Home » Modeling » EMF » [Teneo] Diasbling Two Phase Load Hibernate(Diasbling Two Phase Load Hibernate)
[Teneo] Diasbling Two Phase Load Hibernate [message #957371] Thu, 25 October 2012 03:13 Go to next message
Hi all,
I have a class/entity 'Department'.
It don't have any references to any other class or entities.
When I fetch it using Teneo like below
 Query query = session.createQuery( "from Department" );
 List<EObject> listObj= query.list();
It's taking time in resolving associations as I am seeing below in log
DEBUG org.hibernate.engine.TwoPhaseLoad - resolving associations for [Department#Dept-1]
Why is this happening even though I don't have associations.
Is there anyway I can tell teneo/hibernate to avoid this so that I get quicker turnaround time.
Appasamy
[Updated on: Thu, 25 October 2012 04:38] by Moderator
Re: [Teneo] Diasbling Two Phase Load Hibernate [message #957455 is a reply to message #957371] Thu, 25 October 2012 04:28 Go to previous messageGo to next message
Hi Appasa,
Afaics Hibernate still sees an association, probably from Employee to Department. Does your ecore really not show an
association? If you changed your model, have you regenerated the java code (the model is part of the code, that's used
by Teneo).
I am not sure that resolving association actually means that the referenced object is loaded. To really know/see what
happens you have to check the sql used by hibernate. You can see the sql by setting the hibernate hibernate.show_sql to
true (in the properties you pass to the hibernate store).
Also read the hibernate manual for things like fetch and join strategies. It is quite possible to tune the load
strategies of hibernate.
gr. Martin
On 10/25/2012 09:13 AM, Appasamy Thirugnana wrote:
> Hi all,
> Query query = session.createQuery( "from Employee" );
> Appasamy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Diasbling Two Phase Load Hibernate [message #957466 is a reply to message #957455] Thu, 25 October 2012 04:41 Go to previous messageGo to next message
Hi Martin,
Thanks for the input.
Oops!. The actual query is
Not "from Employee"
Employee- Associated to Department
Department - Not associated to any entity
So my doubt of why hibernate trying to resolve association when I try to load just all Departments.
I will also look in to hibernate documentation as you suggest.
Thanks Martin.
~Appasamy
Re: [Teneo] Diasbling Two Phase Load Hibernate [message #1060396 is a reply to message #957466] Fri, 24 May 2013 09:23 Go to previous message
Hi appasamy,
I have the same issue did you figure out what the issue is ?
Rafeeq
Previous Topic:Model Evolution: Mixing of generated and dynamic models
Next Topic:[XCore] Compiler overrides code tagged as not generated
Current Time: Sat Jul 26 20:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.04335 seconds
