Home » Eclipse Projects » EclipseLink » EntityManagerFactory (Eclipselink RCP) return NullPointerException
icon7.gif  EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #963450] Mon, 29 October 2012 16:46 Go to next message
Greetings,
I'm developing RCP application integrating Eclipselink JPA. The RCP project named as mamsys-dispose.
I've also creates a separate project for JPA and I've generates the entities using EclipseLink and convert it to Plug-in project. I also put my EntityManagerFactory and models in this project (JPA). I then add it as required plug-in at mamsys-dispose (MANIFEST-MF > Dependencies)
I'm referring to the 'comics' example and note that the example is old and I've made a number of configuration such as using Activator (org.eclipse.persistence.jpa.osgi) as the classloader. The emf (instance) in comics example refers to null but in my development, emf is not referring to null. I put as EntityManagerFactory emf;. Only at createEntityManager, I put:-
if (emf == null)
init();
But I'm still got these stack trace:-
java.version=1.6.0_35
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -application org.eclipse.mamsys-dispose.application
Command-line arguments: -application org.eclipse.mamsys-dispose.application -data /Users/azwady/eclipseRCPproj/../runtime-org.eclipse.mamsys-dispose.application -dev file:/Users/azwady/eclipseRCPproj/.metadata/.plugins/org.eclipse.pde.core/org.eclipse.mamsys-dispose.application/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog
!ENTRY org.eclipse.core.jobs 4 2 2012-10-29 04:59:32.852
!MESSAGE An internal error occurred during: "Init View...".
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:54)
at org.eclipse.mamsysdispose.model.CreateCaseModel.<init>(CreateCaseModel.java:24)
at org.eclipse.mamsysdispose.views.viewparts.NewCaseView$2$1.run(NewCaseView.java:162)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
What is missing here?.
**BTW, I'm creating this application on my Macbook and using Eclipse RCP Juno SR1.
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #964470 is a reply to message #963450] Tue, 30 October 2012 10:45 Go to previous messageGo to next message
If the emf is null, you aren't showing the code used to iniilize it so it's not likely anyone will be able to help. Check that your init method isn't catching and ignoring exceptions that might help point to the cause, and be sure to turn Eclipselink logging on.
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #964493 is a reply to message #963450] Tue, 30 October 2012 11:12 Go to previous messageGo to next message
No Message Body
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #964494 is a reply to message #964493] Tue, 30 October 2012 11:13 Go to previous messageGo to next message
You're using the deprecated EclipseLink OSGi support. You should be using Gemini JPA for EclipseLink JPA support in OSGi.
http://www.eclipse.org/gemini/jpa/
--Shaun
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #965764 is a reply to message #964494] Wed, 31 October 2012 09:41 Go to previous messageGo to next message
Hi Shaun,
I've just tried Gemini JPA. Also changing the MamsysEntityManagerFactory properties as attach but the result still the same.
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:52)
Also put the driver (mysql-connector-java-5.1.22-bin.jar) in Bundle-Classpath. (JPA Project that been converted into Plug-in project)
Something is missing I quest
[Updated on: Wed, 31 October 2012 12:09] by Moderator
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #965782 is a reply to message #964470] Wed, 31 October 2012 09:55 Go to previous messageGo to next message
Hi Chris,
Attached is the code using for EntityManagerFactory but I just refer the emf to null but still got NPE.
!STACK 0
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #967082 is a reply to message #965764] Thu, 01 November 2012 09:28 Go to previous messageGo to next message
You're getting an NPE because the requested persistence unit was not found and you're trying to invoke createEntityManager on null. As per the JPA specification, null is returned when the requested persistence unit can't be found.
When using Gemini JPA you don't need to set the classloader as a property--all of that is taken care of for you. The OSGi Enterprise Specification defines a service based approach to OSGi which is different and you need to adjust your application accordingly. Just changing persistence unit properties, bundle imports, or required bundles is not sufficient. Please take a look at the Gemini JPA documentation for details: http://wiki.eclipse.org/Gemini/JPA/Documentation
--Shaun
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #969092 is a reply to message #967082] Fri, 02 November 2012 20:50 Go to previous messageGo to next message
Hi Shaun,
I just delete the classloader property and change logging level to 'FINE' , not setting emf to null and change if (emf == null) to if (emf != null) but I still got NPE.
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:46)
I attach my persistence.xml and MamsysEntityManagerFactory. Can I put my persistence.xml together with MANIFEST. Currently in my JPA project I've TWO META.INF folder. One content persistence.xml and located at my src folder and one content my MANIFEST (As i'm converting the jpa project to plug-in).
Is it possible to put persistence.xml (JPA project) in my MANIFEST (put at plugin xml -> RCP project as I've two separates project) ?
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #972284 is a reply to message #969092] Mon, 05 November 2012 09:01 Go to previous messageGo to next message
Hi Azi,
I don't think you've completely migrated to Gemini JPA if you're still calling Persistence.createEntityManagerFactory(). JPA is service based in OSGi so you need to lookup the EMF service for the persistence unit. Once you've got all the Gemini JPA, EclipseLink, and your bundles deployed as described in the Gemini JPA documentation, you would obtain a reference to an EMF via service lookup as described here: http://wiki.eclipse.org/Gemini/JPA/Documentation/JPAServices#EntityManagerFactory_Service
FYI, you can get Gemini JPA help on the Gemini forum.
--Shaun
icon7.gif  Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #972764 is a reply to message #972284] Mon, 05 November 2012 17:06 Go to previous messageGo to next message
Hi Shaun,
I think there is a connection but i'm sure something needs to be configured. I attach all the stack trace here:
Hello World!!
[EL Config]: metadata: 2012-11-06 05:42:12.781--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.811--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.812--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.815--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.873--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.891--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.907--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.915--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.917--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.919--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.944--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.946--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:12.966--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.971--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.988--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.053--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [process] is being defaulted to: PROCESS_IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [initialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field createCase] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [createCase] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field registerUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [kewPa17] is being defaulted to: KEWPA17_IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprQuery] is being defaulted to: POSTAPPRQUERY_IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [approQuery] is being defaulted to: APPROQUERY_IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa172] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa173] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field appliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [appliQuery] is being defaulted to: APPLIQUERY_IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.1--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being
[Updated on: Mon, 05 November 2012 17:12] by Moderator
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #974198 is a reply to message #972764] Tue, 06 November 2012 18:17 Go to previous messageGo to next message
Hi Azi,
I'm not sure that you do have a connection. If you're using the deprecated EclipseLink OSGi support then the classloader you're passing must be able to load the JDBC driver class or you can pass the datasource.
But once again I strongly encourage you to migrate to Gemini JPA.
Shaun
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #990516 is a reply to message #974198] Wed, 12 December 2012 15:50 Go to previous message
Hi Shaun,
Sorry I've been missing for long time. I don't know wether the connection is established or not but it keep saying that ServerSession Connection is connected.
But when comes to the SWT, there is an exception occurs. If the login is successful, then data should be in place where JFace can extract the data and display it. But nothing is display.
I've put some data in the table previously. I've also rewrite my binding code. But still no luck. I'm also forward this error in SWT's forum as I'm assuming the problem happen at SWT side. Here,i'm posting the new stacktrace as i'm configuring that the problem is from Persistence side.
In my EntityManagerFactory, i'm using the gemini as the PersistenceProvider and point my persistence.xml's path as the Meta-Persistence in MANIFEST.MF (META-INF).
Why the access, target entity, column name and alias name is being default?. What is that mean?.
Here I'm attaching the new stacktrace (.rtf), my entitymanager (.java) and persistence (.xml)
Previous Topic:MOXy and JAXB Marshaller.Listener getting XMLRoot object
Next Topic:EclipseLink zipped p2 repositories?
Current Time: Wed Jul 23 04:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.30247 seconds
