Custom focusable component [message #950551] |
Fri, 19 October 2012 20:51  |
I have following widget layout:
Composite
|MyCustomPanel
||Label
||Button
|MyCustomPanel
||Label
||Button
"MyCustomPanel" is a custom class subclassing Composite.
What I need is the focus cycling between "MyCustomPanel" instances when the user presses tab - e.g. panels must get the focus events and buttons should not get the focus. Currently (I'm on GTK) focus is aquired by buttons.
Is there a way to do it in SWT?
Re: Custom focusable component [message #966053 is a reply to message #950551] |
Wed, 31 October 2012 14:13  |
Hi, sorry for the late reply,
I think the following snippet demonstrates what you need. It has a
Composite (with child Button) that can receive focus, and handles its
own traversals. The only case the snippet does not address is if focus
is in the control following the Composite and a user Ctrl+Tab's
backwards into the Composite, which will leave focus in its child
button. To handle this I think the Composite has to add FocusIn
listeners to all of its children, and take the focus for itself when
this happens.
public class ModifiedSnippet21 {
public static void main (String [] args) {
Display display = new Display ();
final Color red = display.getSystemColor (SWT.COLOR_RED);
final Color blue = display.getSystemColor (SWT.COLOR_BLUE);
Shell shell = new Shell (display);
shell.setLayout(new GridLayout());
final Button defaultButton = new Button (shell, SWT.PUSH);
defaultButton.setText ("Default Button");
shell.setDefaultButton (defaultButton);
defaultButton.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
System.out.println("default button selection");
defaultButton.addListener (SWT.FocusIn, new Listener () {
public void handleEvent (Event e) {
System.out.println("defaultButton focus in");
defaultButton.addListener (SWT.FocusOut, new Listener () {
System.out.println("defaultButton focus out");
final Composite composite = new Composite (shell, SWT.BORDER);
composite.setLayout(new GridLayout());
Button childButton = new Button(composite, SWT.PUSH);
childButton.setText("child button");
composite.addListener (SWT.FocusIn, new Listener () {
System.out.println("composite focus in");
composite.setBackground (red);
composite.addListener (SWT.FocusOut, new Listener () {
System.out.println("composite focus out");
composite.setBackground (blue);
composite.addListener (SWT.KeyDown, new Listener () {
System.out.println ("keypress in composite");
final Text text = new Text (shell, SWT.SINGLE | SWT.BORDER);
composite.addListener (SWT.Traverse, new Listener () {
switch (e.detail) {
/* Do tab group traversal */
case SWT.TRAVERSE_ESCAPE:
case SWT.TRAVERSE_RETURN:
case SWT.TRAVERSE_PAGE_NEXT:
case SWT.TRAVERSE_PAGE_PREVIOUS:
case SWT.TRAVERSE_TAB_PREVIOUS:
e.doit = true;
break;
case SWT.TRAVERSE_TAB_NEXT:
/* custom traversal, skips the child button */
e.doit = false;
text.setFocus();
break;
composite.setFocus ();
shell.pack ();
shell.open ();
while (!shell.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
HTH,
Grant
> Composite
> |MyCustomPanel
> ||Label
> ||Button
> |MyCustomPanel
> ||Label
> ||Button
> buttons.
FUDForum. Page generated in 0.04740 seconds
