Home » Language IDEs » C / C++ IDE (CDT) » Eclipse C++ only has Java Projects ?
Eclipse C++ only has Java Projects ? [message #919060] Fri, 21 September 2012 12:41 Go to next message
I'm using Windows 7.
I can't find the plugins that will show the C++ Project
option in the Project Wizard screen.
I've installed all the C++ software, but no matter.
I can't get eclipse to show C++ project options in the
"Select a wizard" window.
How can I setup C++ and get rid of the Java projects ?
I'm using Eclipse SDK v 4.2.0
It has the EPP CPP Bundle.
I just did a fresh install of Eclipse IDE for C/C++ Developers.
I also installed the C/C++ dev tools dev tools SDK etc.
But when I select New->Project it only shows...
General
---->Project
CVS
----> Projects from CVS
Java
----> Java Projects
I need to be working with C++ projects
But How can I get them on the Wizard screen ??
-Areal
[Updated on: Fri, 21 September 2012 16:05] by Moderator
Re: Eclipse C++ only has Java Projects ? [message #920116 is a reply to message #919060] Sat, 22 September 2012 15:08 Go to previous messageGo to next message
Out of 290 views people 0 have any idea of how to help ?
I don't understand why I cant find the correct plugins so I can
select a C++ project ?
Re: Eclipse C++ only has Java Projects ? [message #920154 is a reply to message #920116] Sat, 22 September 2012 16:01 Go to previous messageGo to next message
It looks like there was a problem with in downloads section on the website
I just downloaded the Windows 32bit IDE for C++ and it works fine.
It has all the C++ options.
There was a problem with the sites download file.
Its working now.
Thanks.
Re: Eclipse C++ only has Java Projects ? [message #955269 is a reply to message #920154] Tue, 23 October 2012 13:00 Go to previous message
I'm having the same problem. Can you elaborate on what was wrong? I also downloaded the 32-bit Windows IDE, but it has no C++ option. I'm trying to follow the C++ tutorials but none of the C++ stuff is there.
Boris.
Previous Topic:CDT GDB No source file named ... error
Next Topic:CDT not building
Current Time: Fri Jul 25 11:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.09796 seconds
