Home » Eclipse Projects » NatTable » Freeze columns programmatically
Freeze columns programmatically [message #968252] Fri, 02 November 2012 06:11 Go to next message
How to freeze column in Nattable programmatically?
I have a table with a large number of columns and I want to freeze the contents of first 4 columns when I build the table, so that users can scroll horizontal having the main info stored in the first columns always available.
Thanks in advance for any help
Re: Freeze columns programmatically [message #972042 is a reply to message #968252] Mon, 05 November 2012 05:00 Go to previous messageGo to next message
in my first project where NatTable is used, I used the following code to freeze columns programmatically:
//get the reference to the SelectionLayer
SelectionLayer selectionLayer = this.gridLayer.getSelectionLayer();
//select cell with column position 2 and row position 0
selectionLayer.setSelectedCell(2, 0);
//freeze the first two columns
natTable.doCommand(new FreezeSelectionCommand());
//remove selection
selectionLayer.clear();
It should also be possible to do it more directly like this:
natTable.doCommand(new FreezeColumnCommand(natTable, 3));
Greez,
Dirk
Re: Freeze columns programmatically [message #1852970 is a reply to message #972042] Mon, 13 June 2022 10:23 Go to previous message
in my case it worked as Dirk said but in an after render way via a paintListener. See https://www.eclipse.org/forums/index.php/m/1852917/?srch=freezecolumn#msg_1852917
Previous Topic:FreezeColumn Nattable 2.0.2 not working
Next Topic:Combo boxes for items with identical string representation
Current Time: Sat Jun 07 16:19:10 EDT 2025
Powered by FUDForum. Page generated in 0.03165 seconds
