Home » Language IDEs » Java Development Tools (JDT) » JDBC Connection for Java ( IBM Data Studio )(Java codes for JDBC)
JDBC Connection for Java ( IBM Data Studio ) [message #957149] Wed, 24 October 2012 22:59 Go to next message
package SMART;
import java.sql.*;
public class HelloWorld {
try
Class.forName("COM.ibm.db2.jdbc.app.DB2Driver");
Connection con = DriverManager.getConnection("jdbc:db2:/localhost:50000/CSP");
Statement statement = con.createStatement();
String createProductTable="CREATE TABLE PRODUCT"+
"(NAME VARCHAR(64)," +
"ID VARCHAR(32) NOT NULL," +
"PRICE FLOAT," +
"DESC VARCHAR(256)," +
"PRIMARY KEY(ID))";
statement.executeUpdate(createProductTable);
catch(Exception e){ e.printStackTrace();
- Everytime I run this . This error always pop out
" java.lang.ClassNotFoundException: COM.ibm.db2.jdbc.app.DB2Driver
at java.lang.Class.forName(Class.java:139)
at SMART.HelloWorld.main(HelloWorld.java:8) "
They have said that my Class.forName has no source. Also if I needed to attach a source? what is it and where will I find it?
Best Regards,
G.L Hernandez
Re: JDBC Connection for Java ( IBM Data Studio ) [message #957827 is a reply to message #957149] Thu, 25 October 2012 10:24 Go to previous messageGo to next message
> Best Regards,
> G.L Hernandez
It basically says it can't find that class (i.e. ClassNotFoundException
means it can't find that class). That is the old obsolete type 2 DB2
driver. You should be using the now standard com.ibm.db2.jcc.DB2Driver
which is in the db2jcc.jar from DB2.
Rich
Re: JDBC Connection for Java ( IBM Data Studio ) [message #957873 is a reply to message #957827] Thu, 25 October 2012 11:08 Go to previous messageGo to next message
Okay sir. Thank you very much for the answer. I will try this ASAP
Re: JDBC Connection for Java ( IBM Data Studio ) [message #957908 is a reply to message #957827] Thu, 25 October 2012 11:41 Go to previous messageGo to next message
Still same error sir Rich . What should I do?
Re: JDBC Connection for Java ( IBM Data Studio ) [message #958006 is a reply to message #957908] Thu, 25 October 2012 13:16 Go to previous message
It means it is not in your classpath. Make sure that the db2jcc.jar is
in your classpath for your launch configuration. (Using the com. not
COM. class name in Class.forName("...")
Previous Topic:ECJ usage in eclipse plugin
Next Topic:[SOLVED] generated equals missing not null check
Current Time: Thu Jul 24 17:36:09 EDT 2025
Powered by FUDForum. Page generated in 0.05078 seconds
