Re: virgo distribution without user region and with repository [message #964284 is a reply to message #964254] |
Tue, 30 October 2012 07:56  |
Hi Yousef,
p2 is basically a dependency resolution manager + installer. In terms of capabilities it is very similar to the Virgo deployment pipeline and Eclipse has been using it for installations and dependency management for 5 years already.
Let me see if I got the use case right. All you need is some way to provision a bundle on top of the server.
When does this happen - is there some kind of trigger for installing the listener? Or it is a static declaration and you just want it installed.
Since you're describing it in the tomcat-server.xml descriptor I assume it's the latter - you just want it statically installed with the server.
One way to achieve this is to drop the listener in pickup.
Another is to export it from Eclipse as a p2 repository and then use the p2 commands to install your listener from the p2 repository onto the server with any dependencies it may have.
Best Regards
Bobby
FUDForum. Page generated in 0.81607 seconds
