Home » Modeling » MoDisco » Problems with kdm in an ATL transformation(Problems with kdm in an ATL transformation)
Problems with kdm in an ATL transformation [message #930438] Tue, 02 October 2012 06:11 Go to next message
Hi everyone,
I am trying to implement an ATL transformation between KDM and another metamodel. This is as simple as:
module kdm2cms;
create cmscm : CMSCM from kdm : KDM;
rule kdm2cms {
from
kdm : KDM!Segment
to
cmscm : CMSCM!CMSModel
I try to transform the Segment element from the Inventory Model to a CMSModel element (an element of our metamodel).
When I launch the transformation any error appears in the console or in the error log, but the file generated is empty.
Otherwise, I have implemented a transformation transforming on the contrary (from a CMSModel to a Segment) and it works.
If any of you can help I'd be grateful.
Feliu
Re: Problems with kdm in an ATL transformation [message #953907 is a reply to message #930438] Mon, 22 October 2012 12:26 Go to previous messageGo to next message
It seems that this is more a model-to-model transformation issue not directly related to the MoDisco KDM metamodel implementation.
You should be able to find a correct way to write your ATL transformation (maybe your input KDM model was simply not containing any KDM!Segment element).
Hugo
Re: Problems with kdm in an ATL transformation [message #964109 is a reply to message #953907] Tue, 30 October 2012 05:04 Go to previous message
Good morning Hugo,
Finally, I fixed it registering a new version of KDM metamodel.
Thank you so much.
Feliu
Previous Topic:how to get uml model from java project
Next Topic:startLine and endLine attributes
Current Time: Sun Jul 20 22:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.05680 seconds
