Home » Eclipse Projects » Remote Application Platform (RAP) » SWT.VIRTUAL & SWT.CHECK table
SWT.VIRTUAL & SWT.CHECK table [message #971422] Sun, 04 November 2012 17:07 Go to next message
Hello all,
I have the following code.
There is a button and virtual SWT.CHECK table.
When the button "Select" is pressed all table items should be checked.
When i am using rap 1.4.0 it works perfectly; after the items are selected the table still behaves as VIRTUAL.
In rap 1.5.1; if I press the button and afterwards scroll, i get empty rows; no data is loaded anymore. If I do not press the button, the table behaves like virtual table.
Can you help me to figure out what am I doing wrong here ?
Thank you.
public void createPartControl(Composite parent)
        parent.setLayout(new GridLayout(1, false));
        Button selectAll = new Button(parent, SWT.NONE);
        selectAll.setText("Select");
        selectAll.addSelectionListener(new SelectionAdapter()
            public void widgetSelected(SelectionEvent e)
                for (TableItem tableItem : tableViewer.getTable().getItems())
                    tableItem.setChecked(true);
        final Composite tableComposite = new Composite(parent, SWT.NONE);
        tableComposite.setLayoutData(new GridData(GridData.FILL, GridData.FILL,
                true, true));
        TableColumnLayout tcl_topicsTableComposite = new TableColumnLayout();
        tableComposite.setLayout(tcl_topicsTableComposite);
        tableViewer = new TableViewer(tableComposite, SWT.BORDER
                | SWT.FULL_SELECTION  | SWT.CHECK | SWT.VIRTUAL);
        Table topicsTable = tableViewer.getTable();
        topicsTable.setHeaderVisible(true);
        topicsTable.setLinesVisible(true);
        TableViewerColumn firstViewerColumn = new TableViewerColumn(
                tableViewer, SWT.NONE);
        final TableColumn firstColumn = firstViewerColumn.getColumn();
        firstColumn.setToolTipText("atring"); //$NON-NLS-1$
        tcl_topicsTableComposite.setColumnData(firstColumn, new ColumnWeightData(
                1, ColumnWeightData.MINIMUM_WIDTH, true));
        firstColumn.setText("first column"); //$NON-NLS-1$
        TableViewerColumn secondViewerColumn = new TableViewerColumn(
        final TableColumn secondColumn = secondViewerColumn.getColumn();
        secondColumn.setToolTipText("second column"); //$NON-NLS-1$
        tcl_topicsTableComposite.setColumnData(secondColumn, new ColumnWeightData(
        secondColumn.setText("second column");
        tableViewer.setContentProvider(ArrayContentProvider.getInstance());
        tableViewer.setLabelProvider(new ITableLabelProvider()
            public void removeListener(ILabelProviderListener listener)
            public boolean isLabelProperty(Object element, String property)
                return false;
            public void dispose()
            public void addListener(ILabelProviderListener listener)
            public String getColumnText(Object element, int columnIndex)
                return ((String[]) element)[columnIndex];
            public Image getColumnImage(Object element, int columnIndex)
                return null;
        tableViewer.setInput(new String[][] {
                { "getStringValue1", "getStringValue2" },
                { "getStringValue1", "getStringValue2" } });
Re: SWT.VIRTUAL & SWT.CHECK table [message #971953 is a reply to message #971422] Mon, 05 November 2012 03:37 Go to previous messageGo to next message
when you call TableItem#setChecked the item is marked as materialized
and no further data are requested. The old behavior (RAP 1.4) was wrong.
Now the behavior is exactly the same like in SWT (just checked it). If
you have suspicions that something is not working correctly always check
your snippet against SWT.
Best,
Ivan
On 11/5/2012 12:07 AM, bogdan toma wrote:
> Hello all,
> Thank you.
> @Override
> GridData.FILL,
> true, true));
> ColumnWeightData(
> ColumnWeightData(
> @Override
> @Override
> property)
> return false;
> @Override
> @Override
> @Override
> @Override
> return null;
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: SWT.VIRTUAL & SWT.CHECK table [message #972152 is a reply to message #971953] Mon, 05 November 2012 06:51 Go to previous message
Ok. Thank you.
Previous Topic:Parent accessible on primary modal dialog
Next Topic:IE launch error post migration to 2.0M2
Current Time: Sat Jul 26 18:45:54 EDT 2025
Powered by FUDForum. Page generated in 0.06939 seconds
