Parent accessible on primary modal dialog [message #970957] |
Sun, 04 November 2012 08:06  |
what is the intended accessibility of a parent dialog in case a primary modal child dialog is open in mode 'OperationMode.SWT_COMPATIBILITY'?
I found out the following:
APPLICATION_MODAL: parent dialog inaccessible
PRIMARY_MODAL: parent dialog accessible
(version = 2.0.0.20121001-1623)
I would expect that the parent dialog is inaccessible also in case of a primary modal child dialog.
Here is a short snippet to reproduce this:
package org.openxma.rwt.launch;
import org.eclipse.rap.rwt.lifecycle.IEntryPoint;
public class RWTTest implements IEntryPoint {
public int createUI() {
Display display = new Display();
final Shell shell = new Shell(display);
shell.setText("Parent");
shell.setSize(500,400);
shell.setLayout(new FillLayout(SWT.VERTICAL));
/* primary modal shell */
Button primaryModalButton = new Button(shell, SWT.PUSH);
primaryModalButton.setText("Open primary modal shell");
primaryModalButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent arg0) {
Shell primaryModalShell = new Shell(shell, SWT.PRIMARY_MODAL | SWT.TITLE | SWT.CLOSE);
primaryModalShell.setText("Primary modal");
primaryModalShell.open();
eventLoop(primaryModalShell);
/* application modal shell */
Button applicationModalButton = new Button(shell, SWT.PUSH);
applicationModalButton.setText("Open application modal shell");
applicationModalButton.addSelectionListener(new SelectionAdapter() {
Shell applicationModalShell = new Shell(shell, SWT.APPLICATION_MODAL | SWT.TITLE | SWT.CLOSE);
applicationModalShell.setText("Application modal");
applicationModalShell.open();
eventLoop(applicationModalShell);
/* open parent shell */
shell.open();
eventLoop(shell);
return 0;
protected void eventLoop(Shell shell) {
Display display = shell.getDisplay();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
Thank you,
best regards,
Karl
Re: Parent accessible on primary modal dialog [message #971958 is a reply to message #970957] |
Mon, 05 November 2012 03:41  |
Hi Karl,
please open a bugzilla about this issue.
Ivan
On 11/4/2012 3:06 PM, Karl Hönninger wrote:
> Hello,
> shell.open();
> eventLoop(shell);
> return 0;
> display.sleep();
> Thank you,
> best regards,
> Karl
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03351 seconds
