Home » Archived » M2M (model-to-model transformation) » [ATL] inject and extract ATL file to an ATL model
[ATL] inject and extract ATL file to an ATL model [message #96458] Thu, 04 December 2008 06:53 Go to next message
I'm looking to a way to inject an ATL file to an ATL model and opposite
(extract an ATL file from an ATL Model).
I have seen class ATLParser which offers apis to inject : methods
parseToModel, parseToModelWithProblems and parseWithProblems.
First one, parseToModel seems to do what I need, is it correct ?
And is there a class in ATL that allows opposite (extract an ATL file from
an ATL Model) ?
Gabriel
Re: [ATL] inject and extract ATL file to an ATL model [message #96497 is a reply to message #96458] Thu, 04 December 2008 09:21 Go to previous messageGo to next message
Hi, you can find some information in this entry:
http://dev.eclipse.org/newslists/news.eclipse.technology.gmt /msg00195.html
Andres
On 2008-12-04 12:53:23 +0100, Gabriel <GBarbier@mia-software.com> said:
> Hello,
> an ATL Model) ?
> Regards,
> Gabriel
Re: [ATL] inject and extract ATL file to an ATL model [message #96659 is a reply to message #96497] Mon, 08 December 2008 10:38 Go to previous messageGo to next message
> Regards
> Andres
>> Hello,
>> from
>> an ATL Model) ?
>> Regards,
>> Gabriel
Thanks Andres,
I just forgot to mention that I would like to do these things
programmatically (without user interactions).
And it woks well for injection, I can apply transformations to ATM model.
But, I still have a problem with extraction (when it try to find meta
classes).
Here is an example :
private final IFile parseFromModel(final ASMModel transformationModel,
URI atlFileUri) throws IOException {
AtlEMFModelHandler modelHandler = (AtlEMFModelHandler) AtlModelHandler
.getDefault("EMF");
IFile file = null;
Map parameters = new HashMap();
parameters.put("name", "ATL"); //$NON-NLS-1$ //$NON-NLS-2$
IPath atlFilePath = new Path(atlFileUri.toFileString());
OutputStream out = new FileOutputStream(atlFilePath.toFile());
final TCSExtractor ebnfe = new TCSExtractor();
try {
ebnfe.extract(transformationModel, out, parameters);
} catch (Exception e) {
e.printStackTrace();
} finally {
try {
out.close();
} catch (IOException ioe) {
return file;
Gabriel
Re: [ATL] inject and extract ATL file to an ATL model [message #96789 is a reply to message #96659] Tue, 09 December 2008 10:24 Go to previous messageGo to next message
Originally posted by: a-yie.uniandes.edu.co
Debugging org.eclipse.am3.ui.action.ActionEBNFExtractor I found that
the params Map passed to ebnfe.extract has the value of {format=ATL-0.2
: TCS}. Do you tried it?
On 2008-12-08 16:38:28 +0100, "gabriel <GBarbier@mia-software.com>"
>> Regards
>> Andres
>>> Hello,
>>> an ATL Model) ?
>>> Regards,
>>> Gabriel
> Thanks Andres,
> But, I still have a problem with extraction (when it try to find meta classes).
> .getDefault("EMF");
> IFile file = null;
> try {
> } finally {
> try {
> out.close();
> return file;
> Regards
> Gabriel
Re: [ATL] inject and extract ATL file to an ATL model [message #96803 is a reply to message #96789] Tue, 09 December 2008 14:14 Go to previous messageGo to next message
Yes, thanks a lot Yie !
I was looking in class ActionATLExtractor => next time I should use debugger !
And with good params, it works well !
The lines I have added :
InputStream tcsStream = this.getClass().getResourceAsStream("resources/atlextractor/TCS.ecore ");
ASMModel mmTCS = modelHandler.loadModel("TCS", modelHandler.getMof(), tcsStream);
InputStream atlStream = this.getClass().getResourceAsStream("resources/atlextractor/ATL-0.2-TCS.ecore ");
ASMModel modelTCS = modelHandler.loadModel("ATL-0.2", mmTCS, atlStream);
parameters.put("format", modelTCS);
Gabriel
Yie wrote:
> Debugging org.eclipse.am3.ui.action.ActionEBNFExtractor I found that the
> params Map passed to ebnfe.extract has the value of {format=ATL-0.2 :
>>> Regards
>>> Andres
>>>> Hello,
>>>> file from
>>>> an ATL Model) ?
>>>> Regards,
>>>> Gabriel
>> Thanks Andres,
>> classes).
>> AtlModelHandler
>> .getDefault("EMF");
>> IFile file = null;
>> try {
>> } finally {
>> try {
>> out.close();
>> return file;
>> Regards
>> Gabriel
Re: [ATL] inject and extract ATL file to an ATL model [message #96818 is a reply to message #96803] Tue, 09 December 2008 14:26 Go to previous message
No problem!!
> tcsStream);
ASMModel
> Regards,
> Gabriel
>>>> Regards
>>>> Andres
>>>>> Hello,
>>>>> an ATL Model) ?
>>>>> Regards,
>>>>> Gabriel
>>> Thanks Andres,
>>> .getDefault("EMF");
>>> IFile file = null;
>>> try {
>>> } finally {
>>> try {
>>> out.close();
>>> return file;
>>> Regards
>>> Gabriel
Previous Topic:[ATL] Matched Rules on uml!PrimitiveType
Next Topic:[QVTO] Using programatically provided model source
Current Time: Sat Jul 19 02:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.04596 seconds
