Home » Eclipse Projects » Plugin Development Environment (PDE) » PLUG-INS how can I remove my plugin from runtime-EclipseApplication
PLUG-INS how can I remove my plugin from runtime-EclipseApplication [message #970909] Sun, 04 November 2012 07:09 Go to next message
I am writing plug-in for Eclipse, but sometimes I want to make a new Eclipse plug-in project and I don't want to run my formers plug-in projects. Is it possibility to disable these plug-ins from runtime Eclipse.
I mean I have plug-in project MyPlugin1. I run it, change it etc. But after a few hours I want to make a new plug-in project MyPlugin2 (but I don't want to delete MyPlugin1) and when I launch it as a new Eclipse Appilcation MyPlugin1 also runs on this instance of Eclipse and I want only to run MyPlugin2!
I will be gratefull for any help!!!
Re: PLUG-INS how can I remove my plugin from runtime-EclipseApplication [message #972452 is a reply to message #970909] Mon, 05 November 2012 11:43 Go to previous messageGo to next message
You can
a) Close the projects you don't want to launch (Right-click on project > Close project)
OR
b) Edit the launch configuration (Run Menu > Run Configurations... > Your Eclipse application configuration > Plug-ins Tab)
Re: PLUG-INS how can I remove my plugin from runtime-EclipseApplication [message #972458 is a reply to message #972452] Mon, 05 November 2012 11:47 Go to previous message
For more complex scenarios I put my projects into java working sets, then right click on the working set and close/open what I need.
Previous Topic:Extending the default java editor
Next Topic:Possible bug in Target Platform handling
Current Time: Thu Jul 24 21:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
