Script task doesn't display Script Format dropdown [message #957968] |
Thu, 25 October 2012 12:41  |
Updated both an Eclipse Indigo and Eclipse Juno install using the BPMN site http://download.eclipse.org/bpmn2-modeler/site/ and all appeared to work correctly.
However, when I insert a Script task into a bpmn process diagram, then open the properties dialog, the script format dropdown doesn't exist, instead I see a label that says "Script Format" followed by "text/xml". My coworker gets a dropdown menu there that offers Java and MVEL. How come I don't get those choices?
Also, the place where there should be a drop down isn't even outlined to make it appear like a data entry text box, it just looks like the words are part of the label, but I can click there and change the value. Same goes for the script box beneath it. I just see a label that says "Script" and I have to know that if I click to the right of it somewhere, I can start typing. There's no visual clue.
I assume there's an incompatibility with other Indigo/Juno components like EMF or GEF, but no amount of updating those things fixes the problem.
FUDForum. Page generated in 0.04288 seconds
