Home » Modeling » EMF » [CDO] Problem running clone example
[CDO] Problem running clone example [message #968050] Fri, 02 November 2012 02:56 Go to next message
I am trying to run the clone example from CDO 4.2-M2 using the bundles org.eclipse.emf.cdo.examples.master and org.eclipse.emf.cdo.examples.clone.
I changed the configuration of the master server as follows:
 <property name="overrideUUID" value=""/>
 <property name="supportingAudits" value="true"/>
 <property name="supportingBranches" value="true"/>
 <property name="supportingEcore" value="false"/>
 <property name="ensureReferentialIntegrity" value="false"/>
 <property name="allowInterruptRunningQueries" value="true"/>
 <property name="idGenerationLocation" value="CLIENT"/>
Then I start the master server with an empty database and when starting the clone server with an empty database the clone throws an exception:
[WARN] Replication attempt failed. Retrying in 2 seconds...
org.eclipse.emf.cdo.common.util.TransportException: java.io.UTFDataFormatException: malformed input around byte 3
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.replicateRepositoryRaw(CDOClientProtocol.java:450)
	at org.eclipse.emf.cdo.internal.server.syncing.RepositorySynchronizer$ReplicateRunnable.run(RepositorySynchronizer.java:449)
	at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
	at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
	at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:88)
	at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:79)
	at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:206)
Caused by: java.io.UTFDataFormatException: malformed input around byte 3
	at java.io.DataInputStream.readUTF(Unknown Source)
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readString(ExtendedIOUtil.java:201)
	at org.eclipse.net4j.util.io.ExtendedDataInputStream.readString(ExtendedDataInputStream.java:36)
	at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readString(ExtendedDataInput.java:135)
	at org.eclipse.net4j.db.DBType$13.readValueWithResult(DBType.java:440)
	at org.eclipse.net4j.db.DBUtil.deserializeTable(DBUtil.java:1004)
	at org.eclipse.net4j.db.DBUtil.deserializeTable(DBUtil.java:944)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawImport(DBStoreAccessor.java:1142)
	at org.eclipse.emf.cdo.internal.server.syncing.SynchronizableRepository.replicateRaw(SynchronizableRepository.java:352)
	at org.eclipse.emf.cdo.internal.net4j.protocol.ReplicateRepositoryRawRequest.confirming(ReplicateRepositoryRawRequest.java:45)
	at org.eclipse.emf.cdo.internal.net4j.protocol.ReplicateRepositoryRawRequest.confirming(ReplicateRepositoryRawRequest.java:1)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
	at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
What am I doing wrong?
Another thing: I understood that the clone needs branching support, but does the master also need branching support and if yes, I would like to know why.
//Jan
Re: [CDO] Problem running clone example [message #968116 is a reply to message #968050] Fri, 02 November 2012 03:53 Go to previous messageGo to next message
Am 02.11.2012 07:56, schrieb Jan Rosczak:
Normally this (or similar protocol problems) are caused by server and clients not using the exact same version/build.
I've recently implemented:
259086: Protocol versions should be checked
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259086
But one of your peers may still be running an older version.
There's a minor potential for a string encoding defect. What charsets are you using?
> at
> at
> at
> at
> at
Theoretically it wouldn't need branching if you actually don't use branches other than the main branch. But I doubt that
I added support for disabling branching explicitely. The consequence is that, for now, you get an extra integer column
in each attribute table.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Problem running clone example [message #968138 is a reply to message #968116] Fri, 02 November 2012 04:11 Go to previous messageGo to next message
I checked the versions of both, they are started from within the same Eclipse instance and the versions look ok to me.
Do you mean the platform encoding? I guess it is CP1252, as I am running on Windows 7.
Do you mean by "support for disabling branches explicitly", setting "supportingBranches" to false in the master configuration is not supported for offline clones?
Cheers
/Jan
Re: [CDO] Problem running clone example [message #968147 is a reply to message #968138] Fri, 02 November 2012 04:20 Go to previous messageGo to next message
Am 02.11.2012 09:11, schrieb Jan Rosczak:
Let me play with an offline setup to see if we have a regression that's not covered by the tests...
Yes, that's what I mean. You can try, but I really think that it's not supported. It could be, though. As kind of an
optimization.
Cheers
/Eike
Re: [CDO] Problem running clone example [message #969900 is a reply to message #968050] Sat, 03 November 2012 13:11 Go to previous messageGo to next message
I have an issue with the clone example as well.
If I start an empty .master server, and I start the .clone server, I get:
State changed from OFFLINE to SYNCING
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Table EOBJECT not found; SQL statement:
UPDATE EObject SET cdo_revised=? WHERE cdo_id=? AND cdo_branch=? AND cdo_version=? [42102-117]
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingMappingStrategy.rawImportReviseOldRevisions(HorizontalBranchingMappingStrategy.java:166)
	at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.rawImport(AbstractHorizontalMappingStrategy.java:236)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawImport(DBStoreAccessor.java:1151)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
	at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:440)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
	at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
I have tried to install version 4.1, but with that, the master server doesn't start, throwing:
app thread - org.eclipse.emf.cdo.server.app.0 [debug.repository] Configuring repository repo1 (type=default)
[ERROR] Store factory not found: db
java.lang.IllegalStateException: Store factory not found: db
	at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getStoreFactory(RepositoryConfigurator.java:281)
	at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.createStore(RepositoryConfigurator.java:291)
	at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getRepository(RepositoryConfigurator.java:164)
	at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:106)
	at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
	at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
	at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
main [debug.om] Stopping bundle org.eclipse.emf.cdo.server
Thanks in advance for any hints.
Cristian.
Re: [CDO] Problem running clone example [message #969909 is a reply to message #969900] Sat, 03 November 2012 13:21 Go to previous messageGo to next message
UPDATE:
I realize that I forgot to set idGenerationLocation to CLIENT. After setting it, I have the same issue as Jan.
Re: [CDO] Problem running clone example [message #969953 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Am 03.11.2012 18:21, schrieb Cristian Mising name:<br>
<blockquote cite="mid:k73jr4$4mt$1@xxxxxxxxe.org" type="cite">UPDATE:
<br>
<br>
</blockquote>
I've already fixed the way the cdo-server.xml gets copied. Now
supportingEcore is set to false and the idGenerationLocation to
CLIENT.<br>
<br>
I'm also working on a larger RCP based example suite:<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12179" alt=""><br>
<br>
It'll be available sometime next week...<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<a class="moz-txt-link-freetext" href="http://www.esc-net.de">http://www.esc-net.de</a><br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a><br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a><br>
<br>
<br>
</body>
</html>
  • Attachment: fehabdjd.png
    (Size: 20.58KB, Downloaded 273 times)
Re: [CDO] Problem running clone example [message #969958 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
</head>
<br>
<br>
</blockquote>
CLIENT.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12180" alt=""><br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
    (Size: 20.58KB, Downloaded 262 times)
Re: [CDO] Problem running clone example [message #969963 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
</head>
<br>
<br>
</blockquote>
CLIENT.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12181" alt=""><br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
    (Size: 20.58KB, Downloaded 254 times)
Re: [CDO] Problem running clone example [message #969968 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
</head>
<br>
<br>
</blockquote>
CLIENT.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12182" alt=""><br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
    (Size: 20.58KB, Downloaded 258 times)
Re: [CDO] Problem running clone example [message #969975 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
</head>
<br>
<br>
</blockquote>
CLIENT.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12183" alt=""><br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
    (Size: 20.58KB, Downloaded 299 times)
Re: [CDO] Problem running clone example [message #969981 is a reply to message #969909] Sat, 03 November 2012 14:07 Go to previous messageGo to next message
<html>
<head>
</head>
<br>
<br>
</blockquote>
CLIENT.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&amp;id=12184" alt=""><br>
<br>
<br>
Cheers<br>
/Eike<br>
<br>
----<br>
<br>
<br>
</body>
</html>
    (Size: 20.58KB, Downloaded 263 times)
Re: [CDO] Problem running clone example [message #970194 is a reply to message #969981] Sat, 03 November 2012 18:50 Go to previous messageGo to next message
Thanks for the excellent news!
I'm looking forward to the running the new example. The screenshot looks very... tempting/teasing Smile
Cristian.
Re: [CDO] Problem running clone example [message #980060 is a reply to message #968050] Sun, 11 November 2012 05:08 Go to previous messageGo to next message
I am moving back here the discussion/ 2 posts related to this discussion:
Infinite loop on client: Open Session, Open Session, etc:
http://www.eclipse.org/forums/index.php/mv/msg/433382/978704/#msg_978704
Eike cannot reproduce the issue:
http://www.eclipse.org/forums/index.php/mv/msg/433382/979929/#msg_979929
After doing a little bit of debug, I realize that's the same issue as Jan's. But in my case I see that the trace is disabled so the exception is hidden:
Opened Session41 [repo1]
org.eclipse.emf.cdo.common.util.TransportException: java.io.UTFDataFormatException: malformed input around byte 5
	at org.eclipse.emf.cdo.internal.server.syncing.RepositorySynchronizer$ReplicateRunnable.run(RepositorySynchronizer.java:434)
	at org.eclipse.net4j.util.concurrent.QueueRunner2.work(QueueRunner2.java:26)
	at org.eclipse.net4j.util.concurrent.QueueRunner2.work(QueueRunner2.java:1)
Caused by: java.io.UTFDataFormatException: malformed input around byte 5
	at java.io.DataInputStream.readUTF(DataInputStream.java:648)
	at java.io.DataInputStream.readUTF(DataInputStream.java:564)
	at org.eclipse.net4j.util.io.ExtendedIOUtil.readString(ExtendedIOUtil.java:202)
	at org.eclipse.net4j.db.DBUtil.deserializeTable(DBUtil.java:1011)
	at org.eclipse.net4j.db.DBUtil.deserializeTable(DBUtil.java:951)
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawImport(DBStoreAccessor.java:1152)
	at org.eclipse.emf.cdo.internal.server.syncing.SynchronizableRepository.replicateRaw(SynchronizableRepository.java:356)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
	... 7 more
Cristian.
Re: [CDO] Problem running clone example [message #980108 is a reply to message #980060] Sun, 11 November 2012 06:02 Go to previous messageGo to next message
Dear Eike,
What I discovered until now:
I see that the exception always happens after processing the DataInput that looks like this. I mean, this is processed ok, but the next invocation of ExtendedIOUtil.readString(DataInput) would throw the exception. The DataInput seems to be empty.
[h, t, t, p, :, /, /, w, w, w, ., e, c, l, i, p, s, e, ., o, r, g, /, e, m, f, /, C, D, O, /, E, r, e, s, o, u, r, c, e, /, 4, ., 0, ., 0,
Daemon Thread [CDORepositorySynchronizer] (Suspended)
	owns: Object  (id=41)
	ExtendedIOUtil.readString(DataInput) line: 192
	ExtendedDataInputStream.readString() line: 36
	CDOClientRequestWithMonitoring$2(ExtendedDataInput$Delegating).readString() line: 135
	StringCompressor.readString(ExtendedDataInput) line: 330
	StringCompressor.read(ExtendedDataInput) line: 175
	CDOClientRequestWithMonitoring$2(CDODataInputImpl).readCDOPackageURI() line: 159
	CDOPackageInfoImpl.read(CDODataInput) line: 90
	CDOClientRequestWithMonitoring$2(CDODataInputImpl).readCDOPackageInfo() line: 153
	CDOPackageUnitImpl.read(CDODataInput, ResourceSet) line: 316
	CDOClientRequestWithMonitoring$2(CDODataInputImpl).readCDOPackageUnit(ResourceSet) line: 124
	CDOClientRequestWithMonitoring$2(CDODataInputImpl).readCDOPackageUnits(ResourceSet) line: 139
	OpenSessionRequest.confirming(CDODataInput, OMMonitor) line: 223
	OpenSessionRequest.confirming(CDODataInput, OMMonitor) line: 1
	OpenSessionRequest(CDOClientRequestWithMonitoring<RESULT>).confirming(ExtendedDataInputStream, OMMonitor) line: 117
	OpenSessionRequest(RequestWithMonitoring<RESULT>).confirming(ExtendedDataInputStream) line: 171
	OpenSessionRequest(RequestWithConfirmation<RESULT>).doExtendedInput(ExtendedDataInputStream) line: 125
	OpenSessionRequest(Signal).doInput(BufferInputStream) line: 328
	OpenSessionRequest(RequestWithConfirmation<RESULT>).doExecute(BufferInputStream, BufferOutputStream) line: 105
	OpenSessionRequest(RequestWithMonitoring<RESULT>).doExecute(BufferInputStream, BufferOutputStream) line: 235
	OpenSessionRequest(SignalActor).execute(BufferInputStream, BufferOutputStream) line: 53
	OpenSessionRequest(Signal).runSync() line: 253
	CDOClientProtocol(SignalProtocol<INFRA_STRUCTURE>).startSignal(SignalActor, long) line: 431
	OpenSessionRequest(RequestWithConfirmation<RESULT>).doSend(long) line: 89
	OpenSessionRequest(RequestWithConfirmation<RESULT>).send() line: 75
	OpenSessionRequest(RequestWithMonitoring<RESULT>).send() line: 97
	CDOClientProtocol.send(RequestWithConfirmation<RESULT>) line: 502
	CDOClientProtocol.openSession(String, String, boolean, CDOCommonSession$Options$PassiveUpdateMode, CDOCommonSession$Options$LockNotificationMode) line: 109
	CDONet4jSessionImpl.openSession() line: 227
	CDONet4jSessionImpl.doActivate() line: 125
	CDONet4jSessionImpl(Lifecycle).internalActivate() line: 76
	CDONet4jSessionImpl(ShareableLifecycle).internalActivate() line: 43
	CDONet4jSessionImpl(Lifecycle).activate() line: 162
	CDONet4jSessionConfigurationImpl(CDOSessionConfigurationImpl).openSession() line: 310
	CDONet4jSessionConfigurationImpl.openNet4jSession() line: 104
	CDONet4jSessionConfigurationImpl.openSession() line: 110
	RepositorySynchronizer$ConnectRunnable.run() line: 353
	RepositorySynchronizer(QueueRunner2<T>).work(WorkContext, T) line: 26
	RepositorySynchronizer(QueueRunner2<T>).work(Worker$WorkContext, Object) line: 1
	RepositorySynchronizer(QueueWorker<E>).doWork(Worker$WorkContext) line: 88
	RepositorySynchronizer(QueueWorker<E>).work(Worker$WorkContext) line: 79
	Worker$WorkerThread.run() line: 206
Another thing, or question: I see that each time the client tries to reconnect:
Opened Session77 [repo1]
Opened Session78 [repo1]
it creates new threads:
Daemon Thread [Net4jReceiveSerializer-Channel[77, CLIENT, cdo]] (Suspended)
Daemon Thread [Net4jReceiveSerializer-Channel[78, CLIENT, cdo]] (Suspended)
but after the exception happens, the threads don't disappear, and they seem to enter in sleep, both client and server.
Daemon Thread [Net4jReceiveSerializer-Channel[77, SERVER, cdo]] (Running)
Daemon Thread [Net4jReceiveSerializer-Channel[78, SERVER, cdo]] (Running)
I think that the connection with the server is somehow not ended properly. If I'm not mistaking, this scenario, with a client failing in this way, could kill a production server, suffocating it with a lot of threads.
As this not happens on your setup, can you give me some hints regarding where I could put breakpoints and what should I look for?
Cristian.
Re: [CDO] Problem running clone example [message #980179 is a reply to message #980108] Sun, 11 November 2012 07:25 Go to previous messageGo to next message
Am 11.11.2012 12:02, schrieb Cristian Mising name:
> Dear Eike,
> be empty.
Thanks for the infos. Can you please submit a bugzilla? I'm currently analyzing another strange effect with fail-over
replication. Thanks to the new example suite it's very easy now to play with the stuff and see issues we've not covered
in the tests. Of course this may take a while...
Cheers
/Eike
> I look for?
> Best regards,
> Cristian.
Re: [CDO] Problem running clone example [message #980264 is a reply to message #980179] Sun, 11 November 2012 09:02 Go to previous message
Done that.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394049
Thanks.
Cristian.
Previous Topic:[CDO/Dawn] Cannot retrieve resources created via a ResourceSet
Next Topic:Global EPackage registry and Resource loading
Current Time: Sun Jul 27 04:16:21 EDT 2025
Powered by FUDForum. Page generated in 0.06002 seconds
