Could I create jdt projects in the workspace as result of a xtext generator ? [message #951682] |
Sat, 20 October 2012 19:36  |
I'm researching for a new dsl, to see if is possible and would like some tips from the list.
I'm thinking in a grammar like this:
Model:
'baseDir' basedir = STRING
components+=Component*;
Component:
'component' name=ID
'Bundle-SymbolicName' symb=STRING
component comp1{
Bundle-SymbolicName "my.bundle.project"
The idea is to create one project in the workspace for each Component in model, maybe using JDT.
Could someone tell me if this would be possible and what route to follow?
regards
Re: Could I create jdt projects in the workspace as result of a xtext generator ? [message #961547 is a reply to message #951682] |
Sun, 28 October 2012 07:11  |
So you would like to create, from the generator, other projects right?
You can create projects programmatically with eclipse APIs; xtext.junit*
plugins offer some utility methods to create projects programmatically
even more easily.
I'm using these utility methods in some UI tests
(http://sourceforge.net/p/xsemantics/code/ci/68395a1c0bed6fa2f3cdf7a0220a49d4f27c98ae/tree/examples/it.xsemantics.example.lambda.tests/src/it/xsemantics/example/lambda/tests/ui/LambdaIntegrationTest.java)
here's a snippet
import static org.eclipse.xtext.ui.junit.util.IResourcesSetupUtil.addNature;
import static
org.eclipse.xtext.ui.junit.util.IResourcesSetupUtil.cleanWorkspace;
import static
org.eclipse.xtext.ui.junit.util.IResourcesSetupUtil.createFile;
import static
org.eclipse.xtext.ui.junit.util.IResourcesSetupUtil.waitForAutoBuild;
import static
org.eclipse.xtext.ui.junit.util.JavaProjectSetupUtil.addSourceFolder;
import static
org.eclipse.xtext.ui.junit.util.JavaProjectSetupUtil.createJavaProject;
@Test
public void testValidSimpleLambdaProgram() throws Exception {
createJavaProjectWithRootSrc("foo");
IFile file = createFile("foo/src/foo.lambda", "lambda x. x");
waitForAutoBuild();
assertNoErrorMarkers(file);
private IJavaProject createJavaProjectWithRootSrc(String string)
throws CoreException {
IJavaProject project = createJavaProject(string);
addNature(project.getProject(), XtextProjectHelper.NATURE_ID);
addSourceFolder(project, "src");
return project;
hope this helps
Lorenzo
On 10/21/2012 01:36 AM, Cristiano Gaviao wrote:
> tips from the list.
> Model:
> Component:
> 'component' name=ID
> 'Bundle-SymbolicName' symb=STRING '}'
> component comp1{
> regards
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
FUDForum. Page generated in 0.04449 seconds
