Home » Modeling » EMF » EcoreUtil.equals fails for EObjects read from 2 XML files which are actually copies of each other
EcoreUtil.equals fails for EObjects read from 2 XML files which are actually copies of each other [message #966805] |
Thu, 01 November 2012 04:41  |
I am observing a weird behavior with EcoreUtil.equals method. I am loading 2 XML files which are exactly the same from 2 different locations (I have the same file at 2 locations) using Resource's createResource and load methods.
ECoreUtil.equals returns false for these 2 EObjects. When I debug the EcoreUtil.equals code, I see that it fails because of the == check on EClass and EStructuralFeature. Note that the classes and structural features are the same, however, 2 separate instances of EClass and EStructuralFeature are seen. EcoreUtil.equals does a == check on feature and class and therefore fails.
What I am unable to understand is why would there be 2 instances created for EClass and EStructuralFeature. I am sure there is no difference in the 2 XML files. One is a copy of the other.
Is there any setting in the ecore model that could be the reason? My XML files have xmi:id attribute in them.
I am stumped by this behavior. Can anyone give any pointers?
Regards, Arati
Re: EcoreUtil.equals fails for EObjects read from 2 XML files which are actually copies of each othe [message #967960 is a reply to message #967906] |
Fri, 02 November 2012 01:15   |
Arati,
Comments below.
On 02/11/2012 5:12 AM, Arati Rahalkar wrote:
> Hi Ed,
> Thanks for the reply. I tried loading the resource (XML file) from the
> same resource set as well. The files are absolutely identical, just at
> two different locations on my machine.
> Another point is that there is a section in my xml file for which I do
> not have a corresponding EPackage registered (since that is an
> extensible portion of my XML file, and others can keep adding new
> extensions to it). Therefore, when I read this XML file, that section
> of the file gets mapped to AnyTypeImpl. Then I compare the two
> AnyTypeImpl using ECoreUtil.equals. That seems to fail, as in the two
> AnyTypeImpl objects, the EClass and EStructuralFeature are different
> instances.
Packages for those are demand created and stored in the instance uses
for OPTION_EXTENDED_META_DATA. If you only set that to Boolean.TRUE, a
new instance is created for each resource's load.
> Hope this clarifies my issue further. I am suspecting whether it is
> due to the AnyTypeImpl usage (I am using the Eobject to extension map
> to get the AnyTypeImpl extensions corresponding to the Eobjects)
Yes, that's definitely the case. One approach to use the following.
resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA,
new BasicExtendedMetaData(resourceSet.getPackageRegistry()));
I.e., provide an instance of ExtendedMetaData to be used across all
resources loaded in the resource set. Similarly you could modify the
factory itself to use a shared instance, keeping in mind that such an
instance is not thread safe.
> Regards,
> Arati
Re: EcoreUtil.equals fails for EObjects read from 2 XML files which are actually copies of each othe [message #971925 is a reply to message #971884] |
Mon, 05 November 2012 03:10   |
Arati,
Comments below.
On 05/11/2012 8:24 AM, Arati Rahalkar wrote:
> Hi Ed,
> I debugged the classes. Following is what I see. Also one basic
> question is: Am I taking the right approach by depending on
> EcoreUtil.equals to check the equality of two AnyTypeImpl objects, or
> is that itself not the correct way in the first place.
I don't know the reason you need to test structural equality, but that's
definitely the way you'd do that.
> Findings below:
> 1. The load options set on resource set for using one instance of
> BasicExtendedMetadata do not get used. The options set on the Resource
> are getting used at the time of resource load.
Yes, the local options of the resource override the default ones of the
resource set.
> 2. Hence, I tried setting the option on resource instead of resource
> set. One more point is that the internal extendedMetaDataHolderCache
> is getting used only if the annotation uri is different than the
> default one.
Yes.
> So I created the BasicExtendedMetadata instance using the
> BasicExtendedMetadata(annotation, registry) constructor instead of the
> BasicExtendedMetadata(registry) constructor.
> Any significance of that?
It's less efficient to keep the information in a map rather than store
it directly on the Ecore mode. What registry did you pass in.
> 3. After the above changes, I see that:
> a. AnyType.getMixed() method internally tries to create a
> FeatureMapValidator. And in that process, does not find the
> extendedmetadata object set on
> BasicExtendedMetadata.EStructuralFeatureExtendedMetaData and hence
> again ends up creating a new instance of BasicExtendedMetadata (again
> without a custom annotation)
Yes, it an only know about the meta model.
> b. I was not able to run this program till the end, because when I set
> the load option on resource level, the program is failing with a
> StackOverflowException. Giving the trace below:
Try using just "new BasicExtendedMetaData()"
> Exception in thread "main" java.lang.StackOverflowError
> at java.lang.ref.ReferenceQueue.poll(ReferenceQueue.java:81)
> at java.util.WeakHashMap.expungeStaleEntries(WeakHashMap.java:274)
> at java.util.WeakHashMap.getTable(WeakHashMap.java:302)
> at java.util.WeakHashMap.get(WeakHashMap.java:349)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getRegistry(EPackageRegistryImpl.java:235)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl$Delegator.delegateRegistry(EPackageRegistryImpl.java:254)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl$Delegator.delegateRegistry(EPackageRegistryImpl.java:259)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl$Delegator.getEPackage(EPackageRegistryImpl.java:274)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.delegatedGetEPackage(EPackageRegistryImpl.java:190)
> at
> org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:143)
> at
> org.eclipse.emf.ecore.util.BasicExtendedMetaData.getPackage(BasicExtendedMetaData.java:119)
> at
> org.eclipse.emf.ecore.util.BasicExtendedMetaData.getAttribute(BasicExtendedMetaData.java:382)
> at
> org.eclipse.emf.ecore.util.BasicExtendedMetaData.getAttribute(BasicExtendedMetaData.java:779)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getFeature(XMLHelperImpl.java:967)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFeature(XMLHandler.java:2959)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2691)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.recordUnknownFeature(XMLHandler.java:1965)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1936)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeature(XMIHandler.java:149)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2694)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.emf
Re: EcoreUtil.equals fails for EObjects read from 2 XML files which are actually copies of each othe [message #972142 is a reply to message #971925] |
Mon, 05 November 2012 06:43  |
Hi Ed,
So I was able to follow your article "Binding-XML-to-Java" on serverside and accordingly set the BasicExtendedMetaData load option and then load the resource. That worked for me.
So basically, earlier I was doing the following:
1. Set the OPTION_EXTENDED_META_DATA load option on the ResourceSet
2. Use Resource.getResource() with a false value for loadOnDemand. Due to this the resource being returned was null
3. Then I was using the resource.createResource followed by resource.load method to actually load the resource contents into Resource object
With the above steps, things were not working for me, and different instances of BasicExtendedMetadata being created always.
Instead, now I am doing the following:
1. Do not specify the OPTION_EXTENDED_META_DATA value at the ResourceSet level
2. Still continue to use getResource with false value for loadOnDemand.
3. But now use resource.load and pass the OPTION_EXTENDED_META_DATA value to the load method at the resource level
The above works, and now I get the two AnyTypeImpl objects as being equal.
So basically, the common shared BasicExtendedMetadata instance was not getting used for me earlier when I was setting it at ResourceSet level and then using the load method explicitly for Resource.
Thanks a lot for your guidance, Ed.
Arati
Current Time: Thu Jul 24 17:57:32 EDT 2025
Powered by FUDForum. Page generated in 0.08498 seconds
