Home » Archived » BIRT » Tooltips on Tomcat displaced or missing
Tooltips on Tomcat displaced or missing [message #957833] Thu, 25 October 2012 10:32 Go to next message
i generated a report with some charts. on the y-series i placed tooltips for interactivity=onmouseover.
When running the report in birt all works fine.
If i run it with tomcat (localhost:8080/BirtViewer/run?__report=Charts.rptdesign) the tooltips are not working allright. Most of them are missing. Others are placed on the wrong position.
I tested it with IE (compatibily IE7) and Firefox. The funny thing: on my first test tooltips worked in firefox with tomcat. then i resized the charts and now they don't do so. resizing again doesn't help.
What's the problem? BIRT, Tomcat or Firefox? Any trick...
Help would be fantastic... I'm really frustrated...
Greetings Marina
Re: Tooltips on Tomcat displaced or missing [message #958444 is a reply to message #957833] Thu, 25 October 2012 21:43 Go to previous messageGo to next message
So, they're working in IE and not in Firefox? Can you attach a report design, that uses the sample db, that has this issue?
Re: Tooltips on Tomcat displaced or missing [message #958685 is a reply to message #958444] Fri, 26 October 2012 02:18 Go to previous messageGo to next message
here is an example. in Birt all fine. in firefox nothing. no, in ie it's also not working. some time ago i had a working report in firefox with tooltips. but after i changed it, it's also not working alright.
Greetings Marina
Re: Tooltips on Tomcat displaced or missing [message #959162 is a reply to message #958685] Fri, 26 October 2012 09:55 Go to previous messageGo to next message
Can you try this in BIRT 4.2.1?
Jason
Re: Tooltips on Tomcat displaced or missing [message #968562 is a reply to message #959162] Fri, 02 November 2012 10:59 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 02 November 2012 11:02] by Moderator
Re: Tooltips on Tomcat displaced or missing [message #968565 is a reply to message #959162] Fri, 02 November 2012 11:02 Go to previous message
big sorry that i didn't answer.
i was in holidays and haven't checked my mail.
After hours of searching i solved the problem. I installed SVGView303.exe, a svg plugin. Now tooltips in Firefox are available.
Greetings Marina
Previous Topic:Repeat table if there is a page break
Next Topic:Webservice MS SQL authentication
Current Time: Wed Jul 23 06:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.06021 seconds
