Re: Is it not possibile to use instance of eclass as map key? [message #973227 is a reply to message #972651] |
Tue, 06 November 2012 01:46   |
Christian,
Actually you can of course have EObjects as the keys of a map, but you
can't (i.e., it's not supported to) override hashCode or equals. As
such x.equals(y) == (x == y) is always true for EObjects. So the John's
statement "they're the same object with different hashcode" is a
contradiction, i.e., if the hash codes are different, they're definitely
not the same object. Note that using mutable objects as keys in a map
is dangerous because any mutations of the object that affect the
hashCode will definitely corrupt the map.
On 05/11/2012 9:01 PM, Christian W. Damus wrote:
> Hi, John,
> EObjects use object identity for equals() comparison. The short
> answer is "no". If you need to put them in a map, you can use the
> IdentityHashMap or perhaps you can create a custom map that uses
> EcoreUtil::equals(EObject, EObject) for comparison if you really need
> structural equivalence.
> Cheers,
> Christian
> On 2012-11-05 18:52:15 +0000, John M. said:
>> Hello,
>> I am trying to use an eclass instance as key of a map.
>> But it is the same object with a different hashcode. Is it not
>> possible to do that?
Re: Is it not possibile to use instance of eclass as map key? [message #973587 is a reply to message #973227] |
Tue, 06 November 2012 08:04  |
Hi, Ed,
Yes, it's because of the mutability of EObjects that I suggested using
them as keys in a map is not practical. (I assume that the
impossibility of a thing the OP already actually did was not in
question :-)
I suppose if you don't override the equals() and hashCode() methods,
then the behaviour of the map devolves to IdentityHashMap-like, but one
is often encouraged to implement these methods in things that are map
keys.
Thanks for the clarification.
cW
On 2012-11-06 06:46:55 +0000, Ed Merks said:
> Christian,
> John's statement "they're the same object with different hashcode" is a
> definitely not the same object. Note that using mutable objects as
> keys in a map is dangerous because any mutations of the object that
> affect the hashCode will definitely corrupt the map.
>> Hi, John,
>> EObjects use object identity for equals() comparison. The short answer
>> Cheers,
>> Christian
>>> Hello,
>>> But it is the same object with a different hashcode. Is it not possible
>>> to do that?
FUDForum. Page generated in 0.03886 seconds
