Maven build with ant task ecore2Java [message #972025] |
Mon, 05 November 2012 04:48  |
Hey folks,
I'm trying right now to generate model java code from an ecore model and I'm able to du this with an ant task:
java -jar /Applications/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -application org.eclipse.ant.core.antRunner -nosplash -buildfile build.xml
Ant task:
<project default="codegen" basedir="..">
<dirname property="antfile.dir" file="${ant.file}"/>
<!-- Global properties -->
<property name="main.directory" location="${antfile.dir}/.."/>
<property name="output.directory" location="${main.directory}"/>
<property name="source.directory" value="src"/>
<property name="genJDKLevel" value="5.0"/>
<target name="codegen">
<!-- A macrodef makes it easier to generate code for multiple models in one script. -->
<macrodef name="ecore2Java">
<attribute name="modelName"/>
<element name="settings"/>
<sequential>
<emf.Ecore2Java
model="${main.directory}/ecore2java/model/@{modelName}.ecore"
genModel="${output.directory}/emf/@{modelName}.genmodel"
modelProject="${output.directory}"
modelProjectFragmentPath="${source.directory}"
modelPluginID="@{modelName}.model"
copyright="This is my code."
jdkLevel="${genJDKLevel}">
<settings/>
</emf.Ecore2Java>
</sequential>
</macrodef>
<!-- Generating the code for the library model -->
<ecore2Java modelName="library">
<settings>
<arg line="-package http:///library.ecore org.examples Library"/>
</settings>
</ecore2Java>
</target>
</project>
So now my question is, how to run this particular ant task from maven. Should I use pde-maven-plugin or can I use tycho-eclipserun-plugin, what is the best solution? I saw some similar topics in forum but no answer for this question.
Thanks for help,
Artem.
Re: Maven build with ant task ecore2Java [message #977174 is a reply to message #976769] |
Thu, 08 November 2012 23:40   |
Artem,
Comments below.
On 08/11/2012 9:59 PM, Artem G. wrote:
> Hi Ed,
> thanks for your reply. I figured out how can I do it properly with
> maven. Hier is my maven task:
> <plugin>
> <groupId>org.eclipse.tycho</groupId>
> <artifactId>tycho-maven-plugin</artifactId>
> <extensions>true</extensions>
> </plugin>
> <plugin>
> <groupId>org.eclipse.tycho.extras</groupId>
> <artifactId>tycho-eclipserun-plugin</artifactId>
> <version>0.16.0</version>
> <configuration>
> <appArgLine>-application
> build.xml</appArgLine>
> <dependencies>
> <dependency>
> <artifactId>org.eclipse.ant.core</artifactId>
> <type>eclipse-plugin</type>
> </dependency>
> <dependency>
> <artifactId>org.eclipse.emf.ant</artifactId>
> </dependency>
> <dependency>
> <artifactId>org.eclipse.emf.importer.ecore</artifactId>
> </dependency>
> </dependencies>
> </configuration>
> <executions>
> <execution>
> <goals>
> <goal>eclipse-run</goal>
> </goals>
> <phase>compile</phase>
> </execution>
> </executions>
> </plugin>
> But now I have a next problem. I have an eclipse project:
> org.example.project
> |-plugin.xml
> |-META-INF
> |-model
> |-myEcore.ecore
> and if I generate a genmodel from ecore and generate model java code
> from this genmodel(it has /org.example.project/model-gen as "Model
> Directory" property) over Eclipse UI it place model code right in
> model-gen directory and don't create plugin.xml etc in this model-gen
> directory, looks like it take org.example.projects' plugin.xml etc.
Yes, it generally won't generate one once it exists though in the latest
builds I've added support for merging of plugin.xml and MANIFEST.MF....
> So but if place build.xml in org.example.project like this:
> code]
> org.example.project
> |-build.xml
> |-plugin.xml
> |-META-INF
> |-model
> |-myEcore.ecore
> [/code]
> with build.xml:
> <emf.Ecore2Java
> model="${antfile.dir}/model/@{modelName}.ecore"
> genModel="${antfile.dir}/model/@{modelName}.genmodel"
> modelProject="${antfile.dir}"
> modelProjectFragmentPath="model-gen"
> modelPluginID="${modelPlugin.ID}"
> generateJavaCode="true"
> generateModelProject="false"
> generateEditProject="false"
> generateEditorProject="false"
> validateModel="true"
> <settings/>
> </emf.Ecore2Java>
> and run, it gives me an error: The project description file
> (.project) for 'org.example.project' is missing. This file contains
> important information about the project. The project will not
> function properly until this file is restored.
> If I change modelProject path like this:
> <emf.Ecore2Java
> modelProject="${antfile.dir}/org.genetty.gendsl"
> <settings/>
> </emf.Ecore2Java>
> it generate all model code with new plugin.xml etc in
> org.example.project directory inside org.example.project:
> org.example.project
> |-build.xml
> |-plugin.xml
> |-META-INF
> |-model
> |-myEcore.ecore
> |-model-gen
> |-org.example.project
> |-plugin.xml
> |-META-INF
> |-model-gen
> |-MyEcore.java
> How can I set the modelProject path to generate model code in
> model-gen and use existing plugin.xml?
It seems to me there was some trick to let it know where the project
starts. Oh yes, hunting around I find
org.eclipse.emf.codegen.ecore.Generator.EclipseHelper.findOrCreateContainerHelper(String,
String, Monitor) where adding a "/./" in the path to indicate where the
project actually starts on the path. I also see that -projects would
help (point at the folder in which the , but I'm not sure how you
specify that in Ant.
public void printGenerateUsage()
System.out.println("Usage arguments:");
System.out.println(" [-projects <project-root-directory>]");
System.out.println(" [-dynamicTemplates] [-forceOverwrite | -diff]");
System.out.println(" [-generateSchema] [-nonNLSMarkers]");
System.out.println(" [-codeFormatting { default | <profile-file> }
System.out.println(" [-model] [-edit] [-editor] [-tests]");
System.out.println(" [-autoBuild <true|false>]");
System.out.println(" [-reconcile]");
System.out.println(" <genmodel-file>");
System.out.println(" [ <target-root-directory> ]");
System.out.println("");
System.out.println("For example:");
System.out.println(" generate result/model/Extended.genmodel");
Can you run under debug control to see how best to take advantage of
these "tricks"?
> Thank you very much for your previous message!
> Artem.
Re: Maven build with ant task ecore2Java [message #978078 is a reply to message #977174] |
Fri, 09 November 2012 15:41  |
Hi Ed,
thank you for your reply. I was able to solve my task partially. On your advise I've downloaded codegen.ecore' source and debugged Eclipse UI to find out, what happens by clicking "Generate Model code" and codegen.ecore.Generator by invoking it from command line. My task was to exclude artefacts, could be generated from ecore from version control: genmodel and generated models java code. Unfortunately I'm not able to exclude genmodel, only models java code. If I use ant task or org.eclipse.emf.importer.ecore.Ecore2GenModel to generate a genmodel from ecore I'm not able to specify a basePackage attribute of genmodel which than used by models code generation from this genmodel, so all the generated java classes get "package <prefix>;" in java source code. This is critical for me. But if I edit ecore in Eclipse UI, related genmodel gets updates automatically -- not such a big loss.
P.S.: Your book is great and very helpful!
FUDForum. Page generated in 0.04585 seconds
