version before. We supply two fonts in the fonts directory to
be sure to have these fonts always available no matter which system
fonts exist.
The problem seems to be in the method "getEmbededFontPath" of class
org.eclipse.birt.report.engine.layout.pdf.font.FontMappingManagerFactory:
The call to
Platform.getBundle("org.eclipse.birt.report.engine");
returns null, so that not font directory is set and our font is not found.
Any ideas how to resolve that without too much hassle? We cannot install
our fonts on all platforms we support, so the fonts subdir was always a
convenient way.
Re: Embedded fonts not found in BIRT 3.7.1 [message #973247 is a reply to message #973236] Tue, 06 November 2012 02:06 Go to previous messageGo to next message
Sorry, bundle is "org.eclipse.birt.report.engine.fonts".
Am 06.11.2012 07:59, schrieb Juergen Schwarz:
> fonts exist.
> The call to
> convenient way.
Re: Embedded fonts not found in BIRT 3.7.1 [message #975766 is a reply to message #973247] Wed, 07 November 2012 23:11 Go to previous message
You might take a look at this thread: http://www.eclipse.org/forums/index.php/m/648561/
It appears that the getBundle() call is a platform call that may only work with OSGi. This may be why it doesn't work with the POJO runtime.
You could also look at this thread: http://www.eclipse.org/forums/index.php/m/893803/
It talks about dealing with fonts with the POJO and OSGi runtimes.
Previous Topic:Page Size ignored when exporting to PDF
Next Topic:Exception while using Birt Joint Dataset
Current Time: Wed Jul 23 12:05:58 EDT 2025
Powered by FUDForum. Page generated in 0.10455 seconds
