Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » How to solve this (reflective?) problem in EMF?
How to solve this (reflective?) problem in EMF? [message #95828] |
Tue, 04 September 2007 07:20  |
Originally posted by: paul.paul.com
Hallo,
I hope I can describe my problem in an understandable way:
I tried to create an Oultine Page using a set of classes (which are
extending EObjectImpl) as its content.
Now, the problem is that for the content I can only get the superclass
EObject and not the "real" class representing the object itself (e.g. ECar
extends EObject, EDoor extends EObject)
whereas I'd like to display the attributes of the objects as part of the
Outline Page (e.g. ECar.type, EDoor.color).
My codes look like below.
Because of some reasons, I'd like not to cast the EObject (to be able to
call ECar.getType()) , but it still somehow must diplay the attributes of
the "real" class behind it, instead of just displaying the name of the class
by calling e.eClass().getName(); so this should happen dynamically. It is
possible to use sort of reflective in EMF? Or is there any better solution
to this?
EObject e = null;
Outline o = null;
for(Iterator iter = ecoreRoot.eContents().iterator(); iter.hasNext();)
e = (EObject)iter.next();
if(e.eClass().getName() != null) {
a = new Outline(e, e.eClass().getName());
Many thanks for ideas.
Best Regards
Re: How to solve this (reflective?) problem in EMF? [message #95858 is a reply to message #95828] |
Tue, 04 September 2007 08:49   |
Paul,
This is just an EMF question for which you should use the EMF newsgroup,
not the EMFT newsgroup. I've added it to the "to" list of the reply.
You can use e.getClass().getName() to get the name of the actual
implementing class, or you can use e.eClass().getInstanceClassName() to
get the name of the generated or wrapped interface (if there is one).
Given the EClass, you can call EClass.getEAllStructureFeatures and for
each such feature, you can call e.eGet(feature) to get the value of that
feature.
Paul wrote:
> Hallo,
> to this?
> EObject e = null;
> Outline o = null;
> Best Regards
Re: How to solve this (reflective?) problem in EMF? [message #95872 is a reply to message #95858] |
Tue, 04 September 2007 09:14  |
Hi Ed,
thanks for the reply.
Before I used e.eClass().eGet and I couldn't get the value. didn't know that
I won't need the eclass() in between. Thanks a lot.
Paul
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag
news:fbjk4r$lhd$1@build.eclipse.org...
> Paul,
> feature.
> Paul wrote:
> > Hallo,
ECar
of
class
is
solution
> > to this?
> > EObject e = null;
> > Outline o = null;
> > Best Regards
Re: How to solve this (reflective?) problem in EMF? [message #609641 is a reply to message #95828] |
Paul,
feature.
Paul wrote:
> Hallo,
> to this?
> EObject e = null;
> Outline o = null;
> Best Regards
Re: How to solve this (reflective?) problem in EMF? [message #609642 is a reply to message #95858] |
Hi Ed,
Paul
> Paul,
> feature.
> Paul wrote:
> > Hallo,
ECar
of
class
is
solution
> > to this?
> > EObject e = null;
> > Outline o = null;
> > Best Regards
Current Time: Fri Jul 25 01:56:00 EDT 2025
Powered by FUDForum. Page generated in 0.04990 seconds
