| Hooks into the Synchronize View Context Menu [message #95642] |
Thu, 17 July 2003 07:58  |
Does anyone know offhand if there are any extension points or hooks into
the context menu in the Team Synchronize View? I want to add my cvs
graph plugin capability into that view. There is apparently no
popupmenu extension defined in plugin.xml for the view. Admittedly, I
have not spent a lot of time looking through the source code for this
yet. I was hoping someone might have already done this and know how to
proceed, or that one of the eclipse developers monitoring the list might
reveal the "secret"? ;-)
jeff
Jeffrey Bonevich
Ann Arbor, Michigan
bonevich at covad dot net
jeff at bonevich dot com
http://www.bonevich.com
"Make me a fire and I'm warm for a night. Set me
on fire and I'm warm for the rest of my life."
- Ancient Didactical Saying
| Re: Hooks into the Synchronize View Context Menu [message #96116 is a reply to message #95749] |
Fri, 18 July 2003 00:06   |
Right. I see where I can hook in to CVSCatchupReleaseViewer. But in
order to use my own subclass of it, do I have to provide the entire
hierarchy of classes back to SyncAction and, in essence, provide my own
action, view, etc.? I guess I am not clear what I can use to hook my
own context menu subclass into the existing framework.
I see that in org.eclipse.team.cvs.ui plugin there is a subscriber
extension-point that might be handy to hook in. Am I on the right track?
Thanx!
jeff
Balaji wrote:
> You need to look at the source for CVS sync view.
> Classes imp to you are CVSSyncCompareInput and CVSCatchupReleaseViewer.
> CatchupReleaseViewer has a
> protected void fillContextMenu(IMenuManager mgr)
> which u need to overide to contribute ur own context menu actions.
> HTH, Balaji
> "Jeffrey Bonevich" <jeff@bonevich.com> wrote in message
> news:bf63am$nn1$1@eclipse.org...
>>jeff
>>Jeffrey Bonevich
>>Ann Arbor, Michigan
Jeffrey Bonevich
Ann Arbor, Michigan
| Re: Hooks into the Synchronize View Context Menu [message #96420 is a reply to message #95749] |
Fri, 18 July 2003 08:20   |
Thanx!
jeff
> HTH, Balaji
>>jeff
>>Jeffrey Bonevich
>>Ann Arbor, Michigan
Jeffrey Bonevich
Ann Arbor, Michigan
| Re: Hooks into the Synchronize View Context Menu [message #96799 is a reply to message #96116] |
Fri, 18 July 2003 15:06  |
My experience with Synchronize view is not related to CVS. I created my own
synchronize view.
This is what I would do:
1. Subclass CVSSyncCompareInput. Override
public Viewer createDiffViewer(Composite parent)
to create your own CatchupReleaseViewer (the one that extends
CVSCatchupReleaseViewer).
Finally u need to call your method when CVS Synchronize action is called. (I
have no idea how u would accomplish this task)
Maybe some CVS folks can provide you with more inputs on extension points
provided by CVS plug-in. (Note: I have not looked at CVS code so I don't
know what CVS provides)
HTH, Balaji
news:3F177250.60506@bonevich.com...
> Thanx!
> jeff
> > HTH, Balaji
> >>jeff
> >>Jeffrey Bonevich
> >>Ann Arbor, Michigan
> Jeffrey Bonevich
> Ann Arbor, Michigan
FUDForum. Page generated in 0.03543 seconds
