Need help on submodules support with jgit API. [message #965710] |
Wed, 31 October 2012 08:56 |
Hi All,
I'm trying to clone a repository on github which has submodules within it. The code i'm using to clone the repository is
String PATH = "C:/Madhu/GIT/Submodules";
File directory = new File(PATH);
FileRepositoryBuilder builder = new FileRepositoryBuilder();
Repository repository = builder.setGitDir(directory).readEnvironment().findGitDir().build();
Git git = new Git(repository);
CloneCommand clone = git.cloneRepository();
clone.setCloneSubmodules(true);
clone.setDirectory(directory).setURI("URL_TO_GITHUB_REPOSITORY");
UsernamePasswordCredentialsProvider user = new UsernamePasswordCredentialsProvider("username", "password");
clone.setCredentialsProvider(user);
clone.call();
I can see the repository created on my local directory. i can also see the .gitmodules file which has the list of submodules within it. I need to parse through all the submodules to get the path and the url of each submodules. For this purpose i'm trying to create a SubmoduleWalk. The code snippet i'm using to create a SubmoduleWalk is
SubmoduleWalk generator = SubmoduleWalk.forIndex(git.getRepository());
generator.setTree(new DirCacheIterator(git.getRepository().readDirCache()));
when i execute the above code snippet, i'm getting the below exception
Exception in thread "main" org.eclipse.jgit.errors.NoWorkTreeException: Bare Repository has neither a working tree, nor an index
at org.eclipse.jgit.lib.Repository.getIndexFile(Repository.java:967)
at org.eclipse.jgit.dircache.DirCache.read(DirCache.java:166)
at org.eclipse.jgit.lib.Repository.readDirCache(Repository.java:991)
at org.eclipse.jgit.submodule.SubmoduleWalk.forIndex(SubmoduleWalk.java:95)
at git.clone.GitClone.main(GitClone.java:49)
I'm using jgit version 2.1.0.201209190230-r.
I had read about insufficient support for submodules in jgit. I believe this is fixed with the version 1.2 or higher.
Can anyone please suggest what might be wrong in this case? Any help is much appreciated.
Thank you.
Madhusudhan
FUDForum. Page generated in 0.04135 seconds
