EMF Notification: how to not get our own modifications? [message #965947] |
Wed, 31 October 2012 12:31  |
I have two pieces of code modifying the same EMF model.
When one modifies it, notifications are sent, to everyone, including the one that modifies it.
Is there any way to detect who did the modification that made the notification happen?
My only need is to be able, when I modify a model, to detect in my listener that I was the one actually modifying the model.
Thank you for any help :)
Re: EMF Notification: how to not get our own modifications? [message #966232 is a reply to message #965947] |
Wed, 31 October 2012 17:29   |
Victor,
There's no way to know what/who caused the change. Of course if you did
the modification, you already know you'll get a notification for that...
On 31/10/2012 5:31 PM, Victor Mising name wrote:
Re: EMF Notification: how to not get our own modifications? [message #966875 is a reply to message #966232] |
Thu, 01 November 2012 05:53   |
An approach that I've used to break similar selectionChanged loops is to
have a private e.g. selectionChanging normally falsevariable. In the
handler, if the variable is false is it is set true to indicate
processing a selection change and restored in a finally clause. If
already set you know that you're in a nested loop and should probably
just return promptly.
Ed Willink
On 31/10/2012 21:29, Ed Merks wrote:
> Victor,
> did the modification, you already know you'll get a notification for
> that...
>> Hi,
FUDForum. Page generated in 0.04520 seconds
