Home » Modeling » EMF » [CDO] Starting sequence of IAppExtensions
[CDO] Starting sequence of IAppExtensions [message #959372] Fri, 26 October 2012 13:11 Go to next message
Hello
I have created an IAppExtension for our CDO/Hibernate server. This extension uses JVM to connect to the server.
My problem is: Depending on the starting order of the IAppExtensions, I sometimes get an error that the JVM acceptor "default:0" could not be found. I found that the acceptor is initiated with the Net4jAppExtension. So when Net4jAppExtension is started first everything is fine. If my new AppExtension is started first, it can't connect.
The acceptor is defined in the cdo-server.xml:
<cdoServer>
    <acceptor type="jvm" listenAddr="default" port="0"/>
    <acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
</cdoServer>
This is the code that establishes the JVM session:
private CDOSession openSession() {
	if (sessionConfiguration == null) {
		logger.info("Initialisiere CDO Configuration ...");
		initialize();
	final CDONet4jSession cdoSession = sessionConfiguration.openNet4jSession();
	return cdoSession;
private void initialize() {
	// Prepare container
	final IManagedContainer container = ContainerUtil.createContainer();
	Net4jUtil.prepareContainer(container); // Register Net4j factories
	JVMUtil.prepareContainer(container); // Register JVM factories
	CDONet4jUtil.prepareContainer(container); // Register CDO factories
	container.activate();
	// Create connector
	if (connector == null) {
		logger.info("Erstelle JVMUtil Connector");
		connector = JVMUtil.getConnector(container, "default:0");
	// Create configuration
	logger.info("Erstelle CDOSessionConfiguration zu: {}", REPO_NAME);
	sessionConfiguration = CDONet4jUtil.createNet4jSessionConfiguration();
	sessionConfiguration.setConnector(connector);
	sessionConfiguration.setRepositoryName(REPO_NAME);
My questions are:
1. Do I need to initialize the acceptor? If yes, how?
2. Is it possible to set the order of AppExtension execution?
Any additional hints are also most welcome.
Thank you!
Christoph
Re: [CDO] Starting sequence of IAppExtensions [message #960223 is a reply to message #959372] Sat, 27 October 2012 05:30 Go to previous messageGo to next message
Hi Christoph,
I think this has been asked before but I couldn't find that thread either. The solution is to listen to IContainerEvents
from IPluginContainer.INSTANCE, if the repository/acceptor is not available there immediately. You can overwrite
ContainerEventAdapter.onAdded() to react to later container element additions. Does that help?
Cheers
/Eike
http://www.esc-net.de
Am 26.10.2012 19:11, schrieb Christoph Keimel:
> Hello
> <cdoServer>
> </cdoServer>
> initialize();
> return cdoSession;
> // Create connector
> My questions are:
> Thank you!
> Christoph
Re: [CDO] Starting sequence of IAppExtensions [message #961501 is a reply to message #960223] Sun, 28 October 2012 06:26 Go to previous messageGo to next message
Hi Eike,
thanks for the Input. I'm still stuck though, so I would be gratefull if you could give me another pointer.
This is the way I am processing at the moment:
private void process() {
	final IManagedContainer container = createContainer();
	try {
		IConnector connector = JVMUtil.getConnector(container, ACCEPTOR_NAME);
		continueProcess(connector);
	} catch (IllegalStateException e) {
		logger.info("Installiere ContainerListener");
		IPluginContainer.INSTANCE.addListener(new ContainerEventAdapter<Object>() {
			protected void onAdded(IContainer<Object> cont, Object element) {
				if (element instanceof JVMAcceptor) {
					JVMAcceptor acceptor = (JVMAcceptor) element;
					if (acceptor.getName().equals(ACCEPTOR_NAME)) {
						//JVMUtil.getAcceptor(container, ACCEPTOR_NAME);
						//IConnector connector = JVMUtil.getConnector(IPluginContainer.INSTANCE, ACCEPTOR_NAME);
					IPluginContainer.INSTANCE.removeListener(this);
I am waiting for the Acceptor to be added before I continue with the processing. This still leads to the same error because the Acceptor is still not available in my container and passing IPluginContainer.INSTANCE to JVMUtil.getConnector produces the same result.
If I manually add the Acceptor with JVMUtil.getAcceptor, I get a different exception:
org.eclipse.net4j.channel.ChannelException: org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.net4j.serverProtocols[cdo]
	at org.eclipse.net4j.internal.jvm.JVMConnector.registerChannelWithPeer(JVMConnector.java:135)
Which I don't realy understand since this factory is contributed by the plug-in org.eclipse.emf.cdo.server.net4j which is part of my product configuration and it should be activated, since the listener is triggered by code in the Net4jAppExtension contributed by the same plug-in.
I was looking for an event signalling the end of the startup process, but couldn't see anything in CdoServerApp. Starting the IAppExtension(s) is the last thing that happens, so I am not sure what I am missing.
Greetings
Christoph
Re: [CDO] Starting sequence of IAppExtensions [message #961515 is a reply to message #961501] Sun, 28 October 2012 06:38 Go to previous messageGo to next message
Hi Christophe,
It's probably easier to not depend on other IAppExtensions at all. You could create the JVMAcceptor/JVMCOnnector pair in
your own extension.
More comments below...
Am 28.10.2012 11:26, schrieb Christoph Keimel:
> Hi Eike,
> try {
> @Override
And is it? You can check on the OSGi console with "ss".
These things are so dependent on your deployment. Can you provide me with a small and executable example?
Cheers
/Eike
Re: [CDO] Starting sequence of IAppExtensions [message #961565 is a reply to message #961515] Sun, 28 October 2012 07:34 Go to previous messageGo to next message
Hi Eike,
Yes. I don't realy want to depend on Net4jAppExtension. The way I read the source, this extionsion is responsible for reading the config and creating the acceptors.
> You could create the JVMAcceptor/JVMCOnnector pair in your own extension.
Yes, I think I will go for this solution: Take the jvm acceptor out of the cdo-server.xml and configure it by hand.
The plug-in is activated:
16 ACTIVE org.eclipse.emf.cdo.server.net4j_4.0.100.qualifier
I tried to create an example deployment. It is based on hibernate using mysql. I don't know, if you will be able to reproduce the error, because it depends on the order in which the extensions are executed ... if the Net4j extension runs first everything is fine. (Which is exactly what is happening when I execute the test here Sad )
Thanks for your support!
Greetings
Christoph
Re: [CDO] Starting sequence of IAppExtensions [message #961582 is a reply to message #961565] Sun, 28 October 2012 07:55 Go to previous messageGo to next message
Did you try to set the start level of your plugin to a higher value than org.eclipse.emf.cdo.server.net4j?
This way, your extension will *always* start later than net4j's...
Re: [CDO] Starting sequence of IAppExtensions [message #961613 is a reply to message #961565] Sun, 28 October 2012 08:32 Go to previous messageGo to next message
Hi Everybody,
I found the solution to the problem. Instead of creating my own container, I need to use IPluginContainer.INSTANCE from the beginning. I also removed the acceptor from cdo-server.xml. The acceptor is now manually created with: JVMUtil.getAcceptor(IPluginContainer.INSTANCE, ACCEPTOR_NAME).
So it's actually very simple to start a JMV connection independent from the Net4jAppExtension:
public void start(File configFile) throws Exception {
	IManagedContainer container = IPluginContainer.INSTANCE;
	CDOSession session = sessionConfiguration.openNet4jSession();
Thanks for the help.
Christoph
Re: [CDO] Starting sequence of IAppExtensions [message #961767 is a reply to message #961613] Sun, 28 October 2012 11:27 Go to previous messageGo to next message
Am 28.10.2012 13:32, schrieb Christoph Keimel:
> Hi Everybody,
> from the beginning.
Oh, I overlooked this in your first post:
Yes, that's basically the same what happens in the Net4jAppExtension.
Good that you figured out how to do it ;-)
Cheers
/Eike
Re: [CDO] Starting sequence of IAppExtensions [message #961768 is a reply to message #961582] Sun, 28 October 2012 11:27 Go to previous message
Am 28.10.2012 12:55, schrieb Erdal Karaca:
Good idea! I must remember this...
Cheers
/Eike
Previous Topic:Understanding CDO
Next Topic:serialize non-containment reference
Current Time: Sun Jul 27 07:54:41 EDT 2025
Powered by FUDForum. Page generated in 0.04580 seconds
