Home » Modeling » GMF (Graphical Modeling Framework) » generating problem after upgrading to GMF2.0M4
generating problem after upgrading to GMF2.0M4 [message #96632] Thu, 25 January 2007 06:43 Go to next message
Originally posted by: sh.wilken.de
Hi friends,
After upgrading to 2.0M4 we have some merging problems concerning
protected methods by "@generated NOT".
If we change the code of a method and mark it by "@generated NOT", we
got a second method with the same name after the next generation like
the following example
* Creates figure for this edit part.
* Body of this method does not depend on settings in
* generation model
* so you may safely remove <i>generated</i> tag and modify it.
* @generated NOT
protected NodeFigure createMainFigure() {
NodeFigure figure = createNodePlate();
figure.setLayoutManager(new StackLayout());
IFigure shape = createNodeShape();
figure.add(shape);
shape.setBackgroundColor(ColorConstants.lightGreen);
contentPane = setupContentPane(shape);
return figure;
* generation model
* @generated
figure.add(shape);
return figure;
Any ideas how we can fix this problem ?
thanks and regards
Sascha
Re: generating problem after upgrading to GMF2.0M4 [message #96693 is a reply to message #96632] Thu, 25 January 2007 07:38 Go to previous message
Hello Sascha_Hänsch,
Looks like a problem described in: https://bugs.eclipse.org/bugs/show_bug.cgi?id=168713
Alex Shatalin
Previous Topic:Re: Is it possible to create a connection before its source and target elements are created?
Next Topic:Initialization of diagramfile from existing domainmodel incomplete
Current Time: Sun Nov 02 20:43:03 EST 2025
Powered by FUDForum. Page generated in 0.04393 seconds
