Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Headless EMFStore server(EMFStore Installation Headless)
Headless EMFStore server [message #920568] Sun, 23 September 2012 03:05 Go to next message
Has anyone built a headless EMFStore installation. Will appreciate if someone can share insights on what is involved in creating an headless installation of EMFStore.
thanks in advance.
Re: Headless EMFStore server [message #922814 is a reply to message #920568] Tue, 25 September 2012 07:07 Go to previous messageGo to next message
Hi Namrata.
sorry for the delayed reply. You can build a headless EMFStore product
following this tutorial:
http://www.eclipse.org/emfstore/documentation/buildProduct.php
Let me know if you have any more questions or issues.
Maximilian
Am 23.09.2012 09:05, schrieb Namrata Tiwari:
> thanks in advance.
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: Headless EMFStore server [message #929373 is a reply to message #922814] Mon, 01 October 2012 08:01 Go to previous messageGo to next message
Thanks Maximilian,
The instructions helped.
I'm not stuck on how to launch the instance from a terminal. How can I launch a EMFStore instance from a terminal. Please advise.
thanks
Re: Headless EMFStore server [message #953127 is a reply to message #929373] Sun, 21 October 2012 22:37 Go to previous messageGo to next message
If you exported the product like the tutorial said, then you end up with an executable file emfstore.exe (or just emfstore on Linux) in the exported application in the "eclipse" folder under the root folder you exported to, assuming you used the defaults from the export wizard. I tried this on Windows and it executed fine, I can't try it on Linux right now because my VM is broken. Mad
This is less than ideal for a production application, because at least on Windows you get no feedback really that the app is running unless you open the task manager. For linux it would work fine, since it's much easier to run daemons, but on Windows you would want to use a service wrapper of some kind. Even better, create a WAR file and deploy it on Tomcat or something, then you have some management capabilities. You can use the WAR Product builder from the Libra project, or use one of the many examples on the net for building WAR files with embedded Equinox instances. I usually go with the method described in Jeff McAffer's Equinox book.
Re: Headless EMFStore server [message #953508 is a reply to message #929373] Mon, 22 October 2012 05:51 Go to previous messageGo to next message
sorry for the late reply, I overlooked your reply. To start EMFStore you
launch the generated product executable, e.g. on Windows
<product.name>.exe. Often it is useful to wrap this into a service on
Windows, the following tool helps to do this:
http://www.roeschter.com/
Anyway we will provide support to generate a war file with one of the
next releases.
Maximilian
Am 01.10.2012 14:01, schrieb Namrata Tiwari:
> Thanks Maximilian,
> thanks
Maximilian Kögel
Re: Headless EMFStore server [message #953509 is a reply to message #953127] Mon, 22 October 2012 05:52 Go to previous message
Hi Mike,
thanks for helping out! I overlooked the other reply, but saw your reply
today.
Maximilian
Am 22.10.2012 04:37, schrieb Mike Haney:
> right now because my VM is broken. :x
Maximilian Kögel
Previous Topic:produce high quality diagram output of some ecore models
Next Topic:Create multiple Tabs with EEF based Properties view
Current Time: Wed Jul 23 12:11:32 EDT 2025
Powered by FUDForum. Page generated in 0.09058 seconds
