Home » Language IDEs » ServerTools (WTP) » Problems in creating a J2EE web application
Problems in creating a J2EE web application [message #95484] Wed, 27 April 2005 11:15 Go to next message
Originally posted by: Rao.Pankaj.gmail.com
Hi All,
I am using Eclispe 3.1 M6 release with The Eclipse Web Tools Platform
(WTP) plugin. I have j2re1.4.2_07 and jakarta-tomcat-4.1.30 installed on
my machine. When I try to create a new J2EE Web Project I get following
exception in my log file. Any help to resolve this problem would be highly
appreciated.
Saint007
!ENTRY org.eclipse.ui 4 4 2005-04-27 16:35:40.219
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-04-27 16:35:40.229
!MESSAGE
org.eclipse.ui.internal.WorkbenchMessages.getString(Ljava/la ng/String;)Ljava/lang/String;
!STACK 0
java.lang.NoSuchMethodError:
at
org.eclipse.jst.j2ee.internal.wizard.J2EEModulesDependencyPa ge.createTopLevelComposite(J2EEModulesDependencyPage.java:92 )
at
org.eclipse.wst.common.frameworks.ui.WTPWizardPage.createCon trol(WTPWizardPage.java:99)
at
org.eclipse.wst.common.frameworks.ui.ExtendableWizard.create PageControls(ExtendableWizard.java:146)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
at
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: Problems in creating a J2EE web application [message #95856 is a reply to message #95484] Thu, 28 April 2005 10:03 Go to previous messageGo to next message
I have not been able to resolve this problem even after a clean reinstall
of all components.
Re: Problems in creating a J2EE web application [message #96036 is a reply to message #95856] Thu, 28 April 2005 13:31 Go to previous messageGo to next message
WTP M3 is not compatible with eclipse base M6, the upcoming M4 build will
arrive any day now.. please pick this driver up.
Re: Problems in creating a J2EE web application [message #96138 is a reply to message #96036] Fri, 29 April 2005 05:58 Go to previous messageGo to next message
I would try with M4 build.
Re: Problems in creating a J2EE web application [message #97781 is a reply to message #96138] Tue, 03 May 2005 07:23 Go to previous messageGo to next message
I tried using M4 WTP build with 3.1M6 build of eclipse but I could not
find a way to create a J2EE web application. There is no J2EE project
creation wizard available in Java or Web projects.
Please advise.
Thanks and Regards,
Re: Problems in creating a J2EE web application [message #97879 is a reply to message #97781] Tue, 03 May 2005 09:51 Go to previous message
In M4, you have to create a Flexible Java project by going to
File->New->Project->Java->Flexible Java Project, and then add J2EE modules
which may
be Web, EJB or other types.
Previous Topic:WTP M4 and WebServices error IWAB0489E and others
Next Topic:Problems/Bugs? in Web Service generation
Current Time: Wed Jun 25 21:10:03 EDT 2025
Powered by FUDForum. Page generated in 0.08364 seconds
