Customized Palette for Stereotypes with String Properties [message #962727] |
Mon, 29 October 2012 05:26  |
I have a profile that contains stereotypes with a string property (multiplicity 1) and extends CombinedFragment. As default value I set LiteralString with an empty string. I registered the profile using the extension point org.eclipse.papyrus.uml.extensionpoints.UMLProfile.
In the runtime workspace, I created a customized palette. I selected the tool for the CombinedFragment and set the list of applied stereotypes. When I use the tool, the stereotype for the drawn CombinedFragment is not applied.
It does not matter if the aggregation of the property is set to "none" or "composite".
It does not matter if I check the property in the "Stereotypes to Apply" section of the palette customization dialog. The only difference then, when I draw the stereotype, I get an additional dialog "You can edit there properties". But the stereotype is not applied anyway.
Is this a bug of Papyrus, am I using the palette customization wrong or is there something from with my profile?
Simon
FUDForum. Page generated in 0.03293 seconds
