Home » Eclipse Projects » EclipseLink » EntityManager.find(...) with pessimistic lock never throws LockTimeoutException
EntityManager.find(...) with pessimistic lock never throws LockTimeoutException [message #963249] Mon, 29 October 2012 13:24 Go to next message
In my code I set a pessimistic lock on a table row with following code:
Map<String,Object> properties = new HashMap<String, Object>();
properties.put("javax.persistence.lock.timeout", 2000);
// GetEm() returns the currently used entity manager
getEm().find(objClass, id, LockModeType.PESSIMISTIC_WRITE, properties);
This works and the lock is really set, but if an other client tries to set a lock on the same row the LockTimeoutException is never thrown, it just hangs on the find(...) method call until the other client releases the lock (which can be up to 5 minutes).
What am I doing wrong here? I found the same example at several places always always with the comment that this exception will be thrown...
I'm using
EclipseLink 2.4.1 (also didn't work with 2.3.2)
Postgresql
javax.Persistence 2.0.4
Re: EntityManager.find(...) with pessimistic lock never throws LockTimeoutException [message #964621 is a reply to message #963249] Tue, 30 October 2012 13:11 Go to previous messageGo to next message
What database platform are you using?
Can you turn on logging and see what the SQL that gets executed is? Does this work on a JPQL query?
Best Regards,
Chris
Re: EntityManager.find(...) with pessimistic lock never throws LockTimeoutException [message #964756 is a reply to message #964621] Tue, 30 October 2012 15:28 Go to previous messageGo to next message
Not all databases support lock/query timeouts. Check that Postgresql can support this.
Re: EntityManager.find(...) with pessimistic lock never throws LockTimeoutException [message #965975 is a reply to message #964756] Wed, 31 October 2012 12:56 Go to previous message
The following sql statement is executed:
SELECT ... WHERE (ID = ?) FOR UPDATE
which is blocking.
Like that:
SELECT ... WHERE (ID = ?) FOR UPDATE NOWAIT
it would be none blocking, but returning directly on failure.
It seems like postgresql doesn't support any locking timeout (thanks for the hint james).
It supports a statement_timeout, but unfortunately it isn't implemented in the JDBC driver.
Seems like it is not a eclipselink issue, but it would be nice, if there is a comment or something in the documentation, which states that the timeout isn't supported on all databases, it would have led me in the right direction of search...
I will try to get it work with the statement_timeout, something like:
java.sql.Connection cn = getEm().unwrap(java.sql.Connection.class);
cn.createStatement().execute("SET statement_timeout TO 1000");
Previous Topic:NPE in CascadeLockingPolicy.initUnmappedFieldsQuery
Next Topic:The attribute type must implement the Serializable interface.
Current Time: Sat Jul 26 03:00:23 EDT 2025
Powered by FUDForum. Page generated in 0.04311 seconds
