Home » Modeling » BPEL Designer » Programmatically open an external BPEL File ?
Programmatically open an external BPEL File ? [message #8684] Wed, 04 July 2007 15:56 Go to next message
i want to add functionality such that i can open an external BPEL File (not
in the workspace) either via "Open File..."
or via an JCR-repository.
If i try to open a bpel file via "Open File.." i get execptions because the
input is not of type IFileEditorInput.
As far as i ve seen, BPELEditModelClient only supports IFile ?
How can i achieve this functionality and where is the place to put this
extension?
Thank for your help.
Greetings
Florian
Re: Programmatically open an external BPEL File ? [message #8709 is a reply to message #8684] Thu, 05 July 2007 17:09 Go to previous messageGo to next message
Florian,
I think that's a new 3.3 feature that was added to be able to open
non-workspace inputs in the editors.
You (we) would have to look into the BPELEditModelClient and see what
really prevents us from supporting this. Edit Model client is shared
among different view instances of the editor. Basically, 1 edit model
client, N views (editors). There are some magical listeners that listen
on IFile resource changes so that might be a little bit of an issue.
-michal
Florian wrote:
> extension?
> Greetings
> Florian
Re: Programmatically open an external BPEL File ? [message #9553 is a reply to message #8709] Fri, 17 August 2007 11:05 Go to previous messageGo to next message
first of all, (delayed) thanks for the reply and all past replies to my
posts.
I ve had a look at the org.eclipse.bpel.common.ui.editmodel and i also
think, as you already mentioned, its a bit of an issue to add non IFile
-Support (the edit model seems to be designed for workspace files only).
But since we want to run our (sometime in the future ;) customized bpel
editor in a RCP-App without Workspace-dependencies we will need this
feature (so we or you (?) have to imlement it ;)
However, since 3.3 the org.eclipse.ui.ide plug-in supports opening
external files trough the "Open File..." action by providing an editor
input type "FileStoreEditorInput". Maybe this would make the whole thing
easier...
Is there a small chance this will be in the M3 release (which is
scheduled for today on the web-site) ?
Thanks for your support (which already helped us a lot).
Greetings
Florian
> Florian,
> -michal
> Florian wrote:
>> Hi,
>> (not in the workspace) either via "Open File..."
>> because the input is not of type IFileEditorInput.
>> this extension?
>> Greetings
>> Florian
Re: Programmatically open an external BPEL File ? [message #9833 is a reply to message #9553] Sat, 29 September 2007 23:02 Go to previous message
Originally posted by: yqouyang.126.com
hi,Florian..
Whether you've solved the problem open an external BPEL File by "Open
File..." ? if not ,you've found another way? I met the similar problem:I
want to use the BPEL editor in the RCP-App for modifying the BPEL flow.
If there is no good methods and I have to bring in the workspace in the
RCP-App like the Eclipse IDE .what i should do to achive this?
thanks very much..
Yi
Previous Topic:Integrating graphical editor into RCP application
Next Topic:stand alone running bpel-designer
Current Time: Fri Nov 07 08:42:39 EST 2025
Powered by FUDForum. Page generated in 0.04774 seconds
