Ecore 2 Ecore - Could use some input [message #958045] |
Thu, 25 October 2012 14:06  |
Hi there,
I have to write some UI for a predefined ecore which is quite large and cannot be altered by myself. Apart from that this ecore provides several really inconvenient constructs. F.e.
- From a semantical point of view there is a datatype definition Enumeration, Primitive, Record which will be established by a single model type DataType. The semantical distinction has to be made by several attribute/element values provided with that type.
- Another thing is that there are several types which are basically identical as they provide exactly the same information (same attributes, same references etc.). They are simple redundant so there are type like RValue, LValue, ZValue which are equal but still different types.
From my development perspective I would like to simplify the application code which is somewhat ugly as it's necessary to deal with the abovementioned differences.
So I basically intend to use my own ecore internally which would achieve something like this:
- Instead of the model element DataType I will get distinctive model elements Enumeration, Primitive and Record .
- The redundant types RValue, LValue and ZValue should be mapped into something like this: Value [ type : {R, L, Z} ] .
Looking for such a possibility I found ecore2ecore. Unfortunately I failed to locate thorough tutorials/documentation about it.
So here are my questions:
1. Are my goals achievable using ecore2ecore or did I miss something ?
2. Where can I find detailed infos about it ?
3. Does anyone know about another technology to realize my goals ?
Thanks in advance.
Bye
Kasimir
Re: Ecore 2 Ecore - Could use some input [message #959254 is a reply to message #958045] |
Fri, 26 October 2012 11:13   |
Daniel,
Comments below.
On 26/10/2012 3:43 PM, Daniel Kasmeroglu wrote:
> Hi there,
> different types.
No. It's purely a data structure representing a mapping. It doesn't do
anything useful other than to represent the mapping.
There really aren't any.
It sounds more like you want to do a model-to-model transformation.
> Thanks in advance.
> Bye
> Kasimir
Re: Ecore 2 Ecore - Could use some input [message #959361 is a reply to message #959254] |
Fri, 26 October 2012 13:02  |
Hi Ed,
Thanks for your answer.
Quote:It sounds more like you want to do a model-to-model transformation.
You're right. I've had the impression that ecore2ecore was some sort of "cheap" M2M which comes with ecore itself. Unfortunately my time constraints on the software doesn't allow me to evaluate and compare different techniques so I will stick with the bad code (nevertheless it's an argument to get involved with M2M techniques anyway when I find the spare time for myself).
P.S.: This topic can be closed now as my questions have been answered properly.
Bye
Kasimir
FUDForum. Page generated in 0.03782 seconds
