Home » Newcomers » Newcomers » Pointing Eclipse to Correct Thing(How do I point eclipse to the correct thing when I call R?)
Pointing Eclipse to Correct Thing [message #954327] Mon, 22 October 2012 20:03 Go to next message
Hey all,
I recently started with android eclipse development and I need to connect android-eclipse to another library. The library is the core library of processing.
My problem is that when I create a android project using the android plugin and then I imported the core library into the project, I get conflicting variable/classes. For example, my current roadblock is the android resource class R, where I have the resources for my project. However there is a static final int R in my processing library, so when I call the R class, it jumps to the R int, which i dont want. How do I point eclipse to the correct thing when I call the R class?
Andrew G.
Re: Pointing Eclipse to Correct Thing [message #955028 is a reply to message #954327] Tue, 23 October 2012 08:45 Go to previous message
On 10/23/2012 01:27 AM, Andrew Gies wrote:
> Hey all,
> Andrew G.
The time you saved by ignoring the sticky posts at the top of the forum
is always wasted by waiting for the answer:
http://www.eclipse.org/forums/index.php/t/225513/
This said, I think I might know what you're talking about. You might
find the answer among some notes I took a couple of years ago when I
worked on Android software. I usually assume, however, that Android has
new and different problems today than back then and direct questions
elsewhere (see sticky post above).
http://www.javahotchocolate.com/tutorials/android.html#r-java
Previous Topic:3.7 / 3.6 updatesites access error
Next Topic:CVS repository
Current Time: Wed Jul 23 11:54:21 EDT 2025
Powered by FUDForum. Page generated in 0.08615 seconds
