Home » Modeling » GMF (Graphical Modeling Framework) » HELP -> RenderedMapModeGraphics(java.lang.RuntimeException: The class: class org.eclipse.gmf.runtime.draw2d.ui.render.internal.graphics.RenderedMapModeGraphics has not implemented this new graphics function)
HELP -> RenderedMapModeGraphics [message #959362] Fri, 26 October 2012 13:04
Dear friends of the GMF Group
I wonder how I do to solve the problem of the Path class, I'm using the methods "drawPath" and "fillPath". Have any solution to this problem, or is it more of a BUG.
An error has occurred. See error log for more details.
at org.eclipse.draw2d.Graphics.subclassFunctionMission(Graphics.java:897)
at org.eclipse.draw2d.Graphics.fillPath(Graphics.java:437)
at org.eclipse.stp.bpmn.figures.AdditionalParticipantFigure.paintFigure(AdditionalParticipantFigure.java:87)
at org.eclipse.draw2d.Figure.paint(Figure.java:1049)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1087)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1119)
at org.eclipse.draw2d.Figure.paint(Figure.java:1051)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1114)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:156)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at org.eclipse.stp.bpmn.figures.PoolPoolCompartmentFigure.paint(PoolPoolCompartmentFigure.java:123)
at org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientArea(ScalableFreeformLayeredPane.java:61)
at org.eclipse.gmf.runtime.draw2d.ui.internal.graphics.ScalableFreeformLayeredPane.paintClientArea(ScalableFreeformLayeredPane.java:82)
at org.eclipse.stp.bpmn.figures.splitviewsupport.FreeFormViewPortWithSplitters.paintClientArea(FreeFormViewPortWithSplitters.java:54)
at org.eclipse.draw2d.DeferredUpdateManager.paint(DeferredUpdateManager.java:155)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem.java:199)
at org.eclipse.draw2d.LightweightSystem$2.handleEvent(LightweightSystem.java:107)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1323)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3842)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528)
at org.eclipse.swt.internal.win32.OS.RedrawWindow(Native Method)
at org.eclipse.swt.widgets.Control.update(Control.java:3651)
at org.eclipse.swt.widgets.Control.update(Control.java:3641)
at org.eclipse.draw2d.NativeGraphicsSource.getGraphics(NativeGraphicsSource.java:43)
at org.eclipse.draw2d.DeferredUpdateManager.getGraphics(DeferredUpdateManager.java:138)
at org.eclipse.draw2d.DeferredUpdateManager.repairDamage(DeferredUpdateManager.java:292)
at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(DeferredUpdateManager.java:181)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer$ToggleUpdateManager.performUpdate(DiagramGraphicalViewer.java:114)
at org.eclipse.draw2d.LightweightSystem.controlResized(LightweightSystem.java:122)
at org.eclipse.draw2d.LightweightSystem$1.controlResized(LightweightSystem.java:102)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:222)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.WM_SIZE(Control.java:4435)
at org.eclipse.swt.widgets.Scrollable.WM_SIZE(Scrollable.java:359)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:1522)
at org.eclipse.swt.widgets.Canvas.WM_SIZE(Canvas.java:449)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3860)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2366)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:79)
at org.eclipse.swt.widgets.Control.WM_WINDOWPOSCHANGED(Control.java:4592)
at org.eclipse.swt.widgets.Canvas.WM_WINDOWPOSCHANGED(Canvas.java:455)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3870)
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1302)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2627)
at org.eclipse.swt.widgets.Composite.setBounds(Composite.java:892)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2588)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2584)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2651)
at org.eclipse.gef.ui.rulers.RulerComposite.doLayout(RulerComposite.java:209)
at org.eclipse.gef.ui.rulers.RulerComposite.layout(RulerComposite.java:272)
at org.eclipse.gef.ui.rulers.RulerComposite$4.handleEvent(RulerComposite.java:308)
at org.eclipse.swt.internal.win32.OS.EndDeferWindowPos(Native Method)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.java:822)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.java:788)
at org.eclipse.swt.widgets.Composite.setResizeChildren(Composite.java:1012)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:1537)
at org.eclipse.swt.layout.FillLayout.layout(FillLayout.java:201)
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.java:1144)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:1533)
at org.eclipse.ui.internal.LayoutPart.setBounds(LayoutPart.java:300)
at org.eclipse.ui.internal.presentations.PresentablePart.setBounds(PresentablePart.java:170)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.layoutContent(PresentablePartFolder.java:131)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.layout(PresentablePartFolder.java:412)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:292)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:217)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:207)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:779)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:678)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:639)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2817)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2673)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2668)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2652)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:318)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:207)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:363)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$5.open(PackageExplorerPart.java:603)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:818)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1079)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:297)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
  • Attachment: ERROR.png
    (Size: 24.53KB, Downloaded 196 times)
Previous Topic:Error when importing the GMF source projects
Next Topic:GMF EXPORT DIAGRAM AS XML
Current Time: Sun Aug 31 07:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.03268 seconds
