Home » Modeling » Graphiti » Create graphical elements by create new diagram
Create graphical elements by create new diagram [message #963181] Mon, 29 October 2012 12:22 Go to next message
i need some help. I want to create some graphical elements while create a new diagram. This elements are not parts of the model, only a graphical representation. For example it should visualize the user a start point as dot. So i create a dummy class, create an AddFeature and CreateFeature. I tried to trigger the creation of this element inside the DiagramProvider.postInit(), but get an exception:
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
What is the correct approach to this? By create a new diagram, there should be a simple dot as start point inside the diagram?
Markus
Re: Create graphical elements by create new diagram [message #964293 is a reply to message #963181] Tue, 30 October 2012 08:07 Go to previous messageGo to next message
Markus,
you need to execute your features within a write transaction for the
resource set/transactional editing domain. This is due to Graphiti using EMF
Transactions underneath. Simply execute your feature on the command stack of
the editor, there is a executeFeature method in DiagramEditor that does
exactly that.
Michael
Re: Create graphical elements by create new diagram [message #964369 is a reply to message #964293] Tue, 30 October 2012 09:16 Go to previous messageGo to next message
Thnaks for help. Now it works fine by execute this as command.
Re: Create graphical elements by create new diagram [message #983962 is a reply to message #964369] Wed, 14 November 2012 04:34 Go to previous messageGo to next message
Hi Michael,
I am also getting same error and as per your suggestion I try to execute my add feature on the command stack of editor using executeFeature method in DiagramEditor.
The following assert in DiagramEditor gives me Nullpointer Error:
DefaultEditDomain domain = getEditDomain();
        // Make sure the editor is valid
        Assert.isNotNull(domain);
Is there something that I am missing?
Re: Create graphical elements by create new diagram [message #985797 is a reply to message #983962] Fri, 16 November 2012 03:34 Go to previous messageGo to next message
Hemlata,
it seems that the editor is not correctly initialized. This method will only
work with a correctly opened editor. How do you retrieve that editor?
Michael
Re: Create graphical elements by create new diagram [message #985842 is a reply to message #985797] Fri, 16 November 2012 05:58 Go to previous messageGo to next message
I use following stuff to create my diagram and open it :
IWorkbenchPage page = PlatformUI.getWorkbench()
                    .getActiveWorkbenchWindow().getActivePage();
      IEditorInput input = getEditorInput();
      // Create the pictogram for selected object
      final Diagram diagram = Graphiti.getPeCreateService()
                    .createDiagram(DIAGRAM_TYPE, object.getName(),
                            false);
       DiagramEditor editor = new DiagramEditor();
       final DiagramTypeProvider dtyProvider = (DiagramTypeProvider) ExtensionManager
                    .getSingleton().createDiagramTypeProvider(
                            DIAGRAM_TYPE_PROVIDER_ID);
       dtyProvider.init(diagram, editor);
       page.openEditor(input, DiagramEditor.DIAGRAM_EDITOR_ID);
and the getEditorInput() is as follows:
public static IEditorInput getEditorInput() throws Exception {
        DiagramEditorInput result = null;
        final IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
        final IProject project = root.getProject("Graphiti");
          IFile diagramFile = project.getFile("Test" + "." + "diagram");
        URI emfURI = URI.createURI(diagramFile.getFullPath().toString());
            if (emfURI != null) {
            URI diagramUri = emfURI.appendFragment("/0");
            result = new   DiagramEditorInput(diagramUri,
                         DiagramTypeProvider.DIAGRAMTYPE_PROVIDER_ID);
        return result;
Re: Create graphical elements by create new diagram [message #986729 is a reply to message #985842] Wed, 21 November 2012 08:23 Go to previous message
Hemlata,
why do you construct a DiagramEditor by yourself? All you should need to do
is create a DiagramEditorInput instance and pass it to
The diagram needs to be persisted in file.
Michael
Previous Topic:Getting started with non EMF Domain Models, need an example
Next Topic:Export Graphiti diagram image via API
Current Time: Sat Jul 26 02:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.05331 seconds
