Home » Archived » Test and Performance Tools Platform (TPTP) » Unable to get SampleClient working on RHEL4 Linux-EM64T platform
Unable to get SampleClient working on RHEL4 Linux-EM64T platform [message #93904] Thu, 22 March 2007 02:10 Go to next message
I am unable to get the basic SampleClient(TPTP 4.3.1) TPTP test on
Linux EM64T platform.
<CommonBaseEvent creationTime="2007-03-22T05:45:46.881855Z"
globalInstanceId="A602180A000D74B95F0F28A91296DAFC" msg="Agent not
found" severity="50" version="1.0.1"> <sourceComponentId
component="AgentController" componentIdType="TPTPComponent"
executionEnvironment="AgentManager.c, line 3640" instanceId="1"
location="be-qarhas42" locationType="IPV4" processId="21044"
subComponent="Agent Manager" threadId="21044" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL"
reportCategory="LOG"/> </situation></CommonBaseEvent>
I have the PATH and LD_LIBRARY_PATH set as explained in readme.txt.
LD_LIBRARY_PATH=/usr/java/jdk1.5.0_11/jre/lib/amd64/server:/ opt/software/eclipse/3.2.2/lib/agntctrl/plugins/org.eclipse. tptp.javaprofiler:/opt/software/eclipse/3.2.2/lib/agntctrl/l ib:/opt/software/eclipse/3.2.2/lib/agntctrl/plugins/org.ecli pse.hyades.perfmon.linux/lib:
PATH=/usr/kerberos/sbin:/usr/kerberos/bin:/opt/software/ecli pse/3.2.2/lib/agntctrl/bin:/opt/software/eclipse/3.2.2/eclip se:/usr/java/jdk1.5.0_11/bin:/opt/oracle/app/oracle/product/ 10.2.0/db_1/bin:/usr/tibco/tibrv/bin:/usr/local/sbin:/usr/lo cal/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/b in
I have also changed the agent/org**TimeCollector/agent.xml to make the
executable="TimeCollector".
What else am I missing ?
-Pranab
Re: Unable to get SampleClient working on RHEL4 Linux-EM64T platform [message #96353 is a reply to message #93904] Wed, 18 April 2007 17:09 Go to previous messageGo to next message
Originally posted by: davidbbs.stanford.edu
Pranab,
I'm having a similar problem on CentOS 4.1, AMD x86 64bit, jdk1.5.0_5
64bit.
I've found that if I manually run ./TimeCollector the SampleClient
runs just fine, but if I don't then it fails.
However, when I look at the debug log for the ACServer I see the
following:
msg="Couldn't load JVM library libjvm.so" severity="30"
If I manually add /usr/java/jdk1.5.0_05/jre/lib/amd64/server/libjvm.so
to my $LD_LIBRARY_PATH, that goes away, but then I get the following:
Starting Agent Controller.
Exception in thread "Thread-0" java.lang.NoClassDefFoundError:
org/eclipse/hyades/internal/execution/file/FileServer
ACServer started successfully.
and it still doesn't work. I can't find the .jar file for
hyades.internal.execution anywhere, so I'm not sure how to put this on a
class path.
Have you had any luck with this? I've been fighting with this thing
for 2 days now with no luck on a clean Eclipse install following the
provided directions as well as I can.
-David
In article <ett6kd$o2n$1@utils.eclipse.org>,
Pranab Dhar <pkd46307@yahoo.com> wrote:
> se/3.2.2/lib/agntctrl/plugins/org.eclipse.tptp.javaprofiler: /opt/software/ecli
> pse/3.2.2/lib/agntctrl/lib:/opt/software/eclipse/3.2.2/lib/a gntctrl/plugins/or
> g.eclipse.hyades.perfmon.linux/lib:
> ctrl/bin:/opt/software/eclipse/3.2.2/eclipse:/usr/java/jdk1. 5.0_11/bin:/opt/or
> acle/app/oracle/product/10.2.0/db_1/bin:/usr/tibco/tibrv/bin :/usr/local/sbin:/
> usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/ root/bin
> -Pranab
Re: Unable to get SampleClient working on RHEL4 Linux-EM64T platform [message #96382 is a reply to message #96353] Wed, 18 April 2007 18:03 Go to previous message
I tried installing the 3.3M6 build of Eclipse and the latest 4.4 build
of TPTP. (The one with the included ACServer in the Eclipse plugin
directory.) This gives me exactly the same behavior as before: namely
when I manually run the ACStart.sh script and then try the SampleClient
it fails. If I manually run the TimeCollector after starting the
ACServer it works.
Any ideas as to why this isn't working?
This is probably a hint, but I don't know how to fix it:
-David
In article <davidbbs-DEB016.14092018042007@news.eclipse.org>,
David <davidbbs@stanford.edu> wrote:
> Pranab,
> 64bit.
> following:
> class path.
> -David
> > Hi,
> > ip
> > li
> > or
> > nt
> > or
> > -Pranab
Previous Topic:sending command to agentcontroller
Next Topic:Set Stop Time
Current Time: Fri Jul 25 22:20:41 EDT 2025
Powered by FUDForum. Page generated in 0.06207 seconds
