Home » Language IDEs » C / C++ IDE (CDT) » HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work?
HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work? [message #96985] Thu, 18 March 2004 21:21 Go to next message
Originally posted by: shilpabathija.yahoo.com
hello all,
I am using CDT 1.2 version for win32 . (with Using Eclipse Version 2.1.2)
I want to use the BCC 5.5 Compiler with it.
My makefile builds when I run on the command prompt.
i.e make and bcc , ilink32 etc are in the path.
But when I try to Build the Project on Eclipse, it is not able to find the
path of bcc and ilink32.
In my Project Properties ->makeBuilder-Build Command
I have UNChecked the default Build and given the Build Command to be
C:\Borland\BCC55\Bin\make -fmakefile
I gave this because it was not able to find make.
I have even specified the path of bcc32 in my makefile
i.e C:\Borland\BCC55\Bin\bcc32
But now it complains that it cannot find the ilnk32 command.
What do I have to do ?
Any help pointers here are greatly appreciated !
Thanks in advance,
Shil
Re: HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work? [message #96990 is a reply to message #96985] Fri, 19 March 2004 03:39 Go to previous messageGo to next message
Shil wrote:
> hello all,
What about, adding your borland binary directory (the one, where
bcc32,ilnk32,make are) to your PATH variable?
> Thanks in advance,
> Shil
Re: HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work? [message #97021 is a reply to message #96990] Fri, 19 March 2004 13:15 Go to previous messageGo to next message
The Borland\BCC55\BIN is in my path variable.
Thats the reason why I am able to successfully build from the Command
Prompt.
kesselhaus wrote:
> Shil wrote:
> > hello all,
> > C:BorlandBCC55Binmake -fmakefile
> > i.e C:BorlandBCC55Binbcc32
> > Thanks in advance,
> > Shil
Re: HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work? [message #97028 is a reply to message #97021] Fri, 19 March 2004 17:58 Go to previous messageGo to next message
> Prompt.
You have restarted Eclipse, and maybe all shells/cmd/explorer,..., after
changing your PATH settings?
What system is that? Win9x/ME or WinNT/2k/XP?
> kesselhaus wrote:
>>Shil wrote:
>>>hello all,
>>>Thanks in advance,
>>>Shil
Re: HELP ASAP ! - CDT 1.2 with Borland 5.5 - Does not work? [message #97054 is a reply to message #97028] Fri, 19 March 2004 18:14 Go to previous message
Its Windows 2000
I have restarted Eclipse several times.
The funny part if that I can make the project from Command Prompt.
CDT is unable to find the path of my compiler i.e Borland
Have you been able to run CDT with Borland before?
Thanks ,
Shil
kesselhaus wrote:
> Shil wrote:
> > The BorlandBCC55BIN is in my path variable.
> > Prompt.
> > kesselhaus wrote:
> >>Shil wrote:
> >>>hello all,
> >>>Thanks in advance,
> >>>Shil
Previous Topic:New Make Project Prefrence Page
Next Topic:No C++ Item in New Project Dialog Box
Current Time: Thu Sep 18 20:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.03692 seconds
